HDC-3 Install Guide
PRE-INSTALLATION [GUIDE]
HDC-3 Install Guide
    CNY ONLY
5-Axis CNC double-Column Mill with 150" x 106" x 39" travels
  • 50 Taper
  • 5 Axis
  • 7500 RPM
  • 50+1 Tool Capacity
  • STEP-BY-STEP GUIDE
  • Layout Drawing
  • Lifting Instructions
  • Rotary Fit
  • Additional Resources
Pre-Installation Checklist
  • Make sure that your floor is correct for the machine. Refer to the “Placement and Preparation” in this document for more information.
STEP-BY-STEP INSTALLATION GUIDE
Foundation
You must put your machine on a solid and stable concrete foundation. This machine requires a 12" (300 mm) concrete foundation, to ensure accurate geometry.
Refer to these specifications:
  • Continuous slab – DO NOT place machines across expansion joints or cracks.
☑ Anchoring
This machine must be anchored for best cutting performance. Click here to view anchoring kits for your machine
  • Download anchoring pattern
☑ Machine Placement
  • Ensure adequate machine installation clearance (see below)
☑ Optional Component Location
  • External Transformers.
Layout Drawing
Download Machine Layout Drawing (PDF) (Coming Soon)
The HDC-3 is not suitable for overhead lifting. It does not have built-in lifting provisions, and must be lifted by forklift.
Machine Installation Clearance
BRIDGE INSTALLATION OPTION 1: BRIDGE ASSEMBLED TO COLUMNS FROM REAR OF MACHINE.
STEP 1 – ENSURE BOTH DIMENSIONS ‘A’ AND ‘B’ CONDITIONS ARE MET FOR ADEQUATE MACHINE INSTALLATION CLEARANCE.
STEP 2 – INSTALL COLUMNS.
STEP 3 – INSTALL BRIDGE ASSEMBLY (BRIDGE IS STACKED ON COLUMNS BEFORE SADDLE IS IN FINAL POSITION. SADDLE SHOWN IN FINAL POSITION FOR REFERENCE ONLY).
STEP 4 – INSTALL SADDLE ASSEMBLY FROM FRONT OF MACHINE.
BRIDGE INSTALLATION OPTION 2: BRIDGE ASSEMBLED TO COLUMNS FROM FRONT OF MACHINE.
NOTE: BRIDGE ASSEMBLY SHOWN IN SHIPPING CONFIGURATION (WITH FORKLIFT TOOL) FOR INSTALLING ON COLUMNS.
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Spindle Speed 7500 rpm 7500 rpm
Spindle Power 60.0 hp 44.7 kW
Full Load Amps (3 Phase) - Low 105 A 105 A
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines CL-1, and CM-1. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
ATTENTION! Optional high-performance spindles have a higher power requirement than the standard spindle. Verify the power requirement before running power for your machine.
Caution:
    • soluble oil coolant
    • semi-synthetic coolant
    • synthetic coolant
General
  • Refer to the Machine Layout Drawing for the location of the machine’s electrical input.
440 V Power *
  • Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop machines, CL-1 ,and CM-1.
Ground
Three-Phase Power
  • For Mini Mill Series machines, some options, such as Through-Spindle Coolant, require three-phase power.
Single-Phase Power
Wire Size
Service Breaker
Phase Converters
Rotary Fit Chart
* If a rotary product is not listed, it is does not have a compatible fit with this mill.
  • Anchoring Instructions
  • Video Library
  • Operator’s Manual
  • Service
