Desktop Mill - VFD - Replacement - AD0561
Service Home How To Procedures Desktop Mill - VFD - Replacement - AD0561
Recently Updated Last updated: 05/30/2025
Desktop Mill - Variable Frequency Drive - Replacement
AD0561
Revision A - 5/2025
- Jump to Section - 1. Introduction 2. Replacement (8 steps) Back to Top
This procedure will tell you how to replace the Variable Frequency Drive on a Desktop Mill.
This Procedure Applies to the Following Parts:
  • 93-3321 110V VFD REPLACEMENT KIT DESKTOP MILL
  • 93-3323 VFD REPLACEMENT KIT 220V DESKTOP MILL
  • 93-3237 SERVICE KIT 120VAC VFD DESKTOP MILL
  • 93-3238 SERVICE KIT 220VAC VFD DESKTOP MILL
  • 93-3950 PROGRAMMED VFD 2HP 1PH 120V DTL
  • 93-3949 PROGRAMMED VFD 2HP 1PH 240V DTL
If VFD replacement is needed and the customer has:
  • 69-2120 they will need 93-3321
  • 69-2220 they will need 93-3323
  • 69-2120A they will need 93-3237
  • 69-2220A they will need 93-3238
Replacement
Push [POWER OFF].
Unplug the Desktop Mill.
NOTE: Be sure to unplug BOTH the control pendant and the Desktop Mill power cords, as current runs from the pendant to the mill.
Remove (x9) BCHS 6-32" from the rear panel and remove the panel.
Open the VFD's front cover, and use a screwdriver to carefully disconnect the power cables, ground cables, and remaining input/output wires.
The left image is a Schneider VFD, and the right image is a Delta VFD.
If your machine currently has a Schneider VFD, unscrew the two Philips head screws to remove the VFD.
Delta VFDs are held in place with four screws, one at each corner.
For machines initially built with a Delta VFD:
Some desktop mills built with a Delta VFD do not have a bracket. If this is the case, no bracket is needed.
  • If your machine currently has a Delta 110V VFD, unscrew the four Philips head screws from the bracket to remove the VFD [2].
  • If your machine currently has a Delta 220V VFD, unscrew the two Philips head screws from the bracket to remove [3].
For machines initially built with a Schneider VFD:
Note: If installing a Delta VFD on a machine built initially with a Schneider VFD, a mounting bracket [1] P/N 25-15216 will need to be installed. Before proceeding, this is done with two PPHS 6-32 X 3/8 and washers included in the kit. It is possible that your machine may have the necessary holes to mount the Delta VFD, and the bracket will not be needed.
  • To install a Delta 110V VFD, install four PPHS 6-32 X 3/8 and washers into the mounting holes shown in BLUE [2].
  • To install a Delta 220V VFD, install two PPHS 6-32 X 3/8 and washers into the mounting holes shown in RED [3].
Carefully reinstall the power, ground, and input/output wires according to the reference table.
*Important: For Delta VFDs, the Wht/Brn wire should be put into RB even if the wire is labeled RA. This will reduce the chance of erroneous alarms.
Note: The blue wire may be installed into either DCM port on a Delta VFD.
 Note: Each wire has a label indicating which port it should be connected to on the VFD. The three-letter code in brackets indicates the port on a Schneider VFD, and the three-letter code without brackets indicates the port for a Delta VFD.
Reference Table
Color Function Schneider Delta
Red/Wht Enable LI1 MI1
Red Speed AI1 AV1
Wht/Brn Fault R1A RB*
Brn Common R1C RC
Wht/Blu Common COM ACM
Blu Common COM DCM
Reinstall the rear panel with (9) BCHS 6-32".
Plug in the machine and control the pendant.
Push [POWER ON] and test machine operation.
 NOTE: If the spindle does not start up properly upon first power up, cycle power and try again. If the problem continues, stop and call Haas Customer Service.
