Low Load Solenoid Valve Kit - Installation - AD0594
Service Home How To Procedures Low Load Solenoid Valve Kit - Installation - AD0594
Recently Updated Last updated: 01/17/2024
AD0594
- Jump to Section - 1. Introduction 2. Installation (6 steps) Back to Top
This procedure outlines how to add in an AC input line filter to the I/O PCB and solenoid output filter on machines with I/O PCB 34-3490A/B. These kits will assist intermittent digital SMC solenoid related alarms.
Machine Requirements:
  • I/O PCB P/N 34-3490A/B
  • 93-3450: DUAL SOLENOID FILTER SERVICE KIT
  • 93-3451: SINGLE SOLENOID FILTER SERVICE KIT
  • 93-3452: SIO PWR FILTER SERVICE KIT
IMPORTANT: Only install the above filter service kits on I/O PCB boards 34-3490A/B. Do not install the filter service kits on I/O PCB boards 34-3490C as the filters are built into the board.
Use the table below to determine which kits are needed for your application.
Solenoid Type Kit 93-3450
Note: Only for machines with I/O PCB 34-3490A/B
Kit 93-3451
Kit 93-3452
Single SMC DIgital Solenoid N/A ✔ ✔
Double SMC DIgital Solenoid ✔
N/A
Note: Lathe APL's will need three (3) of kit 93-3450 and VF & UMC APL's will need two (2) of kits 93-3450.
Push [POWER OFF].
Set the main circuit breaker to the [OFF] position.
Danger: After turning off the machine, wait at least 5 minutes before working in the control cabinet, to allow power to dissipate. Wait for the voltage indicator LED on the vectore drive to go off completely.
Caution: When you handle a PCB, you must wear an Electrostatic Discharge (ESD) strap.
In the lube panel cut off the air supply and bleed the excess from the air gun.
Warning: If you are working on an APL make sure there is nothing in the grippers.
Follow this step for all applications.
Note: This step applies to P/N: 93-3452
For machines without a Tool Changer board
Attach the SIO board to the left side of the I/O board using the standoffs and screws provided.
Disconnect cable 33-0349 from P55 on the I/O board and connect it to the Input connection of the SIO board [1].
Connect the cable from the SIO board to P55 on the I/O board [2].
Put any excess cable in the cable channel path.
For machines with a Tool Changer board
Attach the SIO board to the left side of the Tool Changer board using the standoffs and screws provided.
Disconnect cable 33-0349 from P55 on the I/O board and connect it to the Input connection of the SIO board [3].
Connect the cable from the SIO board to P55 on the Tool Changer board [4].
Follow this step for solenoids in the lube panel.
Note: This step applies to P/N: 93-3450 OR P/N: 93-3451
Disconnect the SMC solenoid [1] from the lube panel connection.
Attach the SMC solenoid to the solenoid filter [3] and attach the solenoid filter to the lube panel connection [2] that the SMC solenoid was previously disconnected from.
Note: Pictured is a single SMC solenoid using a single soleniod filter, same process can be used for the SMC double solenoid by using a double solenoid filter.
Use zip ties to secure the solenoid filter in the cable channel as shown in [1] & [2].
Cut the excess off the zip tie and put any excess cable lengths in the cable channel and slide the cover up as shown in [3].
Follow this step for APL Solenoids
Note: This step applies to P/N: 93-3450 on APL's
Disconnect the APL solenoid [1] and connect it to the double solenoid filter [2] connection [3] that was ordered.
Connect the solenoid filter where the APL solenoid was originally connected to [4].
Zip tie the double solenoid filter to the mounting bracket as shown [5].
Use a zip tie to tie up any excess cables.
Turn the air supply back on.
Turn the machine on and verify that everything works correctly.
