H-5AX Spindle Collet Push Out and TRP Sensor Adjustment
Service Home How To Procedures H-5AX Spindle Collet Push Out and TRP Sensor Adjustment
- Jump to Section - 1. Introduction 2. Scheduled maintenance (2 steps) 3. Lubricate the spindle collet (2 steps) 4. Measure Spindle Collet Push Out 5. Spindle Clamping Cone Push Out Adjustment (4 steps) 6. TRP Sensor Adjustment (10 steps) 7. TRP Sensors 8. TRP Sensors Adjustment (5 steps) 9. Prox Sensor Tester (T-0220) (5 steps) Back to Top
Recently Updated Last updated: 03/13/2026
AD0941
Revision C - 03/2026
This document applies to H-5AX A63 and F63 Spindle types
This procedure explains how to verify and adjust the spindle clamping cone push out and TRP sensor adjustment.
This document applies to the following service kits:
  • 93-3155 HSD TRP SENSOR S1
  • 93-3157 HSD TRP SENSOR S2
  • 93-3158 HSD TRP SENSOR S4
  • T-0220 PROX SENSOR TESTER LED PNP/NPN
  You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
   Only authorized personnel with the proper training and certification should do this repair procedure.
   All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
Frequency: MONTHLY
To maintain the spindle clamping cone in perfect working order, lubricate it every month with grease:
METAFLUX-Fett-Paste Nr.70-8508 (Not Sold)
or alternatively
METAFLUX-Moly-Spray Nr.70.82 (Not Sold)
  •  The grease should be added between the segments and the spindle clamping cone.
  • Perform approx. ten tool changes in order to evenly distribute the grease
  • Remove the tool holder from the spindle and with a clean cloth remove any lumps of visible grease
Warning: Excess grease is harmful since it could hold chips or other machining operation deposits
Frequency: 6 MONTHS or 200,000 tool changes
  • Check the spindle clamping cone push out and adjust it if necessary
NOTE: Adjustment of the clamping cone and the tightening of the lockscrew must be carried out together
  • Checking the Spindle Clamp force.
Note: Make sure the spindle clamping cone adjustment is completed before adjusting the TRP sensor
  • Bring the spindle to the full Unclamp position, where the Drawbar is forward and the clamping cone is to the maximum Push Out.
  • Use a depth gauge to check that position of the clamping cone in relation to the spindle nose, the value (1).
 (10.6 mm +0.1 / -0.0 mm / 0.417 in + .004 / -0.0 in)
  •  If the push out is incorrect, make the adjustment described in the steps below
Note: Make the spindle clamping cone adjustment is completed before adjusting the TRP sensor
Warning: Manufactor uses Loctite 243 on the Lock screw. Apply heat directly to the Lock Screw before attempting loosen.
  • Bring the spindle to the full Unclamp position, where the piston is forward and the clamping cone is to the maximum distance.
  • Using a Metric box wrench and Metric Hex Key loosen (CCW)  the lockscrew in the Draw Bar.
With the  Lock Screw loose;
  • Rotate the clamping cone Clockwise to decrease the push out
  • Rotate the clamping cone Counter Clockwise to increase the push out
Tighten (CW) the lockscrew against the Draw Bar. Torque the Lockscrew to the values indicated  below;
Collet Type Torque Value
F63 20 Nm / 14.75 ft-lbs
A63 30 Nm /  22.1269 ft-lbs
Verify Spindle clamping cone push out after the Lockscrew has been torquesed to the correct value.
Assemble the drawbar force gage according to the manufacturer’s instructions. Put the gage into the spindle.
  • Take the Setup and CAREFULLY place it into the spindle.
  • Grab the tool from the Adapter Diameter, beware of pinch points.
  • Read the force on the Gauge, the following are force readings allowable:
 H-5AX Spindle :
HSK-A63 = 2832 - 5170 lbf (12.6-23 kN)
HSK-F63 = 1731 - 3147 lbf (7.7-14 kN)
TRP Sensors
Identifying the sensors for ES779 and ES789
  1. S1+S4 - Clamping cone locked in the correct position (DRAWBAR CLOSED)
  2. S2  - Clamping cone open tool-holder ejected, Draw Bar forward (DRAWBAR OPEN)
  3. S3 - Not Used
  4. S5** - Not Used
** Present in certain versions only.
Unscrew the 4 screws from the corners of the TRP cap. There is also a thin layer of silicone fixing the cap to the spindle, but a slight force is enough to remove it.
Adjusting sensor S2
  • Command the spindle to the “Unclamped ” condition, where the piston is forward , use a depth gauge to check that position of the clamping cone in relation to the spindle nose reaches of 10.6 mm +0.1 /0 mm; 0.417 in + .004 /0 in
  Note: if the push out is incorrect, Checking and adjusting the HSK clamping cone position” before adjusting the sensor
  • Use a regulator to lower the pressure  to bring the clamping cone to the minimum distance of 10.4 mm (0/-0.1) /  0.409 "(0/-0.0039")
  • Actuate the TRP and verify the clamping cone is at the correct distance.
  • Loosen the screw to the sensor clamp (1). Rotate sensor S2 until you find the position that provides a <1> on “SPINDLE DRAWBAR OPEN”  Input 52 on the Diagnostics > I/O Tab.
  • Tighten the screw on the sensor clamp, increase the TRP regulator back to 145 psi
  • Actuate the TRP and verify the “SPINDLE DRAWBAR OPEN” bit is changing properly.
Adjusting sensors S1
  • Insert a tool holder in the spindle.
  • Loosen the sensor clamp on S1 and remove the sensor clamps from S4.
  • Remove S4 from the TRP body, place a metallic object in front of the sensor.
  • Watching INPUT 54 SPINDLE DRAWBAR CLOSED on the Diagnostic > I/O Tab.
  • Inspect S1 for the reference mark (Red Dot), Rotate the S1 sensor CW or CCW until the INPUT 54 changes state on the screen
  • Rotate back to the location in which the input is <1> and tighten the screw that fastens the sensor clamp.
  • rotate the spindle shaft manually and check that INPUT 54 SPINDLE DRAWBAR CLOSED do not change state.
Adjusting sensors S4
  • Insert S4 back into the TRP body and install the sensor clamp hand tight.
  • Inspect S4 for the reference mark (Red Dot), Rotate the S4 sensor CW or CCW until the INPUT 54 changes state on the screen.
Install the TRP cap, careful not to damage the sensor cables inside. Applying a thin layer of silicone fixing the cap to the spindle.
Locate the Prox Sensor Tester [1] and the Tester cable [2] in T-0220.
Pressing [1] the buttons on the Prox Sensor Tester will open [2] the contact surface to allow the cable pins to be inserted.
Releasing [3] the buttons will close [4] the contact surface and secure the cable pins.
Place the tester cable pins into the Prox Sensor Tester in the following order from left to right:
Blue [1], Black [2], Brown [3]
Connect the sensor [1] to the test cable [2].
Touch the sensor [1] on a piece of steel [2].
On the Prox Sensor Tester, a green light [3] and beep should trigger if the sensor is functioning correctly.
No light or sound will trigger if the sensor is not functioning correctly.
