BMT65/75 Drive Replacement - AD0372
Service Home How To Procedures BMT65/75 Drive Replacement - AD0372
- Jump to Section - 1. Introduction 2. Replacement (9 steps) Back to Top
Recently Updated Last updated: 07/30/2024
BMT65/75 Drive - Replacement
AD0372
Follow these instructions to replace the live tool drive in the BMT turret.
If the BMT drive was damaged by a live tooling crash refer to: Crashed BMT Drive - Replacement otherwise follow the procedure below.
Tools Required:
  • T-0080 BMT65 MASTER ALIGNMENT BLOCK
  • T-0081 BMT65 LIVE TOOL ASSEMBLY PRELOAD TOOL
  • T-0082 BMT65 ALIGNMENT INDICATOR HOLDER
  • T-0083 BMT65 OUTPUT SHAFT ALIGNMENT TOOL
  • T-0133 BMT TORQUE ARM PULLER (For Torque Arms with Set Screws Only)
  • 93-1933A MOBILITH SYNTHETIC GREASE 1QT/0.94L
This Document Applies to the following Service Kit
  • 93-4488 LIVE DRIVE REPLACEMENT KIT BMT-65
  • 93-4562 BMT65/75 LT Shim Kit
Replacement
Index to tool #1 and disable the A-Axis and live tooling motors.
Remove the following items in this order:
  • The live tool and turret servo motors [1].
  • The top and bottom alignment bushings [2].
  • The rear turret gearbox cover [3] (lubricant/oil will drain).
If equiped with live tooling, remove the torque arm [1] with a set screw and ball bearing in the following order:
  • Loosen the jam nut [2].
  • Remove the set screw [3] and steel ball [4].
  • Loosen the two clamp bolts [5].
 NOTE: If needed, install two 5/16-18 bolts in the jack screw holes [6] next to the clamp bolts. Apply just enough torque to spread the torque arm so it can slide off the torque tube.
 NOTE: In the event of a live tool crash the torque arm may be difficult to remove. A pulley puller may be used. If the torque arm still cannot be removed cut it off the torque tube with a grinder. If a grinder was used remove the gears from the turret housing, throughly clean them and the turret housing.
Remove the torque arm.
Remove the snap ring from the torque tube.
To remove the torque arm [1] with set screws, remove the following items in this order:
  • Remove the set screws [2]
  • Loosen the two clamp bolts [3].
Remove and discard the torque arm.
 NOTE: If the set screws are difficult to remove, use a blow torch to apply localized heat to the set screws to soften the loctite.
 NOTE: If needed, install two 5/16-18 bolts in the jack screw holes [4] next to the clamp bolts. Apply just enough torque to spread the torque arm so it can slide off the torque tube.
 NOTE: In the event of a live tool crash the torque arm may be difficult to remove. T-0133 BMT TORQUE ARM PULLER can be used or a pulley puller. If the torque arm still cannot be removed cut it off the torque tube with a grinder. If a grinder was used remove the gears from the turret housing and throughly clean them and the turret housing.
Torque arm with set screws:
T-0133 BMT TORQUE ARM PULLER is used to remove the torque arm from the torque tube.
Install the stop to the torque tube.
Install the puller to the torque arm and install the jack screw to the puller.
Tighten the jack screw to remove the torque arm from the torque tube.
To remove the torque arm with the keyway, remove the following items in this order:
  • Remove the clamp screw [1]
  • Install a 3/8-16 bolt[2] in the jack screw hole next to the clamp bolt. Apply just enough torque to spread the torque arm so it can slide off the torque tube.
Remove the key[3] from the torque tube.
Remove the number ring [1] and live tool drive bracket [2].
Remove the (6) bolts from the retaining ring [4] and slide the live tooling drive [3] out of the turret.
Clean the bore and insert the same stack size of shims [5] from the previous drive.
Install the replacement drive [3] and torque the (6) mounting bolts for the retaining ring [4].
Roughly align the drive head to tool #1
To replace the torque arm [1] with a set screw and ball bearing:
Install the snap ring on the torque tube.
Place the torque arm with the springs on the torque tube. Install the steel ball [2] and set screw [3] with light torque to align the two pieces. Back off the set screw 1/8th of a turn.
Install the T-0081 preload tool [1] on the turret housing.
Remove the jack screws from the threaded holes [5] if used.
Tighten the set screw [3] with Loctite (blue 242) to 10 ft-lb. Lock the jam nut [4] to 35 ft-lb.
Torque the two clamp bolts [6] to 80 ft-lb.
Follow the alignment procedure before installing the rear gearbox cover.
ALIGNMENT PROCEDURE
To replace the torque arm [1] with set screws:
Tighten the set screws [2] with Blue Loctite and torque to 30 ft-lbs.
Install the two clamp bolts [3] with 80 ft-lb of torque.
Install the springs, rear turret gearbox cover and alignment bushings.
Follow the alignment procedure.
ALIGNMENT PROCEDURE
To replace the torque arm with the keyway:
  • Install the snap ring on the torque tube.
  • Install the key[3] to the torque tube.
  • Install a 3/8-16 bolt[2] in the jack screw hole next to the clamp bolt. Apply just enough torque to spread the torque arm so it can slide on the torque tube.
  • Seat the torque arm against the snap ring.
  • Install the clamp screw[1], torque to 80 ft-lbs.
  • Remove the jack screw.
ALIGNMENT PROCEDURE
