VF-6/7/8/9/10/11/12/YT - Way Cover - Replacement - AD0828
Service Home How To Procedures VF-6/7/8/9/10/11/12/YT - Way Cover - Replacement - AD0828
Recently Updated Last updated: 04/23/2025
VF - 6/7/8/9/10/11/12/YT - Way Cover - Replacement
AD0828
Revision B - 4/2025
- Jump to Section - 1. Introduction 2. Replacement (5 steps) Back to Top
This procedure demonstrates how to replace the X-Y way covers on large VF machines. To replace the way covers, you must order the correct kit. Go to the Way Cover - Troubleshooting Guide to troubleshoot the way covers.
NOTE: This procedure applies to the X- or Y-Axis way covers. The images in this procedure are shown on the X-Axis way cover.
This document applies to the following service kits:
  • 93-4842 WAYCVR TELES SS X-AXIS VF-7/9
    NOTE: If currently using galvanneal waycover (30-12190A/B/C/D) and ordering this kit, please order a quantity of four saddle chip guards (25-17301). Replace the existing chip guards with the new version to prevent potential clearance issues with the updated waycover.
  • 93-4843 WAYCVR TELES SS FRNT Y VF-6/7/10/12
  • 93-4844 WAYCVR TELES SS FRNT Y VF-8/9/11/14
  • 93-4845 WAYCVR TELES SS X-AXIS VF-6/8,EC
  • 93-4846 WAYCVR TELES SS X-AXIS VF-10/11
  • 93-4847 WAYCVR TELES SS X-AXIS VF-12/14
  • 93-4848 WAYCVR TELES SS REAR Y-AX LRG VF
 NOTE: This service video is for reference only and does not replace the written procedure.
Replacement
Unbolt old way cover and remove. Remove old gaskets [1]. Remove chips and debris from linear guides. Apply a fresh coat of grease to linear guides.
Install gaskets in their proper location:
  • X-axis gaskets should be installed under the table [1].
  • Front Y-axis gaskets should be installed on the saddle cover [2] .
  • Rear Y-axis gaskets should be installed on the column [3].
Align gaskets to way cover so that holes align as closely as possible.
Place way cover on linear rails. Bolt way cover in place, starting with the end further from the table. Expand the way cover by hand along the guide rails to reach the table. Bolt way cover to table. Leave bolts slightly loose.
 Slowly move table across the full axis travel. Listen for grinding or sounds of impact from the way cover. If these sounds are present, open the way cover and slowly move it along the rails, looking for places where impacts may occur.
Tighten down way cover bolts. Lightly spray a multi-purpose lubricant on the tops and sides of the new way cover panels.
Run way cover back and forth across the full extent of axis travel several times to break it in.
