Haas Shop Lift - Installation - AD0522
Service Home How To Procedures Haas Shop Lift - Installation - AD0522
3.1 Haas Shop Lift - Installation
Recently Updated Last updated: 02/12/2021
AD0522
This procedure outlines how to put the Haas Shop Lift together.
Warning: The max lifting capacity is 1000lbs.
This procedure applies to the following kit:
  • 93-1000577 - HAAS SHOP LIFT
Attach the casters to the base using the bolts, hex nuts, and washers as shown, make sure to place the washer on top of the base.
Note: If the caster wheels are already attached, then move the washers from the bottom to the top of the base as shown.
Attach the mast to the base as shown in [1], use the bolts and washers that do not have hex nuts attached to them.
Note: When attaching the mast hardware make sure to attach the hardware loosely, these will be tightened in a later step.
Attach the pump arm if it is not already to the mast as shown in [2]; use a bolt, washer, and hex nut provided.
Attach the pump arm holder if it is not already to the mast as shown in [3]; use the bolts provided.
Attach the rear supports as shown. Use a bolt, washer, and hex nut at the top and (2) at the bottom.
Do not comepletely tighten the hardware until all hardware is attached, once the harware is attached go back and tighten the bolts for the mast and rear supports.
Note: The shop lift may need to turned on its side to attach the bottom hardware.
Attach the boom arm [1] as shown using a bolt, washer, and hex nut [2].
Attach the hook [3] at the front of the boom arm using a bolt, washer, and hex nut [4].
Attaching Pump and Pump Arm
Follow the steps below if the pump and pump arm did not come attached.
Take the component that links the pump arm to the pump [1] and attach it to the pump arm [2] as shown with the retaining clip [3].
Pull the pump arm down so that the linking component [1] is outside of the mast and attach it to the cylinder key [2] as shown with the retaining clip [3].
Note: If the cylinder key [2] falls out of the pump during this step or any other, make sure to purge the cylinder of air by following the Purge Air Instructions below before operation.
