    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
    • Deals Of The Week
      Deals Of The Week Shop All
      • Grooving Tools
      • Cut-Off Tooling
      • Boring Bars
      • OD Toolholders
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Network Cable Tester Tool
Service Home How To Procedures Network Cable Tester Tool
Recently Updated Last updated: 06/30/2023
Network Cable - Tester Tool
- Jump to Section - 1. Network Cable Tester Video 2. Introduction 3. Maincon PCB to SKBIF PCB Test (1 step) 4. Maincon PCB to Serial I/O PCB Test (1 step) 5. Maincon PCB to Enet Port Test (1 step) Back to Top
This procedure will show you how to use a network cable tester tool on a machine with the Next Generation Control (NGC).
The Next Generation Control uses network cables to transfer high speed data between the printed circuit boards (PCB's).
The integrity of these cables is very important for the correct function of the machine. The network cable tester tool enables you to quickly and easily verify the integrity of these cables.
In this procedure we will use a Fluke Networks MT-8200-49A cable tester, similar cable testers can be used.
 Note: Make sure your network cable tester is able to test shielded network cables.
Turn off the machine, and remove the stack cover.
Disconnect the RJ45 cable from the J9
 port on the  Maincon PCB [1].
Connect the RJ45 cable to the cable tester remote unit [2].
Remove the pendant back cover.
Disconnect the RJ45 cable from the J28 port on the SKBIF PCB[3].
Connect the RJ45 cable to the cable tester unit [4].
Select the cable test and press the Test button on the unit [5].
Make sure the cable passes the test and there is no shorts or opens detected.
 Note: The cable tester shown, all the LED lights turn green when the cable is good [6]. Other cable testers may show different indicators.
If cable tester detects a problem with the cable, replace the cable and test before installing.
Disconnect the RJ45 cable from the J14 port on the Maincon PCB [1].
Remove the I/O PCB cover.
Disconnect the RJ45 cable from the J4 port on the I/O PCB [3].
Select the cable test and press the [Test] button on the unit [5].
Make sure the cable passes the cable test and there is no shorts or opens detected.
Disconnect the RJ45 cable from the J7 port on the Maincon PCB [1].
Disconnect the RJ45 cable from the ENET port on the side of the control cabinet [3].
Select the cable test on the network cable tester.
Press the [Test] button on the unit [5].
 Note: The cable tester shown, all the LED lights (except the shield light) turn green when the cable is good [6]. Other cable testers may show different indicators.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
