Higen Motors - Installation - AD0643
Service Home How To Procedures Higen Motors - Installation - AD0643
Recently Updated Last updated: 09/22/2023
Higen Motors - Installation - CHC
AD0643
- Jump to Section - 1. Introduction 2. 1.5HP Motors 3. 5HP 100V Motors 4. 5HP 200V Motors 5. 10HP Motors 6. 20HP Motors 7. 30HP Motors Back to Top
This procedure should be referenced when replacing a spindle motor on a CHC machine with a Higen brand spindle motor.
Two parameters will need to changed, Parameter 180 and Parameter 181. Refer to the applicable table below for the new values.
1.5HP Motors
The table below applies to Higen Motor PN 62-0149 on CM and OM machines.
This applies to the following kits:
          93-20021B, 93-30-11585A, 93-30-13658, 93-30-30229C
Change parameters 180 and 181 to the following values:
Spindle Speed Parameter Value
30k 180 144
181 50
50k 180 180
181 50
5HP 100V Motors
The following table applies to Higen Motors PN 62-0134 on DT/DM machines.
          93-30-13543, 93-30-13544, 93-3728, 93-3729, 93-3730, 93-3731, 93-3732, 93-3738, 93-3739
Machine Type Parameter Value
DT 10k spindle 180 322
181 60
DT 12k/15k spindle 180 250
181 60
5HP 200V Motors
The table below applies to Higen Motor PN 62-0133 on MM/GR/SMM/TM/TL machines.
          93-0341C, 93-0925A, 93-1389A, 93-30-11518A, 93-30-13526, 93-30-13527, 93-30-13661, 93-30-13662, 93-30-13663, 93-30-13664, 93-30-13665, 93-30-13666, 93-30-1674E, 93-30-3708, 93-30-3708A, 93-30-8915, 93-3265A, 93-3266A, 93-3716, 93-3717, 93-3718, 93-3719, 93-3720, 93-3721, 93-3722, 93-3723, 93-3724
TM/MM 6k spindle 180 225
181 45
TM/MM 10k spindle 180 281
181 45
TL 180 500*(Parameter183/26667)
Note: See example below
181 45
GR/SMM 180 180*(Parameter183/26667)
181 30
Example for Parameter 180:
Parameter 180 = 500 * (Parameter 183 / 26667)
So if Parameter 183 on the machine = 25000, Parameter 180 for Higen = 468.74, so round up to 469.
10HP Motors
The following table applies to Higen Motor PN 62-0136 on Lathe and VF. machines.
          93-30-13377
Vector Drive Type Parameter Value
20HP Vector Drive 180 175 * (Parameter183 / 26667)
181 30
40HP Vector Drive 180 115 * (Parameter183 / 26667)
181 30
Parameter 180 = 115 * (Parameter 183 / 26667)
So if Parameter 183 on the machine = 25000, Parameter 180 for Higen = 107.81, so round up to 108.
20HP Motors
The table below applies to Higen Motor PN 62-0146 on 50T Gearboxes and HS machines.
          93-30-11806C, 93-30-13611, 93-30-3602A, 93-30-9743B, 93-30-9744C
Parameter  Value
Parameter 180 180 * (Parameter183 / 26667)
Parameter 181 30
Parameter 180 = 180 * (Parameter 183 / 26667)
So if Parameter 183 on the machine = 25000, Parameter 180 for Higen = 168.74, so round up to 169.
30HP Motors
The following table applies to Higen Motor PN 93-62-0151 on Lathe XP Options.
          93-3734, 93-3735, 93-30-13780
Parameter  Value
Parameter 180 75
Parameter 181 45
