Axis Servo Motor - Set Grid Offset Parameter - CHC
Service Home How To Procedures Axis Servo Motor - Set Grid Offset Parameter - CHC
Recently Updated Last updated: 02/22/2023
- Jump to Section - 1. Introduction 2. Axis Grid Offset - Video 3. Axis Grid Offset (3 steps) Back to Top
This procedure tells you how to set the parameters for the grid offset for each axis. These parameters set the number of encoder counts necessary to move the axis from the home switch to the motor zero-channel after you press [ZERO RETURN].
Refer to this procedure if you have one of the conditions:
  • A servo motor, a ball screw, or a proximity switch was replaced
  • If you have one of these alarms:
    • AXIS ZERO RETURN MARGIN IS TOO SMALL
    • AXIS ZERO RETURN MARGIN IS TOO LARGE
The following service video shows how to set the Axis Grid Offset on a Classic Haas Control (CHC).
NOTE:  This  service video is for reference only and does not replace the written procedure.
Axis Grid Offset
Set Setting 7, Parameter Lock, to OFF.
Find the parameters for the GRID OFFSET you will change.
Axis X           Y           Z           A           B
Parameter - Grid Offset 125 126 127 128 170
Parameter - Ratio (Steps/Units) 5 19 33 47 155
For example, to set the grid offset for the X Axis, find Parameters 125 (X GRID OFFSET) and 5 (X RATIO [STEPS/UNIT]):
Set the correct GRID OFFSET parameter to 0. For example, for the X Axis, set Parameter 125 to 0.
Push [ZERO RETURN]. Push the letter of the correct axis, for example X. Push [SINGLE].
Push [POSIT].
Calculations to get the grid offset for the correct axis:
Subtract 0.118 from the DIST (distance) TO GO.
EXAMPLE: X-Axis DIST TO GO = 0.1961 [1]
0.1961 - 0.118 = 0.0781
Multiply the result by the value of the RATIO (STEPS/UNITS) parameter.
EXAMPLE: X Ratio (Parameter 5) = 665846 [2]
0.0781 x 665846 = 52002.57
Round the result to (5) digits. EXAMPLE: 52003.
Push [EMERGENCY STOP].
Set the correct GRID OFFSET parameter to the calculated value. For this example, set Parameter 125 to 52003 [3].
Release the [EMERGENCY STOP]. Push [RESET].
If you change the GRID OFFSET for the Z Axis, make sure to adjust Parameter 64, Z TOOL CHANGE OFFSET. For VMCs, refer to one of these procedures:
  • VMC - Side-Mount Tool Changer - Set Parameter 64 - Z-Axis Tool Change Offset
  • VMC - Umbrella Tool Changer - Set Parameter 64 - Z-Axis Tool Change Offset
