Door Edge Sensor - Mill- Installation - AD0583
Service Home How To Procedures Door Edge Sensor - Mill- Installation - AD0583
5.1 Mill Edge Sensor Install
Recently Updated Last updated: 09/29/2023
Door Edge Sensor - Mill - Installation
AD0583
Revision C - 6/2026
The procedure outlines how to install the door edge sensor on mill.
Machine Requirements:
  • Software Version 100.21.000.1110 or higher
  • Haas Autodoor (See machine requirements for CAN AUTO DOOR)
  • 93-1000759: EDGE SENSOR KIT 35 INCH SML VF
  • 93-1000760: EDGE SENSOR KIT 42 INCH MED VF
  • 93-1000761: EDGE SENSOR KIT 37.5 INCH DT/DM-1, MM/SMM
  • 93-1000994: EDGE SENSOR FIELD INSTALL KIT CM-1
  • 93-1001081: EDGE SENSOR FIELD KIT 42 INCH VF-7/9, VR-9
  • 93-1001082: EDGE SENSOR FIELD KIT 42 INCH VF-6/8, VR-8
  • 93-1000889: EDGE SENSOR KIT 42 INCH LRG VF-10/11, VR-11
  • 93-1001100: EDGE SENSOR FIELD INSTALL KIT DC-2
  • 93-1000762: EDGE SENSOR KIT 42 INCH UMC-500
  • 93-1000763: EDGE SENSOR KIT 55 INCH UMC-750/1000
VF - Installation
VF-1/2 (Small)
On VF-Small machines, drill (7) 1/8 inch holes on top of the right door. The hole locations will be the following:
  1. 0.473 in
  2. 3.438 in
  3. 1.000 in
  4. 0.430 in
  5. 0.370 in
  6. 12.210 in
  7. 1.740 in
  8. 0.310 in
  9. 2.625 in
  10. 0.380 in
  11. 0.310 in
VF-3/4/5 (Medium)
On VF-Medium machines, drill (8) 1/8 inch holes on top of the right door.
The hole locations for VF-MEDYT machines will be the following:
  1. 0.47 in
  2. 6.38 in
  3. 2.87 in
  4. 0.50 in
  5. 1.01 in
  6. 0.25 in
  7. 13.69 in
  8. 1.56 in
  9. 0.31 in
  10. 0.80 in
  11. 0.31 in
  12. 0.31 in
The hole locations for VF-MEDNYT machines will be the following:
  1. 0.468 in
  2. 4.500 in
  3. 2.820 in
  4. 0.560 in
  5. 1.015 in
  6. 0.750 in
  7. 13.241 in
  8. 1.350 in
  9. 0.310 in
  10. 0.80 in
  11. 0.31 in
  12. 0.31 in
VF-6/7/8/9/10/11, VR (Large)
On VF-Large machines, drill (8)  holes on top of the right door. The (4) holes in the green circles will need to be 0.125 inches in diameter and the (4) red circles will need to be 0.156 inches in diameter. The hole locations will be the following:
  1. 0.500in
  2. 6.000 in
  3. 1.000 in
  4. 6.000 in
  5. 0.320 in
  6. 7.000 in
  7. 2.200 in
  8. 6.500 in
  9. 2.700 in
  10. 1.000 in
  11. 0.320 in
Remove the handle from the right door and attach the edge sensor bracket [1] by reattaching the door handle [2].
Attach the edge sensor rail [3] to the bracket using (4) self-tapping screws provided.
Note: If the machine has a window airblast option, it will need to be removed and reattached after installing the edge sensor bracket.
Updated
Slide the edge sensor [1] onto the rail as shown.
For VF-Small machines, connect the edge sensor cable to cable [A] and route the cable as shown in [2] using the provided cable clamps and cable carrier.
For VF-Medium & VF-Large machines, connect the edge sensor cable to cable [A] and route the cable as shown in [3] using the provided cable clamps and cable carrier. Secure the other side of the cable carrier using the provided hardware [4] as shown.
Once through the cable carrier, route the cable to the control cabinet along the same path as the Autodoor motor cable.
The cable part number for cable [A] is as follows:
  • VF-Small: 33-0799
  • VF-Medium: 33-1799
  • VF-6/7/8/9: 33-0794
  • VF-10/11: 33-1795
 Note: If the edge sensor cable carrier is unable to fit under the door lock, refer to the Door Height Adjustment section.
