HPC - TSC 300 - Auxiliary Coolant Filter - Standard Coolant Pump Fittings - Installation - AD0103
Service Home How To Procedures HPC - TSC 300 - Auxiliary Coolant Filter - Standard Coolant Pump Fittings - Installation - AD0103
Recently Updated Last updated: 01/17/2019
AD0103
Applies to machines built from: November, 2013 to June, 2015
- Jump to Section - 1. Introduction 2. Prerequisites 3. HPC/TSC 300 - Auxiliary Coolant Filter - Standard Coolant Pump Fittings - Installation (6 steps) Back to Top
If you have all the follow conditions perform this procedure:
  1. You install an auxiliary coolant filter (AF) system.
  2. The machine has Through-Spindle Coolant (TCS) or High-Pressure Coolant (HPC) 300.
  3. The machine was made before June, 2015.
  • Mills receive a check-valve. This procedure tells you how to install the fittings for each of these conditions:
    • The standard pump body has a 90-degree outlet [1].
    • The standard pump base has an elbow fitting [2] at the outlet.
  • Lathes do not receive a check valve. This procedure tells you how to install the fittings for each of these conditions:
    • The standard pump body has a 90-degree outlet [3].
    • The standard pump base has an elbow fitting [4] at the outlet.
Prerequisites
  • If a coolant hose is connected to the pump, disconnect it.
  • In the steps that follow, apply thread sealant to all threaded surfaces. Do not apply sealant to the hose adapter in Step 5.
If the pump has an elbow fitting at the outlet port, go to step 3.
If the pump body has a 90-degree outlet [1], remove the plug [2] from the outlet port.
Install the 1/4" elbow fitting [3].
If the machine is a lathe, go to Step 5.
If the machine is a mill, remove the hose adapter [4].
If the machine is a mill:
  • Install the nipple [1].
  • Install the check valve [2].
 Caution: Make sure that the arrow on the check valve points up.
  • Install the hose adapter [3] removed in Step 1.
Go to Step 5.
If the pump has an elbow fitting [2] at the outlet port:
  • Remove the hose adapter [1].
  • Install the tee fitting [3] to the elbow fitting.
  • Install the 1/4" elbow fitting [5] to the tee fitting
If the machine is a mill, perform Step 4.
If the machine is a lathe, install the hose adapter [4] to the tee fitting.
Go to Step 5.
 Caution: Make sure the arrow on the check valve points up.
  • Install the hose adapter [3] removed in Step 3.
Perform this step for mills and lathes.
Find the 1/4" hose [1] from the auxiliary coolant filter. The illustration shows the two possible installations:
  • the 1/4" elbow fitting [2] on a pump with a 90-degree outlet
  • the 1/4" elbow fitting [3] on a pump with an elbow fitting at the outlet
Find the coolant hose [1] from the supply port for the standard coolant. Connect the hose to the pump. The illustration shows the two possible connections:
  • the pump with a 90-degree outlet [2]
  • the pump with an elbow fitting [3] at the outlet
 Caution: Do not apply thread sealant to the hose adapter. This makes the hose difficult to remove.
