Vector Drive - Electrical Cabinet Door - Vent Hole Modification - AD0245
Service Home How To Procedures Vector Drive - Electrical Cabinet Door - Vent Hole Modification - AD0245
Recently Updated Last updated: 05/16/2025
AD0245
Revision A - 05/2025
- Jump to Section - 1. Introduction (2 steps) 2. Template 3. Vent Hole Modification (2 steps) Back to Top
This procedure tells you how to create a vent hole in the electrical cabinet door. Do this procedure after you replace a Type 1 vector drive with a Type 2 vector drive.
Applies to machines built from: May, 2003 to August, 2007
Haas machines have one of these 60 hp vector drives:
  1. Type 1: Classic vector drive
  2. Type 2: Smart vector drive (current style)
All of the replacement vector drives look like Type 2.
KIT PN: 93-32-5560, Vector Drive, 60HP Smart.
59-0237 RUBBER EDGE TRIM TRIM-LOK #X1002
Tools Required
  • Jigsaw
Template
Machines with a Type 1 vector drive do not have the necessary cutouts. After you install a Type 2vector drive, you must use this template to make the necessary cutouts.
The diagram shows the inside of the door to the electrical cabinet. Use these dimensions to find where to cut the holes for the vector drive vents:
  • A - 19" (48 cm)
  • B - 4.5" (11.4 cm)
  • C - 11" (28 cm)
  • D - 2.5 (64 mm)
  • E - 3.25" (83 mm)
  • F - 3.25" (83 mm)
Push [POWER OFF]. Set the main circuit breaker to the OFF position.
Open the electrical cabinet door.
Danger: After turning off the machine, wait at least 5 minutes before working in the electrical cabinet, to allow power to dissipate. Wait for the voltage indicator LED on the vector drive to go off completely.
Use the cutout template to put marks for the holes you will cut. Make sure the marks align with the vector drive vents [2].
Remove the cabinet door.
Use a jigsaw [1] to cut the vent holes. Remove all burrs from the vent holes. Clean the door.
Caution: Make sure chips and debris from the door stay out of the electrical cabinet.
Put the RUBBER EDGE TRIM [A] around the edges of the cut areas.
