50T Heavy Tool Loader - AD0400
Service Home How To Procedures 50T Heavy Tool Loader - AD0400
Recently Updated Last updated: 08/07/2023
AD0400
- Jump to Section - 1. Introduction 2. Installation (4 steps) 3. Calibration (1 step) 4. Operation (1 step) 5. Reference Images Back to Top
Machine requirements:
  • 100.17.000.2034 or higher software
  • WIPS Option
This document applies to the following kit:
  • 93-2937 50Taper Tool Loader Field Install Kit
Programs and images:
M150/M151 Programs and Images
Install the tool loader in the desired location using the included hardware. The tool loader can only be installed in the X direction like it is shown in the image.
Install the tool [1] onto the tool loader.
Note: Excercise caution for interferences like double arm rotation [2] or an optional rotary's motion.
Set the alignment key [1] in the correct posititon to match the machine tooling, CT or BT.
Make sure the bottom of the tool holder sits on the tool loader. DO NOT insert the tool holder using the grooves.
Indicate the spindle drive dogs parallel to the x-axis. Press [CURRENT COMMANDS] then go Device>Mechanisms under Main spindle orient copy that value to Macro Variable #10994
With the work probe in the spindle, jog until it is over the loader to prepare for calibration.
Dowload M150/M151 programs.
Turn Setting 23 to OFF.
Load the Pickup (M151)  and Drop Off (M150) programs into the 9000 folder in  Memory.
In Settings under the Alias Codes tab, set M MACRO CALL O9007 to 150 and set M MACRO CALL O9008 to 151.
Calibration
To calibrate the loader, go to: EDIT-VPS-PROBING-CALIBRATION-TOOL LOADER CALIBRATION.
Follow the instructions by selecting CT or BT. Manually jog the spindle probe down until the probe is on center of the ½ thru hole.
Cycle Start the program to run from MDI and calibrate the loader position.
The macro position is stored in the G154 P99 offset.
Operation
The loader can be ran from the VPS page or you can generate the G-code by pressing [F4].
 Note: Do not leave tools in the loader while machining. It does not lock the tool in place and they will fall during axis motion.
The control will prompt you to answer if the fixture or spindle are empty before completing the cycles.
Place a heavy tool on the loader. Run the M151 command to pick up the tool and load it into the spindle.
Run the M150 command to unload a tool from the spindle onto the loader. Remove the tool from the loader.
Reference Images
