Coolant Level Float Sensor - CHC - Installation - AD0025
Service Home How To Procedures Coolant Level Float Sensor - CHC - Installation - AD0025
Coolant Level Float Sensor - Installation - CHC
AD0025
Applies to machines built from: December, 2012
- Jump to Section - 1. Introduction 2. Coolant Level Float Installation (3 steps) Back to Top
This procedure tells you how to install the Coolant Float Sensor into the coolant tank.
Do this procedure for these tanks:
  1. 55-gallon tank
  2. 95-gallon tank
The machine software requirements:
  • CHC: Mill software version 11.17 or higher, or lathe software version 4.21 or higher.
This procedure applies to the following P/N:
  • 93-2257        CLNT LVL SNSR FIELD ADAPT KIT
  • 93-2876        FIELD INSTALL KIT CPK-MM EDU/UK
  • 93-CS_GR     FIELD INSTALL CS-GR
  • 93-1000353  COOLANT OPTION W/AUGER GM-2
  • 93-1000354  COOLANT OPTION GR
  • 93-1000396  COOLANT OPTION KIT GM-2 3AX
  • 93-1000397  COOLANT OPTION KIT GM-2 5AX
Push [POWER OFF].
For a tank lid with dimples [4]:
  • Put the float [5] from the coolant float assembly [A] into the tank.
  • Align the housing dimples [3] with the dimples on the tank lid [4].
  • Push the housing [1] down onto the side of the tank.
  • Put the cable [2] from the assembly to the coolant electrical connection panel.
For a tank lid with a cutout [8]:
  • Put the float [9] from coolant float assembly [A] into the tank.
  • Push the housing [6] down onto the cutout [8] of the tank lid.
  • Put the cable [7] from the assembly to the electrical connection panel.
Note: The location of the electrical connector panel changes with the machine type.
For a machine with a rear-panel M12 cable:
  • Connect the cable [1] from the assembly [A] to the rear-panel coolant sensor[C].
For a machine with a rear-panel Amphenol cable or RJ-12 cable:
  1. Disconnect the rear-panel Amphenol cable (or RJ-12 cable) from P22 on the Maincon.
  2. Remove the rear-panel Amphenol cable (or RJ-12 cable) from the rear of the electrical connection panel.
  3. Put the o-ring [2] from the old M12 cable on the sensor cable [C] (M12 cable).
  4. Place a WASHER [B] onto the sensor cable.
  5. Attach the sensor cable to the rear of the electrical connection panel. Use a washer [B] and the nut [3].
  6. Connect the sensor cable to P22 on the Maincon.
  7. Connect the cable [1] from the assembly [A] to the sensor cable.
Push [POWER ON].
Push [PARAMETER/DIAGNOSTICS] until the parameters show. Go to the SYSTEM tab.
Push [E-STOP].
Make sure the values for Parameters 603 and 604 are correct. Refer to the tables below for the correct values of parameters.
To make sure the coolant tank float operates correctly, do these steps:
  1. Push [MEMORY] on the pendant.
  2. The upper-right corner of the screen shows a coolant level arrow. When the float goes up, the arrow goes up [1]. When the float goes down, the arrow goes down [2].
Mill Machine Model Parameter 603 Value
(CHC)
Parameter 604 Value
(CHC)
DM, DT, EC, ES, GR, HS, UMC, VF, VR, VS 39000 49000
MM, SMM 41500 49000
Lathe Machine Model Parameter 603 Value
(CHC)
Parameter 604 Value
(CHC)
GT-10, GT-20, SL-10, TL-1 through TL-3 0 0
SL‑40, ST‑10 through ST-50, DS‑30 45000 49000
