Axis Lubrication System - Non-Restrictor Flow Grease - RD0008
Service Home Axis Lubrication System - Non-Restrictor Flow Grease - RD0008
Recently Updated Last updated: 10/16/2025
RD0008
- Jump to Section - 1. Introduction 2. Identification Back to Top
Note: The location of the grease reservoir is different on some machines.
The non-restrictor flow grease lubrication system is an equal length system that pumps grease through flexible plastic tubing and copper tubes to the axes.
Identification
Note: For recommended lubricant types, see Lubricant Table for Haas Machine Components.
  1. Grease Reservoir Assembly - Stores the grease.
  2. Grease Filter Wrench - Removes the grease reservoir.
  3. Axis-Lube Air Solenoid - Pressurizes the grease reservoir [1].
  4. Air-Lube Panel Decal - Shows the color-coded cables that connect each solenoid.
  5. Oil Reservoir - Stores the oil that lubricates the spindle.
  6. Air Pressure Gauge - Shows the pressure (in psi and bar) at which the air is regulated.
  7. Air Manifold Assembly - Supplies air to the machine.
Main Distribution Manifold
  1. Main Distribution Manifold - Sends grease to the axis manifolds.
  2. Main Distribution Manifold Pressure Switch - Monitors the grease supply pressure and sends a signal to the control to generate an alarm if the pressure drops too quickly.
Axis Lubrication Cycle
The grease reservoir lubricates the axes at a rate of (1) pump cycle for every 24 hours of axis motion.
Grease moves from the grease-canister [1] through flexible plastic tubing to the main distribution manifold [2].
Grease moves from the main distribution manifold [2] to the axis manifolds [3].
Note: The amount of axis manifolds may be different on some machines.
Note: Each axis has (2-6) linear guide trucks [4] and (1) ballnut [5].
Grease moves from the axis manifolds through copper tubes. The copper tubes lubricate the linear guide trucks [4] and ballnut [5].
Axis Manifold Fitting Information
The non-restrictor flow grease lubrication system uses adapter fittings [1] in axis manifolds. The linear guide trucks also use adapter fittings [2]. There are no restrictor fittings in this system. The flow of grease is controlled by equal length flexible plastic tubing and copper tubing to each distribution point.
Note: Adapter fittings are smaller than restrictor fittings and do not restrict the flow of grease.
Note: The copper tubes on this system are equal length.
Note: Do not change the length of the copper tubes or flexible plastic tubing. This changes the flow of grease.
