VMC - Ballscrew - Backlash Test - NGC
Service Home How To Procedures VMC - Ballscrew - Backlash Test - NGC
Recently Updated Last updated: 10/25/2022
- Jump to Section - 1. Introduction 2. X-Axis Ballscrew (3 steps) 3. Y-Axis Ballscrew (3 steps) 4. Z-Axis Ballscrew (3 steps) Back to Top
This procedure tells you how to do a test for axis backlash on the X, Y and Z axes of a vertical mill.
Prerequisites:
Push [POWER ON].
Jog each axis to the center of its range of travel.
Tools Required:
  • Dial indicator that can measure 0.0001" (0.003 mm)
X-Axis Ballscrew
Put the dial indicator so that it touches the side of the spindle housing.
Push [X.]
Push [HAND JOG].
Push [.001/1]..
Jog the X-Axis until the dial shows approximately 0.015" (0.38 mm).
Set the indicator dial to 0.
Push [POSITION].
Push [ORIGIN].
In the display, the X value for OPERATOR shows 0.
Jog the X Axis 0.010" (0.25 mm) in the positive (+) direction.
Jog the X Axis 0.010" (0.25 mm) in the negative (-) direction.
Record the difference between these two values:
  • the indicator value
  • the X-Axis position on the control
If the difference is more than 0.0002" (0.005 mm), the backlash is too large.
Caution: Before you do the manual backlash test, make sure the machine is not in an alarm condition: Release [EMERGENCY STOP], and push [RESET] to stop each alarm.
Do a manual test of the backlash as follows:
  1. With your hands, push on the right side of the table.
  2. Set the indicator to 0.
  3. With your hands, push on the left side of the table.
If the indicator shows more than 0.0002" (0.005 mm), the backlash is too large.
Y-Axis Ballscrew
Put the dial indicator so that it touches the front of the spindle housing.
Push [Y].
Push [HAND JOG].
Push [.001/1.].
Jog the Y Axis until the dial shows approximately 0.015" (0.38 mm).
Push [POSITION].
Push [ORIGIN].
In the display, the Y value for OPERATOR shows 0.
Jog the Y Axis 0.010" (0.25 mm) in the positive (+) direction.
Jog the Y Axis 0.010" (0.25 mm) in the negative (-) direction.
  • the Y-Axis position on the control
  1. With your hands, push on the front of the table.
  3. With your hands, push on the back of the table.
Z-Axis Ballscrew
Put the dial indicator so that it touches the face of the spindle cap.
Push [Z].
Push [HAND JOG].
Push [.001/1.].
Jog the Z Axis until the dial shows approximately 0.015" (0.38 mm).
Push [POSITION].
Push [ORIGIN].
In the display, the Z value for OPERATOR shows 0.
Push [.001/1.].
Jog the Z Axis 0.010" (0.25 mm) in the positive (+) direction.
Jog the Z Axis 0.010" (0.25 mm) in the negative (-) direction.
  • the Z-Axis position on the control
