Umbrella Tool Changer - Pocket - Replacement
Service Home How To Procedures Umbrella Tool Changer - Pocket - Replacement
3.3 Umbrella Tool Changer - Pocket - Replacement
Recently Updated Last updated: 08/12/2025
Applies to machines built from: January, 1989
Revision A 08/2025
Pocket - Replacement - Introduction
The illustrations in this procedure show a BT-style tool-changer. The instructions are the same for a CT-style tool-changer.
This procedure is applicable to more than one kit. Only one of the kits is necessary.
  • 93-2366 POCKET REPLACEMENT, BT UMBRELLA 32 STATION
  • 93-2371 POCKET REPLACEMENT, CT UMBRELLA 10 STATION (SMM & GR ONLY)
  • 93-2370 POCKET REPLACEMENT, BT UMBRELLA 10 STATION (SMM & GR ONLY)
  • 93-2373 POCKET REPLACEMENT, CT UMBRELLA 20 STATION (NOT GR)
  • 93-2372 POCKET REPLACEMENT, BT UMBRELLA 20 STATION (NOT GR)
  • 93-2369 POCKET REPLACEMENT, CT UMBRELLA 20 STATION (GR ONLY)
  • 93-2368 POCKET REPLACEMENT, BT UMBRELLA 20 STATION (GR ONLY)
  • 93-2374 POCKET REPLACEMENT, BT UMBRELLA 10 STATION (NOT SMM)
  • 93-2367 POCKET REPLACEMENT, CT UMBRELLA 32 STATION
  • 93-2375 POCKET REPLACEMENT, CT UMBRELLA 10 STATION (NOT SMM OR GR)
Remove all tools from the tool changer. Put wooden blocks on the table. Put a bottle jack on the wooden blocks.
Jog the table below the center of the carousel plate.
Support the carousel plate with the bottle jack.
Push [POWER OFF].
Remove the (6) SHCS from the carousel plate. With a second person remove the carousel plate.
Use your hand to push the station door [1] fully in to make sure it moves freely. If it does not move freely, clean the chips from the door and the door track.
Use a straightedge on the extractor fork [2] to see if it is bent.
Remove the screws [3] that attach the damaged fork assembly to the carousel plate. Remove the assembly as shown. Replace all damaged parts.
Apply a medium-strength thread-lock compound (for example, blue Loctite®) to the threads on the fork assembly screws [3]. Apply Mobil SHC grease to the thru-holes of the replacement assembly.
Install the replacement assembly. Make sure that the beveled side of the washer [4] is against the extractor key (BT, shown) or the fork bushing (CT). Torque the screws to 7 ft-lb (9.5 Nm).
Put a piece of tape [1] on the carousel at pocket 1. Remove the pocket number ring [2].
Remove the sliding panel cover [3], compression spring [4], rivet [5], and sliding panel [6]. Replace all damaged parts. Clean all debris from the pocket.
Apply Mobil SHC-460 grease to the new compression spring. Put the 3/32" rivet into the end of the compression spring. Install the new compression spring [4] and new sliding panel [6]. Install the new sliding panel cover [7] while you push the end of the spring [8] under the panel.
Torque the (2) 10-32 SHCS [9] to 20 in-lb (2.26 Nm).
Apply medium-strength thread-lock compound (for example, blue Loctite®) to the (2) 10-32 flat head cap screws (FHCS) [10]. Install the (2) FHCS [10] and torque to 20 in-lb (2.26 Nm). Make sure the sliding panel [6] moves freely.
Install the pocket number ring [2]. Make sure the number 1 on the number ring aligns with the tape [1] on pocket 1 of the umbrella tool changer.
