IPFDM PCB - Replacement - AD0915
Service Home How To Procedures IPFDM PCB - Replacement - AD0915
33.1 IPFDM PCB - Replacement
Recently Updated Last updated: 10/31/2025
AD0915
Revision A - 10/2025
This procedure shows how to replace the IPFDM PCB inside the electrical cabinet.
This procedure applies to the following service kits:
  • 93-5777 - IPFDM ASSEMBLY
  • 93-5780 - IPFDM ASSEMBLY
The IPFDM is only applicable to 19-inch monitor machines. 15-inch monitor machines do not use the IPFDM.
Note: 93-5777 can only be used to replace 32-2110. 93-5780 can be used to replace 32-2110 and 32-2110A.
Remove IPFDM PCB
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Make sure machine is powered OFF. Flip the main breaker to the OFF position.
To access the IPFDM PCB, remove the safety cover [1] from the stack of PCB's in the upper left side of the electrical cabinet.
Then remove the standoffs [2] holding the IPFDM in position.
Mark all the cables connected to the IPFDM so that they can be reinstalled in the correct position on the replacement PCB.
Remove the cables connected to the PCB [2].
Disconnect the battery [2] from the IPFDM PCB before putting away the board.
Remove the IPFDM PCB from the standoffs.
Continue to the next section for installing the replacement IPFDM.
Install Replacement IPFDM Assembly
Install the replacement IPFDM assembly [1] onto the standoffs.
Fasten the 4 standoffs [2] that were removed in the previous section. These will hold the IPFDM assembly in position.
Note: Keep the IPFDM assembly in the orientation that is shown in the image.
Connect all the cables into the correct ports on the IPFDM. The cables have labels for what ports on the IPFDM they connect to:
  • J2 - Cable from Main Processor PCB
  • J6 - Cable from PSUP and K1 Contactor
  • J4 - Cable from the pendent LCD display
  • J1 - Cable from LVPS in control cabinet
IMPORTANT: Make sure to connect the battery [1] to the connector on the IPFDM PCB. The battery is not connected during assembly for shipping. The battery needs to be connected at installation of the replacement board.
Once all the cables and the battery is connected, power ON the Haas machine.
Verify the machine functions and there are no issues. Refer to the IPFDM - Troubleshooting Guide if there are any issues that occur after replacing the PCB.
Once the machine is running as it should, reinstall the protective cover on the standoffs to protect the IPFDM assembly.
