Coolant Chiller Installation Instructions - AD0468
Service Home How To Procedures Coolant Chiller - Installation - AD0468
7.1 Coolant Chiller - Installation
Recently Updated Last updated: 07/01/2021
AD0468
Coolant Chiller Installation Video
The following video shows how to install the coolant chiller on VF and ST machines.
Note: This service video is for reference only and does not replace the written procedure.
This procedure will show you how to install the Coolant Chiller option on a VF or ST machine.
Machine Compatibility
  • Next Generation Control
  • 100.19.000.1000 Software Version
  • 93-1000011: COOLANT CHILLER FIELD INSTALL KIT
  • 93-1000490: COOLANT CHILLER FIELD INSTALL KIT ST
For instructions on how to operate the coolant chiller refer to:
Coolant Chiller - Operation
VF Coolant Chiller - Installation
Coolant Filter - Removal
Remove the machine screws [1] that attach the coolant filter to the enclosure panel.
Remove the drain plug [2] and allow the coolant to drain from the filter into the coolant tank and discard the plug [2].
Reinstall the machine screws to prevent coolant leaks and disconnect all the coolant hoses from the coolant filter.
Remove the 1/2 NPT hose barb [1] and assemble the rest of the components as shown.
  1. 1/2 NPT hose barb
  2. 1/2 brass 90 degree fitting
  3. 3/4 brass 90 degree fitting
  4. Wing tip hose barb fitting
  5. Temperature sensor.
VF-1/2/3/4/5
Secure the drill template to the enclosure in the location specified by the diagram. Use 5/16 drill bit to make holes using template.
Note:  For VF-2YT that have a stiffener on back panel use a spacer and longer bolts to mount.
For all models except those stated below, place drill template on right side [4] of the stiffener otherwise for the models stated below place on left side [3].
  • VF-3YT/50
  • VF-5/50XT
  • VF-5/50TR
  • VF-5/50
Align the upper bracket [1] with the upper three holes drilled in the enclosure panel using the template.
Raise the left side window and install the coolant chiller upper bracket [1] onto the enclosure panel using the sealing washers [2] and machine screws [3]. Do not fully tighten the machine screws.  Make sure the position of the upper bracket can still be adjusted by hand.
 Note: For VM-2, VF-2YT and VF-2SSYT equipped with SMTC-50 and built before 01/2020. These machines have a stiffener [4] on the back panel that require a spacers.  Install the spacers [5] (P/N 59-1822) in between the back panel and the upper bracket.  Install the longer screws (P/N 40-1978) and washers (P/N 45-0184).
Use the hooks on the top of the coolant chiller to hang the coolant chiller from the upper bracket and put 2 machine screws in the bottom.
Install the hex nuts [1] onto the upper bracket.
Align the coolant chiller with the lower two holes drilled in the enclosure panel using the template. Install sealing washers [2] and machine screws [3] onto the coolant chiller.
Tighten all the fasteners securing the upper bracket and coolant chiller.
 Note: For the VF-2YT that have a stiffener on the back panel install the spacers (P/N 59-1822) in between the back panel and the coolant chiller.  Use the longer screws (P/N 40-1978) and washers (P/N 45-0184).
VF - Coolant Filter - Installation
VF Machines with Coolant Filter
Install the screws until half of the threads are shown.
Slide the coolant filter assembly [2] onto the machine screws [1] and tighten.
Install hose caps onto all the barb fittings.
Route the coolant hoses as shown.  Secure the coolant hoses to the barb fittings with hose clamps.
If a coolant hose does not reach its barb fitting create a jumper hose using a double sided barb fitting.  Allow each hose some slack so it does not kink.
Route the coolant hose [1] from coolant pump to the filter assembly.
Route the coolant hose [2] from the filter assembly to the heat exchanger.
Route the coolant hose [3] from the waycover washdown to the filter assembly though the cable carriers under the coolant chiller. Secure the waycover washdown hose with a cable clamp [5].
Route the temperature sensor cable [4] along the waycover washdown hose.  Secure it to the waycover washdown hose between the sensor and the cable clamp using a zip tie.
Route the coolant hose [6] from the washdown spray nozzle to the filter assembly.
Route the coolant hose [7] from the flood coolant to the heat exchanger.
VF Machines with a Chip Separator Filter
Install the chip separator filter assembly using the screws [1] and tighten.
VF Machines with Chip Separator Filter
Route the coolant hose [3] from the waycover washdown to the filter assembly though the cable carriers under the coolant chiller. Secure the waycover washdown hose with a cable clamp.
Route the temperature sensor cable [4] along the waycover washdown hose.  Secure it to the waycover washdown hose between the sensor and the cable clamp [6] using a zip tie.
Route the coolant hose [5] from the washdown spray nozzle to the filter assembly.
ST Coolant Chiller - Installation
Secure the drill template to the enclosure in the location specified by the diagram. Make sure the template is flat on the enclosure. Use a 5/16 drill on the top 3 holes on the template. Use a 7/32 drill on the bottom 2 holes on the template. Deburr the holes after drilling.
