Maincon - Dual Boot Simulator - M17/18.xx / L10/11.xx - Software Recovery - CHC
Service Home How To Procedures Maincon - Dual Boot Simulator - M17/18.xx / L10/11.xx - Software Recovery - CHC
Recently Updated Last updated: 06/11/2024
Revision 1
- Jump to Section - 1. Introduction 2. Prepare the USB device 3. Clean Memory and Dual Loader Software Load 4. Initialize and Configure the Simulator (8 steps) 5. Simulator Mocon Firmware Load (2 steps) Back to Top
This procedure tells you how to recover the software on a Maincon - Dual Boot Simulator - CHC.
Important: This procedure will only work on simulators that are equipped with a Maincon PCB.  To determine if you have a simulator with a Maincon PCB:
  • Press and hold [PRGRM CONVRS] while you press POWER ON.
  • If the BIOS letters are RED then you have a Maincon PCB simulator. If the BIOS letters are GREEN, do Cold Fire 2 - Dual Boot Simulator - M16.xx / L09.xx - Software Recovery - CHC procedure.
Use this procedure for the following scenarios:
  • The simulator software is corrupted.
  • The simulator hangs during boot up.
  • You replaced the batteries on the Maincon PCB.
  • Upgrade the simulator to the latest CHC software release.
  • You replaced the Maincon PCB on the simulator.
  • You are getting a 144 TIME OUT alarm.
Tools Required
  • USB Memory Device
  • Maincon Dual Boot Simulator Software files.  Log into the HBC site to download the files.
Extract the downloaded .zip files.
Copy the files to the root folder of your USB memory stick [1].
Open the Boot folder and make sure the M1829B.bin and L1129B.bin [2] software files are inside.
Important: Make sure the file directory on the USB looks like in the illustration.
Push and hold the [PRGRM CONVRS] button while pressing the POWER on button.
This puts the simulator in MONITOR mode [1].
Do these steps to clear the BBU (battery back-up) memory [2]:
  • Type M6000000 6FFFFFF and push [WRITE/ENTER].
  • After MEMORY TEST PASSED, PRESS RESET TO STOP appears (3) times, push RESET.
Do these steps to clear the Flash memory [3]:
  • Type FC and push [WRITE/ENTER].
  • Wait until FLASH CLEAR COMPLETE!! appears.
Do these steps to load the simulator software file [4]:
  • Insert the USB memory stick into the simulator.
  • Type NGLDR304.BIN and push [WRITE/ENTER].
  • Type UF and push [WRITE/ENTER].
After LOAD COMPLETE!! appears, cycle POWER.
As the Boot Load Screen starts.
Press the [Left] arrow to select MILL.
The simulator will begin searching for the software in the USB Boot folder.  If it can not find the software on the USB, it will search the internal Hard Drive\BOOT folder.
Note: If the simulator does not find any software it will display an error "Start Failed..".  Check the USB directory Boot folder and Cycle the power.
Once it finds the software it will begin load it to memory.
After boot up, the Language File Loader appears.
This loads the new language files and the ROTARY.rpk file.
Note:  The first initial boot, the simulator functions may become unstable before you select a machine model.
Do these steps to select the simulator mill model:
  • In the alarms page type in: DEBUG
  • Press [WRITE/ENTER].
    Note:
    When in DEBUG mode a green line shows around the display boxes [1].
  • Type the desired mill model number (VF2, VF3, VF4, etc.) [2].
  • Push [WRITE/ENTER].
  • The simulator restarts.
  • Push the left arrow to select MILL.
To have the simulator boot from the internal Hard drive.
  • Make a folder in the HARD DRIVE directory labeled BOOT [1] .
    Note: If a BOOT folder already exists go into the folder and delete any previous software versions.
Copy these files [2] to the HARD DRIVE\BOOT folder:
  • M1829A.bin (or current mill software)
  • L1129A.bin (or current lathe software)
  • Write down the simulator serial number that is engraved on the back electrical plate.
  • Set Setting 26 (SERIAL NUMBER) to the correct serial number.
  • Set Parameter 1275 (PENDANT ESTOP) to 0 [1] for simulators built before May 2011 without redundant PENDANT ESTOP circuitry.
  • Set Parameter 737:17 (ENABLE CIRCUIT BREAKER MONITOR) to 0 [2].
  • Reset all the alarms and zero return all the axis.
Cycle POWER.
Push the right arrow to select LATHE.
The simulator will now load the lathe software into memory.
 Note: Simulator functions may become unstable before you select a machine model. Clear the alarms and continue.
Do these steps to select the simulator lathe model:
    Note:
  • Type the desired lathe model number (ST10, ST20, ST30, etc.) [2].
  • The simulator restarts. Push the right arrow to select LATHE.
  • Set Parameter 1275 (PENDANT ESTOP) to 0 for simulators built before May 2011 without redundant PENDANT ESTOP circuitry.
  • Set Parameter 737:17 (ENABLE CIRCUIT BREAKER MONITOR) to 0.
Perform the following procedure ONLY if you have replaced the Maincon PCB on the simulator.
 Important: DO NOT attempt this procedure if you do not completely understand the instructions. Contact your Haas Factory Outlet (HFO) and schedule a service technician visit if you have any doubts about doing this procedure.
Press [POWER OFF].
Wait 10 seconds, then press and hold [PRGRM CONVRS] while you press POWER ON.
Make sure the S511SIM.bin file is on the root of the USB memory device.
In Monitor mode, wait 1 minute.
Type MM1
Press [WRITE/ENTER ] [1].
Make sure you have a double prompt [2]:
MOCON>>
MOCON>>
Type: FC 200000
Caution: The number is 2 with (5) zeros. Make sure you type this number correctly before you continue.
Press [WRITE/ENTER] [3].
Type N S511SIM.BIN [4].
Press [WRITE/ENTER]
Type UF 200000 [5].
After the firmware upload is complete the control will show the message shown in the illustration [6].
