VMC 50T - Non-Contact Encoder Brace - Installation - AD0655
Service Home How To Procedures VMC 50T - Non-Contact Encoder Brace - Installation - AD0655
Recently Updated Last updated: 04/19/2023
AD0655
- Jump to Section - 1. Introduction 2. Replacement (6 steps) 3. Test (3 steps) Back to Top
This procedure shows you how to install a brace for the Non-Contact Encoder on 50T VMC.
Parts Required:
  • 93-3592: NCE Brace 50T Service Kit
Machine Requirements:
  • VMC 50T build before 11/01/2022
NOTE: Vertical machines built after 11/01/2022 have the non-contact encoder brace already built in.
Replacement
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Remove the spindle-head cover panels.
If the machine has through-spindle coolant (TSC), remove the TSC Union assembly. Refer to 50 TAPER - TSC - COMPENSATING UNION AND THREADLESS TRANSFER TUBE - REPLACEMENT
Remove the TRP assembly [1]. Refer to VMC - 50-TAPER - TOOL RELEASE PISTON - REPLACEMENT for more information.
 NOTE: The gearbox assembly has been removed in the following illustrations for clarity.
When facing the front of the machine, measure the dimension [A] from the front edge of the heat shield and [B] from the outside edge of the heat shield.
Next, measure the same dimension [A] and dimension [C] from the outside edge of the heat shield.
  • A - 12.5" (31.75 cm)
  • B - 1" (2.54 cm)
  • C - 1.75" (4.445 cm)
Cut the holes [D] and [E]:
  • D - 0.2" (0.508 cm)
  • E - 0.2" (0.508 cm)
Repeat on other heat sheild [1].
NOTE: Ignore this step if heat shield holes [D] and [E] are already cut out.
NOTE: Make sure spindle drive belt tension is within tolerance before install. Refer to SPINDLE DRIVE BELT - TENSION ADJUSTMENT - GATES SONIC METER - MILL for more information.
Remove (2x) bolts [1] from read head mount [2].
Attach NCE read head brace [3]. Loosely reinstall (2x) bolts [1] connecting the brace to the read head mount.
Install (4x) bolts [4] connecting the brace to both heat shield plates.
Check the air gap between the encoder read-head [1] and ring [3] by putting a 0.3 mm plastic shim [2] through.
Push the encoder read-head toward the encoder ring as needed.
Make sure there is a uniform air gap [4] between the encoder read-head and the encoder ring.
Tighten the (2x) screws [5] for the encoder read-head. Remove the shim.
Install the tool release piston (TRP) assembly [1]. Hand-tighten the screws.
If the machine has through-spindle coolant (TSC), install the TSC union. Connect the TSC hose.
Test
Operate the spindle at 25% [1], 50% [2], and 100% [3] of the maximum speed.
 NOTE: In this example the maximum speed is 7500 RPM.
To make sure the encoder operates correctly, check the Spindle Orientation. Refer to SIDE-MOUNT TOOL CHANGER - SPINDLE ORIENTATION OFFSET - NGC for more information.
 Push [COOLANT] to start the TSC.
Correct operation is as follows:
  1. Coolant flows correctly from the TSC tool holder [1].
  2. A few drops flow from the vacuum-generator hose [2].
Push [RESET].
Make sure there are no leaks in the air hoses and coolant hoses.
