6 - Rotary - 5-Axis Models
Rotary/Tailstock - Operator's Manual Supplement
  • 1 - Rotary - Introduction
  • 2 - Rotary - Legal Information
  • 3 - Rotary - Installation
  • 4 - Rotary - Operation
  • 5 - Rotary - MRZP
  • 6 - Rotary - 5-Axis Models
  • 7 - Rotary - Programming
  • 8 - Rotary - G-Codes
  • 9 - Rotary - Parameters
  • 10 - Rotary - Maintenance
  • 11 - Rotary - Workholding
  • 12 - Tailstock - Operation/Setup
  • 6.1 Tilting Rotary
  • 6.2 Trunnion Rotary
  • 6.3 Rotary relations
6.1 Tilting Rotary
TRT70 Features
Specifications Overview
For more specifications see the SPECS section on the main website for TRT70.
For installation on a New Generation Control (Storm) you must have Software Version 100.17.000.2030 or newer.
  • The TRT70 is a unique product designed to interface with the Compact Mill (CM) but can be used on any Vertical Machining Center.
  • The A (tilt) & B (rotary) axes do not have a home switch.
  • The TRT70 homes using the encoder Z-pulse.
    Note: The tilt and rotary axis will find home about 10° from the position where it was left at power off. In order to zero return the tilt and the rotary to the same home position every time: manually jog the tilt and rotary axes to align the markings on the black adapter [2], and the line on the platter [1], with the lines on the casting. Then, the TRT70 needs to be zero returned again to ensure that the home position for the tilt axis is flat and facing up and that the home positon for the rotary axis will be the same every time.
  • The TRT70 is a combination worm gear & spur gear driven system [3].
    Note: A & B axis cannot be back driven.
  • Neither the tilt or rotary axis has a brake.
  • Provided pull pins are used for the CM to center the rotary quickly.
Field Servicable Features
  • Cables and J-box gaskets can be replaced
  • Motors, motor enclosures and gaskets can be replaced
  • B-axis oil O-ring can be replaced [4]
  • A-axis backlash adjustment [5]
  • B-axis backlash adjustment [5]
  • Oil changes for the A-axis are the same as the HA5C. See Maintenance section on the rotary service manual.
  • Oil changes for the B-axis are slightly different than the HA5C. See Maintenance  section on the rotary service manual.
TRT160 Features
For more specifications see the SPECS section on the main website for TRT160.
Requires a Haas mill with 4th- and 5th-axis drives for true 4th- and 5th-axis operation.
Requires Software Version NGC 100.18.000.1030 or newer to work with DWO/TCPC option.
Consult your local HFO for use on machines with a Classic Haas control.
  • Features a larger work capacity in size and weight than the TRT70
  • Low profile design allows for more z-axis clearance.
  • TRT160 is compatible with standard bolt-hole pattern platter, T-Slot platter, or A5 platter to bolt manual A5 chucks and accessories directly to the rotary spindle nose.
  • Available with 6" manual 3 jaw chuck, and air clamping provision.
  • Automatically finds home position
  • Unique casting design allows the table to be mounted to the extreme right of the mill table [2].
  • No need to remove the table to accomplish large 3-axis work!
  • Note: Image shows TRT160 mounted on VF-2 table.
  • Oil changes are made simple with two easily accesible drain plugs. See Maintenance section on the rotary service manual for A and B-axis oil changes.
TRT210 Features
For more specifications see the SPECS SECTION ON THE MAIN WEBSITE FOR TR210.
Requires a Haas mill with 4th- and 5th-axis drives and Software Version 18.00 or newer for true 4th- and 5th-axis operation.
  • A more robust work center for larger, heavier parts.
  • The TRT210 has a greater selection of both platter and workholding options.
  • Compatible with standard bolt-hole pattern platter, T-slot Platter, A6 spindle nose which allows manual A6 chucks and accessories to bolt directly to the rotary spindle nose, or Zero Point Platter which accepts industry-standard zero-point tooling.
  • Available with 8" Manual 3-Jaw Chuck, and air clamping provision.
  • Unique casting design allows the table to be mounted to the extreme right of the mill table so that operators still have plenty of room for 3-axis vise work.
  •  Note: Image shows TRT210 mounted on VF-3 table.
  • Oil changes are made simple with two easily accesible drain plugs [1]. See Maintenance section on the rotary service manual for A and B-axis oil changes.
6.2 Trunnion Rotary
TR160 Features
For more specifications see the SPECS SECTION ON THE MAIN WEBSITE FOR TR160.
Requires a Haas mill with 4th- and 5th-axis drives and Software Version 18.00 or later.
Scale feedback only functional with software version 18.00 or later. Scale feedback does not function with rotary control box.
  • Our most compact trunnion table provides 4th and 5th axis capability while offering maximum rigidity for machining small to medium parts.
  • Available with our standard 250 mm or 400 mm platter to provide additional support for larger workpieces.
  • Optional 6" Manual 3-Jaw Chuck and Rotary Brake Booster
  • A-axis Scale option provides high-precision scale feedback on the A-axis (tilt) to improve accuracy and repeatability, by compensating for wear, backlash, or additional forces exerted by overhung loads.
Maintenance is made simple using sight glasses [2] to check oil levels, and accessible fill ports [1] for refilling or changing oil easily. See Maintenance section in the Rotary Service Manual for A-axis and B-axis oil changes.
TR210 Features
Requires a Haas mill with 4th- and 5th-axis drives and Software Version 18.00 or later for true 4th- and 5th-axis operation.
  • This trunnion table provides increased working capacity for larger parts with longer swing, while maintaining stability.
  • Available with our standard 350 mm or the 500 mm Platter for mounting larger workpieces or multiple fixtures.
  • Optional 8" Manual 3-Jaw Chuck and Rotary Brake Booster.
Maintenance is made simple using sight glasses to check oil levels, and accessible fill ports for refilling or changing oil easily. See Maintenance section in the Rotary Service Manual for A-axis and B-axis oil changes.
6.3 Rotary Relations
Rotary Relations
When setting up 5-axis rotaries, the relationship between the two rotaries must be defined.
  1. Master
  2. Slave
  3. Independent.
If the intention is only to use the axis for indexing, "Independent" can be used. However, if the intention is to use G254 DWO or G234 TCPC, one axis must be set as the "Master" and the other as "Slave".
When selecting which rotary should be the master or the slave. The stacked rotary must be set as the slave [1], and the base rotary attached to the machine as the master [2].