ST-10/15 [1]
  • X = 2"
  • Y = 11"
ST-20/25/20L/25L/30/35/30L/35L [1]
  • X = 2"
  • Y = 19"
ST-40/45/40L/45L/50/55 [2]
  • X = 4"
  • Y = 60"
Remove the rear panel from the machine.
Install the bracket [1] with the upper three holes drilled in the enclosure panel with the button head screws[2].
Reinstall the rear panel to the machine.
Use the hooks on the top of the coolant chiller to hang the coolant chiller from the upper bracket.
Align the coolant chiller with the lower two holes drilled in the enclosure panel and install the self tapping screws [2].
Disconnect the coolant hose [1] from the coolant pump and connect it to the lower fitting on the coolant chiller.
Connect the hose [2] that was included with the coolant chiller kit to the upper fitting on the coolant chiller and the coolant pump.
Connect the Temperature Sensor [1] to the NPT 3/4M Tee Fitting [2].
ST Coolant Filter - Installation
Machines Chip Filter Chip Separator
ST-20/25/Y 07/13/2024 - 07/19/2024 08/02/2024 - Present
ST-20/25/L/LY 04/19-2024 - 07/31/2024 09/05/2024 - Present
ST-28/Y 07/13/2024 - 07/31/2024 07/31/2024 - Present
ST-28L/Y 04/19/2024 - 07/31/2024 07/31/2024 - Present
ST-30/35/L/LY 06/26/2024 - 09/05/2024 07/31/2024 - Present
ST-30/35/Y 06/08/2023 - 07/19/2024 07/19/2024 - Present
DS-30Y 06/08/2023 - 07/19/2024 07/19/2024 - Present
ST Machines with Coolant Filter Pump
Install as shown, 1/2 of the threads should be engaged.
Slide the coolant filter assembly onto the machine screws and tighten.
Route the temperature sensor cable [3].  Secure it with a cable clamp [4].
Route the coolant hose [6] from the flood coolant to the heat exchanger.
ST Machines with Chip Separator Filter
Route the coolant hose [3] from the washdown spray nozzle to the filter assembly.
Route the temperature sensor cable [4] along the waycover washdown hose with a ziptie.
Route the coolant hose [5] from the flood coolant to the heat exchanger.
Electrical - Installation
Electrical Safety
Caution: When maintenance or repair is performed on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
Push [POWER OFF].
Set the main circuit breaker to the [OFF] position.
Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must be off for at least 5 minutes. If the voltage indicator light is on, do not touch the electrical components. The high voltage in the electrical cabinet can kill you. Some service procedures can be dangerous or life threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about performing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
Install the cabcool/coolant chiller power supply [1] onto the main transformer using the machine screws, lock washers, and washers.
Remove the sheet metal cover [2] from the main transformer.
Remove the red, white, and black power cables from the terminal block .
Install the red, white, and black power cables from the cabcool/coolant chiller power supply onto the terminal block.
Reinstall the removed red, white, and black power cables.
Reinstall the sheet metal cover [2].
Log in to the HBC site to download the latest configuration file.  Install the configuration file.
For instructions on how to operate the coolant chiller. Refer to: Coolant Chiller - Operation.
Power down the machine and set the main circuit breaker to [OFF].
Small VF (not shown):
Route the temperature sensor [2] and power cable [3] through the casting, remove the enclosure panel located below the control cabinet, and route cables through it.
Medium / Large VF (shown):
Remove the enclosure panel [1] located below the control cabinet, remove coolant connector box and route temperature sensor cable [2] and coolant chiller power cable [3] through the back of the coolant connector box and through the base casting and up through the hole in the bottom of the control cabinet.
For all:
Use the provided magnet and cable tie to secure the cables to the enclosure.
Inside the control cabinet route the temperature sensor cable through the cable carriers to I/O PCB plug P44.
Plug the coolant chiller power cable into the labeled outlet on the cabcool / coolant chiller power supply.
Coil any extra length of power or sensor cable under the control cabinet and fasten with a Velcro tie.
Reinstall the enclosure panel [1] for the small VF and reinstall the coolant connector box and enclosure panel [1] for medium/large VF.
ST-10/15/20/25
Route the temperature sensor cable [1] and power cable [2] under the coolant chiller in the cable channel to the control cabinet. Use the provided magnets and cable ties to secure the cables to the enclosure. The control cabinet skirt may need to be removed to route cables into the control cabinet.
Plug the coolant chiller power cable into the labeled outlet on the cabcool/coolant chiller power supply. Coil any extra length of power or sensor cable under the control cabinet.
Coolant Chiller Activation
Turn on the machine.
Login to the HAAS SERVICE PORTAL.
Download the Coolant Chiller option configuration patch files.
Note: The option files will appear on the configuration download page after the Coolant CHiller Kit has been ordered.  If the option does not appear contact the service department.
Load the option configuration patch file to the control.  Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
Test the Coolant Chiller
To test the coolant chiller. Press MDI and then COOLANT to turn on the coolant.
Let it run and navigate to Diagnostic > Gauges and check the coolant temperature on the Gauge page. The max rate of change is 1 degree per 10 minutes of coolant flow.