For VF-7/9/10/11 and VR-9/11 Machines
Attach the cable carrier support bracket [1] to the top of the door as shown.
 NOTE: To prevent the cable from getting caught in the door, install the second cable carrier support bracket [2] to the opposite side of the door as shown.
This bracket is used to prevent the cable carrier from drooping.
UMC, DT/DM-1, MM/SMM, and CM-1 - Installation
Attach the rail to the sheet metal using the double sided tape provided. Drill 0.159 inch holes in the sheet metal and secure the rail using the provided self-tapping screws.
Note: The image to the right shows the DT/DM/MM/SMM kit which contains 4 self-tapping screws. The CM-1 kit only has 3 screws, but the installation procedure is the same.
 Note: When attaching the rail to the sheet metal, make sure there is clearance for the door to close properly.
Remove the header sheet metal [1] and slide the edge sensor [2] onto the rail.
Reinstall the header sheet metal [1].
Attach the cable on the edge sensor to cable [A]. Route cable [A] to the electrical cabinet as shown.
  • DT/DM-1, MM/SMM, and CM-1: 33-0792
  • UMC-500: 33-1796
  • UMC-750/1000: 33-0799
 Note: The upper image is for DT/DM-1, MM/SMM, and CM-1 and the lower image is for the UMCs.
DC-2 - Installation
Slide the door edge sensor into position on the rail.
Use the SHCS [1]  to connect the cable carrier [2] to the top of the door panel.
Also connect the cable carrier to the top right enclosure panel [3] so that the cable carrier bends as the door opens and closes.
Connect the door edge sensor to cable 33-0799 [4] and route the cable up the door with the cable clamps [5] and feed it through the cable carrier.
Route the edge sensor cable to the control as shown in the image.
Continue to the next sections of this procedure for instructions on wiring and testing the edge sensor.
Wiring Installation
Remove the LVPS and Autodoor power supply assembly [1] from the electrical cabinet.
Make sure the switch on the relay is switched to the ON position [1].
Remove the Autodoor power supply and attach the Edge Sensor Relay bracket (25-15536) [1] to the LVPS  using the screws [2] from the LVPS.
Snap in the Edge Sensor Relay [3] as shown, no hardware is needed.
Reattach the Autodoor power supply [1] to the LVPS and Relay assembly.
Attach the complete assembly [2] into the electrical cabinet.
Connect the following cables to the relay as shown in the diagram:
  1. Cable [A]
  2. Cable 33-1797
  3. Cable 33-0601
  • VF-Small: 33-0799
  • DT/DM-1: 33-0792
Secure any excess cable slack in the control cabinet with zip ties.
Door Edge Activation
Turn on the machine.
Login to the HBC PORTAL.
Download the Door Edge option configuration patch files.
Note: The option files will appear on the configuration download page after the Door Edge service kit has been ordered. If the option does not appear, contact the service department.
Load the option configuration patch file to the control. Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
Verification
Verify that INPUT 128 [1] is triggered when the edge sensor is tested.
Door Height Adjustments
Note: After adjusting the door height, add shims to the stop block as needed to ensure the door lock is triggered correctly.
The required shims are included in the 93-2242 - Pneumatic Interlock Installation Kit.
For troubleshooting door lock issues, refer to Pneumatic Safety Door Interlocks Troubleshooting Guide - TG0110.
Inside of the enclosure at the bottom of each door there are two brackets. Locate the pitch bracket [1], then loosen the screws [2] and roller nut [3].
Keep the upper-right screw [4] slightly tightened and loosen it gradually to avoid the door dropping under its own weight.
Repeat this procedure on the other door [5].
Note: If the cable carrier still cannot fit under the lock after these adjustments, contact Haas service and provide an image showing the height of the lock.
Adjustments to the lower rail may cause the top rollers to become misaligned.
To check, push and pull on the door at several points along the track. If front-to-back movement is present along the entire track, the uppder door rollers are not maintaining three-point contact with the rolling track.
To realign the top rollers loosen the 4 screws on the center bracket [1]. Push the bracket inward until the end rollers are firmly pressed against the track wall. Then repeat this adjustment on the other door [2].
