SKBIF PCB - Replacement - NGC - AD0340
Service Home How To Procedures SKBIF PCB - Replacement - NGC
Recently Updated Last updated: 01/31/2022
AD0340
- Jump to Section - 1. Introduction 2. Replacement (2 steps) Back to Top
This procedure tells you how to replace the SKBIF PCB.
Download and fill out the SKBIF Inspection Report Checklist below before replacing any parts. It can be found at the SKBIF and LCD Monitor troubleshooting guide.
This document applies to these parts:
  • 93-32-4510: SKBIF FOR NGC W/ RJH-C/VID CCA SVC KIT
  • 93-32-4510B: SVC KIT SKBIF-NGC W/ RJH-C/VID CCA ROHS3
  • 93-32-4510C: SVC KIT SKBIF-NGC W/RJH-C/VID CCA ROHS3
Replacement
When you handle a PCB, you must wear the electrostatic discharge (ESD) strap.
Push [POWER OFF]. Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Danger: After turning off the machine, wait at least 5 minutes before working in the control cabinet, to allow power to dissipate. Wait for the voltage indicator LED on the vector drive to go off completely.
Remove the rear cover and disconnect all cables connected to the SKBIF PCB. Record the location of each cable.
Remove the (4) 6-32 x 3/8" Phillips pan-head screws (PPHS) and the SKBIF PCB from the control pendant.
Make sure the positions of the DIP switches on SW1 on the replacement SKBIF PCB [1] are the same on the removed SKBIF PCB.
Make sure there the jumper orientations on JP2 and JP3 on the replacement SKBIF PCB [1] are the same as on the removed SKBIF PCB.
Install the replacement SKBIF PCB [1] and the (4) 6-32 x 3/8" PPHS [2].
Connect all of the cables to the replacement SKBIF PCB [1].
