TL-1/2 - 10" Manual 3-Jaw Chuck (2.5K Max RPM) Installation - AD0580
Service Home How To Procedures TL-1/2 - 10" Manual 3-Jaw Chuck (2.5K Max RPM) Installation - AD0580
Recently Updated Last updated: 11/08/2021
TL-1/2 - 10" Manual 3-Jaw Chuck (2.5K Max RPM) - Installation
AD0580
- Jump to Section - 1. Introduction (2 steps) 2. Safety 3. Installation (6 steps) Back to Top
This procedure will explain how to install the 10" Manual 3 -Jaw Chuck on a TL-1/2.
Please read the safety disclaimer in the following section before installing.
You may use the installation video as a reference for installing the manual chuck.
Safety
Safety Warning:  Proper installation of this device is needed to comply with safe operation of the machine. Installer must follow installation instructions.
Do not run the machine over 2500RPM with this chuck installed.
Apply grease through the grease port on the front of the chuck. Different chuck makers will have different ports, use the appropriate grease nozzle.
Open the jaws until 4 teeth are exposed, apply grease on the mating surface on the back of the jaw.
NOTE: if the chuck binds while greasing contact Haas Service.
Apply a light coat of rust inhibitor on the spindle nose
Install the chuck adapter plate if required, indicate the adapter plate this is NTE 0.0005” TIR
Safely lift the chuck using an eye bolt, there is a lifting hole that can be used. Use the proper lifting equipment to do so.
Install the chuck with the supplied hardware, but do not torque the bolts down yet.
Indicate the chuck body, this is NTE 0.0005”.
After indicating the chuck torque the fasteners down follow the HAAS TORQUE SPECIFICATION for reference.
NOTE: To torque the bolts down use a crescent wrench to hold on a jaw of the chuck to counter the rotation while torquing.
