GM-2 Y-Axis Bellows - Replacement - AD0578
Service Home How To Procedures GM-2 Y-Axis Bellows - Replacement - AD0578
Recently Updated Last updated: 01/07/2025
GM-2/5AX Y-Axis Bellow - Replacement
AD0578
- Jump to Section - 1. Introduction 2. Removal (6 steps) 3. Installation (4 steps) Back to Top
This procedure outlines how to the replace the Y-Axis Bellow cover on GM-2 / 5AX .
This procedure applies to the following service kits:
  • 93-3430 GM-2 Y-AXIS BELLOWS SERVICE KIT
You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
  Only authorized personnel with the proper training and certification should do this repair procedure.
  All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
Removal
Position the X - Axis to the center of the table an the Y - Axis to the center of travel.
Warning: Use the proper safety process when working inside the machine work envelope.
Push [POWER OFF]. Lock Out the main circuit breaker.
Removal of external enclosure panels will need to be done to gain access to the Bellow cover brackets.
Remove the two rear panels on the Tool Changer and the two side panel on the operator side.
Remove the three screw securing the left bellow cover the Y-axis sub-plate and two on the panel behind the Tool Changer Enclosure.
Collapse the bellow cover and remove the four inner screw securing the bellow to the bracket.
From the rear of  the machine on tool changer side, remove the four screw securing the bellow cover bracket the bridge casting  remove the bracket and slide the bellow cover off the guide rails.
Remove the three screw securing the Right bellow cover to the Y-Axis sub-plate.
Remove the four screws securing the bellow cover bracket the bridge casting and slide the bellow cover off the bellow guide rails.
Power On the machine and push [POWER UP]. Jog the the X to the center of travvel and the Y-Axis at Home position.
At this position, remove the seven counter sink screw from both the upper and lower bellow rail supports.
Jog the Y-Axis to center of travel, from the right side of the machine (operator side) remove the last counter sink screw from the bellow support rails. Slide the support rails out from the right side.
Install the new upper and lower Y-Axis waycover rails and secure with the first two screw on the right side of each rail.
Jog the Y - Axis to the HOME position.
Install all remaining screw into the upper and lower Y-Axis waycover rails.
Use the proper Haas Fastener Torque Specifications
Install the bellow on right sides (operator) of the GM Bridge.
Secure the bellow using four 1/4"-20 BHCS on the inside surface of the bracket.
Secure the INTRNL PANL BRIDGE COVER brackets  to the side of the bridge using  1/4"-20 BHCS.
 Secure the Bellows onto the Y-Axis Subplate.
Jog the Y-Axis towards to end travel (tool changer).
Install the bellow on the left sides (tool changer) of the bridge.
Ensure that the bellows on both sides of the subplate collapse and expand correctly when jogging the Y-axis.
Reinstall all extrenal sheetmetal panels onto machine.
