H-5AX HSKA100 Dual-Support - Crashed Spindle Head Correction
Service Home How To Procedures H-5AX HSKA100 Dual-Support - Crashed Spindle Head Correction
- Jump to Section - 1. Introduction 2. Spindle Cartridge Checks (2 steps) 3. Complete an Inspection Report 4. Verify B-Axis Tool Change offset (3 steps) 5. Verify C-Axis Tool Change Offset (3 steps) 6. Complete an Inspection Report 7. B and C-Axis Compensation 8. Set Tool Changer Alignment (2 steps) 9. Calibrate Probe 10. MRZP & Safe Zone Calibration 11. Test Cut 12. Verification Back to Top
Recently Updated Last updated: 04/23/2026
Revision A - 03/2026
This procedure show how to correct the Spindle Head after a crash on HDC-3-5AX machines.
Tools Required:
  • Drawbar Force gauge
  • Depth Micrometer
  • Mag base
  • Indicator
  • T-0190 HSK100A SERVICE SPLIT TOOL
  • HSKA100 Test Arbor
  • 12 x 12 Granite square
  • Cylinder
  • H-5AX test cut
Fill out the checklist below and attach it to the work order.
H-5AX HSKA100 Dual-Support Spindle Head Crash Checklist
Note: Make sure the spindle clamping cone adjustment is completed before adjusting the TRP sensor
  • Bring the spindle to the full Unclamp position, where the Drawbar is forward and the clamping cone is to the maximum Push Out.
  • Use a depth gauge to check that position of the clamping cone in relation to the spindle nose, the value (1).
                                      (13.3 mm +0.1 / -0.0 mm / 0.524 in + .004 / -0.0 in)
  •  If the push out is incorrect, make the adjustment described in the steps below
Assemble the drawbar force gauge according to the manufacturer’s instructions. Put the gauge into the spindle.
  • Take the Setup and CAREFULLY place it into the spindle.
  • Grab the tool from the Adapter Diameter, beware of pinch points.
  • Read the force on the Gauge, the following are force readings allowable:
HSK-A100: 10116 - 13038 lbf (45-58kN)
Complete the machine geometry sections and the C-Axis Parallel to Z-Axis check of the latest inspection report before setting the B and C-Axis Tool Changer Offsets. After the Tool Changer Offsets are set, finish the remaining checks on the inspection report.
The latest inspection report can be found on EA - Alignment Inspection Report - Reference Table through the Dealer-Only Content page.
 Note: This site is available only to Haas Service Techs.
Please refer to the H-5AX Double Yoke Spindle Head - Geometry Guide for further details on how to perform the 5AX inspection report checks.
  Note: The VR Double Yoke machine is shown for illustrative purposes. The same steps will apply to the HDC-3-5AX.
 WARNING: This page may be used as reference for the inspection report but do not make any adjustments before consulting with Haas Service. Adjustments made without consulting Haas Service will void warranty.
Verify the B-Axis Tool Change Offset.
Home the B & C-Axis and place the indicator on the side face of the test arbor.
Find the high spot on the test bar by jogging the Y-Axis. Once the indicator is on the high spot jog the indicator up and down the test bar. The error on the indicator should be no more than 0.0001".
If the error exceeds 0.0001", adjust the B-Axis so that the error on the indicator is no more than 0.0001" and update the B-Axis Tool Change Offset using the steps below.
 Note: If the B-Axis Tool Change Offset is changed, the B and C-Axis compensation table needs to be recalculated. Follow the steps in the H-5AX - VR DOUBLE YOKE - HDC - B/C-AXIS COMPENSATION procedure.
If B-Axis Tool Change Offset needs to be reset:
Use the following instructions to change the B-Axis Tool Change Offset if a service key is not available.
Press [SETTING] and navigate to the rotary tab. Highlight the 4th axis selection [1] and press [ALTER] [2] to set the B-Axis Tool Change Offset [3].
After adjusting the B-Axis Tool Change Offset. Redo the inclination test, sweeping from position [1] to [2]. If the inclination is out of tolerance after adjusting the offset, redo the adjustment portion.
If a service key is available press [DIAGNOSTIC] and navigate to the parameters tab and to the factory tab. Find Parameter 6.078 B-AXIS TOOL CHANGE OFFSET to set the Tool Change Offset by pressing the [B] + [F2] to set the offset to the current position.
After adjusting the Tool Change Offset. Redo the inclination test, sweeping from position [1] to [2]. If the inclination is out of tolerance after adjusting the offset, redo the adjustment portion.
Home the B and C-Axis.
In MDI command the B-Axis to -90°.
Place an indicator on the front face of the test bar at the end of the bar [1] on the high spot. Zero the indicator at this location.
Jog the Z-Axis up so the test bar clears the table and command B = +90°. Jog the table in the Z and X direction to move the indicator to position [2] on the front face of the test bar at the end of the bar on the high spot. The error on the indicator, between positions [1] and [2], should not exceed 0.0005".
If the error is larger than 0.0005", adjust the C-Axis so that the error on the indicator does not exceed 0.0005" between positions [1] and [2].
Once the end of the test bar reads the same error at both B = -90 and B = +90 degrees set the C-Axis Tool Change Offset using the steps below.
 Note: Do not move the Y-Axis during this step.
If C-Axis Tool Change Offset needs to be reset:
Use the following instructions to change the C-Axis Tool Change Offset if a service key is not available.
Press [SETTING] and navigate to the rotary tab. Highlight the 5th axis selection [1] and press [ALTER] to set the C-Axis Tool Change Offset [3].
If a service key is available press [DIAGNOSTIC] and navigate to the parameters tab and to the factory tab. Find Parameter 7.078 C-AXIS TOOL CHANGE OFFSET to set the tool change offset by pressing [C] + [F2] to set the offset to the current position.
Complete the H-5AX section of the latest inspection report.
  Note: MRZP will be completed after the compensations are calculated and the probe is calibrated later in the procedure.
Verify the B and C-Axis Tool Change positions are repeating.
Calculate the compensation values of B=+90, B=-90, C=+90, C=+180, and C=-90 by following the step in the H-5AX - VR DOUBLE YOKE - HDC - B/C-AXIS COMPENSATION procedure.
Take a back up after populating the compensation values and attach it to the machine history.
Verify the HPU pressure is between 650-725 PSI (45-50 bars).
Use T-0190 SMTC HSK100A SERVICE SPLIT TOOL and follow the steps in the SMTC - Double Arm - Alignment - VMC procedure.
Use T-0190 SMTC HSK100A SERVICE SPLIT TOOL and follow the steps in the Side-Mount Tool Changer - HSK - Spindle Orientation Offset - NGC procedure.
Calibrate Probe
Calibrate the probe by following the steps in the WIPS - Probe Calibration - NGC procedure.
Calibrate MRZP and Safe Zone.
Note: Software 100.24.000.1000 combines the MRZP and Safe Zone into one program.
  Important: The spindle probe must be calibrated before doing this procedure. This makes sure the accuracy of the probe to the machine position is correct. Refer to the Next Generation Control - Probe Calibration (VPS) procedure.
Test Cut
Complete the H-5AX test cut procedure.
Adjust the MRZP values as needed.
Verification
Run the customers part to see how the machine performs.
