115V LED - Work Light - Troubleshooting Guide - NGC - TG0163
Service Home 115V LED - Work Light - Troubleshooting Guide - NGC - TG0163
Jump to Section Back to Top
21.2 - 115V LED - Table Work Light - Installation
Recently Updated Last updated: 11/17/2025
TG0163
Revision C - 11/2025
Standard work lights are either:
  • 120VAC LED 20-Watt lamps
  • 120VAC LED 30-Watt lamps
  • 120VAC LED 50-Watt lamps
The light does not power on. Problem with the GFCI circuit/receptacle.
If the machine has a GFCI, check if the GFCI is tripped.
If the receptacle needs to be replaced, order the following part number:
  • For machines with 120VAC LED lamps: 74-1807
Problem with the LED assembly. Check the light for damage. Check for 120 VAC at the fixture connector. It must be replaced if the voltage is correct and the LED does not work. If the LED is flickering on and off, re-seat the connections. If flickering continues, replace the LED assembly.
Problem with the worklight or HIL momentary button. Go to the Diagnostics / Keyboard I/O page and toggle the button. Check the switch operation with an Ohm meter to see if the bit does not toggle in Diagnostics.
The cable from the HIL momentary button to the SKBIF is incorrectly wired. See the HIL Button Cable Incorrectly Wired section for additional details.
The light flickers. Problem with the LED assembly. Check the light for damage. Check for 120 VAC at the fixture connector. If the voltage is correct and the LED does not work, it must be replaced. If the LED is flickering on and off, re-seat the connections. If flickering continues, replace the LED assembly.
Alarm 552  TRIPPED CIRCUIT BREAKER The incorrect GFCI was installed If a machine has a 120V Worklights or HIL, ensure the outlet is a GFCI.
Tripped Breaker/GFI Plug
Corrective Action:
  • Check if CB2 (NGC) on the PDIST PCB has been tripped. If necessary, reset the circuit breaker.
  • Disconnect anything connected to the GFCI receptacle. Push the [RESET] button on the GFCI receptacle. Measure the voltage at the plug. When the [RESET] button is fully engaged, the voltage must measure 120 VAC.
  • If the [RESET] button does not fully engage, disconnect the light cable:
    • Work light: I/O P18-21 (NGC)
    • HIL: I/O PCB P22 (NGC)
  • Push the [RESET] button on the GFCI receptacle again.
    • The GFI plug works correctly if the [RESET] button fully engages and you have 120 VAC. Check the cable and fixtures to find the cause of the short in the light circuit.
    • If the [RESET] button does not fully engage, the GFCI receptacle is defective. Replace the GFCI receptacle.
  • After you replace the GFCI, if there is still no voltage, go to
    • Power Distribution PCB - Troubleshooting Guide (Next Generation Control)
Electrical Diagram
115VAC Worklight LED diagram
