8 - Rotary - G-Codes
Rotary/Tailstock - Operator's Manual Supplement
  • 1 - Rotary - Introduction
  • 2 - Rotary - Legal Information
  • 3 - Rotary - Installation
  • 4 - Rotary - Operation
  • 5 - Rotary - MRZP
  • 6 - Rotary - 5-Axis Models
  • 7 - Rotary - Programming
  • 8 - Rotary - G-Codes
  • 9 - Rotary - Parameters
  • 10 - Rotary - Maintenance
  • 11 - Rotary - Workholding
  • 12 - Tailstock - Operation/Setup
  • 8.1 Control Box - G-Codes
his section gives detailed descriptions of the G-codes and Parameters that your rotary uses. Each of these sections begins with a numerical list of codes and associated code names.
G- Code Description
G28 Return to home position (same as G90 with step 0)
G33 Continuous motion
G73 Peck cycle (linear operation only)
G85 Fractional circle division
G86 Turn CNC relay on
G87 Turn CNC relay off
G88 Return to Home position (same as G90 with step 0)
G89 Wait for remote input
G90 Absolute position command
G91 Incremental command
G92 Pulse CNC relay and wait for remote input
G93 Pulse CNC relay
G94 Pulse CNC relay and run next L steps automatically
G95 End of program/return but more steps follow
G96 Subroutine call/jump (destination is a step number)
G97 Delay by L count/10 seconds (down to 0.1 second)
G98 Circle division (circular operation only)
G99 End of program/return and end of steps
Control G-Codes Explaination
G28 Return Home
G28 (and G88) provide a programmed return to home command. The feed rate (F) is used to provide the rate of return to the zero position.
G33 Continuous Motion
When remote CYCLE START is manually closed and held or an M-Fin signal from the CNC controller is active at a G33 step, continuous rotary movement is started. Motion stops when remote CYCLE START is manually opened or the M-Fin signal from the CNC controller is removed.
M51 to close and M61 to open.
G73 Peck Cycle
Refer to the Mill Manual G73 High Speed Peck Drilling Canned Cycle description and G91 Incremental Command.
G85 Fractional Circle Division
For TRT units, circle division is selected with G85. The L defines how many equal parts a circle is divided into. After the L count steps, the unit is in the same position it started from. Circle division is only available in the circular modes (i.e., Parameter 12 = 0, 5, or 6).
G86/G87 Turn CNC Relay On/Off
G86 closes the FINISH SIGNAL relay in the Servo Control.
CNC Relay On: [1] CNC Mill, [2] Servo Control
NOTE: If the control is used around high-frequency equipment, such as electric welders or induction heaters, shielded wire must be used to prevent false triggering by radiated EMI (electromagnetic interference). The shield should be attached to earth ground.
If your application is in an automatic machine (CNC mill), the feedback lines (FINISH SIGNAL pins 1 and 2) are used. Pins 1 and 2 are connected to the contacts of a relay inside the control and have no polarity or power on them.
They are used to synchronize the automatic equipment with the Servo Control.
The feedback cables tell the mill that the rotary unit has finished. The relay can be used to FEED HOLD NC machine movements, or can be used to cancel an M-Code function. If the machine is not equipped with this option, an alternative may be to dwell (pause) longer than it takes to move the rotary unit. The relay triggers for all CYCLE START closures, except G97.
G87 opens the FINISH SIGNAL relay.
G88 Return To Home Position
G88 Return to Home position is the same as G90 with step 0. Refer to G28 Return to Home Position.
G89 Wait For Remote Input
G89 waits for the remote input (mFin). Stops rotary/indexer and waits for mFin signal to continue motion.
G90/G91 Absolute/Incremental Position
G90 is used to indicate absolute positioning and G91 is used for incremental positioning. G91 is the default value.
G92 Pulse CNC Relay And Wait For Remote Input
Same as G94 except Servo Control waits for remote input.
G93 Pulse CNC Relay
Same as G94, with no loop.
G94 Pulse CNC Relay And Run Next L Steps Automatically
G94 is used to perform simultaneous milling. The relay is pulsed at the beginning of the step so that the CNC mill goes to the next block. The Servo Control then executes the L steps without waiting for start commands. Normally, the L count on the G94 is set to 1 and that step is followed by a step that is run simultaneous with a CNC mill.
G95 End Of Program/Return But More Steps Follow
End a G96 subroutine with a G95 after the last step of the subroutine.
G96 Subroutine Call/Jump
Subroutines allow repetition of a sequence up to 999 times. To call a subroutine, enter G96. After entering 96 move the blinking display 00 preceded by Step# registered to enter the step to jump to. The control jumps to the step called out in the Step# register, when the program reaches the G96 step. The control executes that step and the ones following until a G95 or G99 is found. The program then jumps back to the step following the G96.
A subroutine is repeated by using the loop count of a G96. To end the subroutine, insert either a G95 or G99 after the last step. A subroutine call is not considered a step by itself, since it executes itself and the first step of the subroutine.
NOTE: Nesting is not permitted.
G97 Delay By L Count/10 Seconds
G97 is used to program a pause (dwell) in a program. For example, programming a G97 and setting L = 10 produces a 1 second dwell. G97 does not pulse the CNC relay at step completion.
G98 Circle Division
Circle division is selected with a G98 (or G85 for TRT units). The L defines how many equal parts a circle is divided into. After the L count steps, the unit is in the same position it started from. Circle division is only available in the circular modes (i.e., Parameter 12 = 0, 5, or 6).
G99 End Of Program/Return And End Of Steps
A G99 is the end of the program or steps.
