UMC-400
  1. Vertical Mills
  2. Universal Machines
  3. UMC-400
UMC-400
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
5-Axis CNC Vertical Machining Center with 17" x 11" x 13" travels
The UMC-400 has a compact footprint and generous travels that make it the perfect fit for smaller shops, or shops doing 5-axis small-part machining.
Using the proven design elements of our existing UMCs, the UMC-400 is sure to be a great performer. Standard features include an 8100-rpm 40-taper spindle and a 30+1 side-mount tool changer. All this fits into a compact 7 ft x 7 ft (2.1 x 2.1 meter). That’s 25% smaller than the ever-popular UMC-500.
  • 5-axis simultaneous machining
  • Powerful inline direct-drive spindle
  • 30+1 side-mount tool changer
  • Includes Wireless Intuitive Probing System
See Available Stock
Current Lead Time
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
UMC-400 SERIES
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Machine Info
    Travels S.A.E METRIC
    X Axis 17.00 in 432 mm
    Y Axis 11.00 in 279 mm
    Z Axis 13.00 in 330 mm
    Spindle Nose to Platter (~ max) 17.0 in 432 mm
    Spindle Nose to Platter (~ min) 4.0 in 102 mm
    Trunnion S.A.E METRIC
    Platter Diameter 9.10 in 230 mm
    Max Weight on Platter 100 lb 45.4 kg
    Spindle S.A.E METRIC
    Max Rating 15.0 hp 11.2 kW
    Max Speed 8100 rpm 8100 rpm
    Max Torque 46.0 ft-lbf @ 1700 rpm 62.0 Nm @ 1700 rpm
    Taper CT or BT 40 CT or BT 40
    Bearing Lubrication Air / Oil Injection Air / Oil Injection
    Cooling Air Cooled Air Cooled
    B Axis - Tilt S.A.E METRIC
    Travel 120 ° to 45- ° 120 ° to 45- °
    Max Speed 80 °/sec 80 °/sec
    Torque (Continuous) 300 ft-lbf 407 Nm
    Brake Torque 425 ft-lbf 576 Nm
    C Axis - Rotation S.A.E METRIC
    Travel 360 ° 360 °
    Max Speed 100 °/sec 100 °/sec
    Torque (Continuous) 210 ft-lbf 285 Nm
    Brake Torque 200 ft-lbf 271 Nm
    Max Part Swing 14.5 in 368 mm
    Feedrates S.A.E METRIC
    Max Cutting 650 ipm 16.5 m/min
    Rapids on X 900 ipm 22.9 m/min
    Rapids on Y 900 ipm 22.9 m/min
    Rapids on Z 900 ipm 22.9 m/min
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 30+1 30+1
    Max Tool Diameter (full)** 2.5 in 64 mm
    Max Tool Diameter, Large (adjacent empty)** 5.0 in 127 mm
    Max Tool Length (from gage line) 7.00 in 178 mm
    Tool-to-Tool (avg) 2.80 s 2.80 s
    Chip-to-Chip (avg) 3.60 s 3.60 s
    General S.A.E METRIC
    Coolant Capacity 45 gal 170 L
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 8100 rpm 8100 rpm
    Spindle Power 15.0 hp 11.2 kW
    Domestic Pallet 102.0 in x 91.5 in x 100.0 in 259 cm x 232 cm x 254 cm
    Export Pallet 102.0 in x 91.5 in x 100.0 in 259 cm x 232 cm x 254 cm
    Weight 7520 lb 3411.0 kg
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    AVAILABLE OPTIONS
    RELATED PRODUCTS
    Standard Features
    • 8100-rpm Spindle
    • 30+1 Side-Mount Tool Changer
    • Wireless Intuitive Probing System
    • Variable Flow Coolant
    • 45-Gallon Coolant Tank
    • Chip Tray Filter Kit
    • Chip Auger, Front Discharge
    • Control Widescreen Monitor
    • Large Remote Jog Handle with Touchscreen Display
    • Ethernet Interface
    • CNC Control Cabinet Cooler
    • Power Surge Protection
    • Second Home Position
    • Advanced Tool Management
    • Media Display M-Code; M130
    • Safe Run
    • HaasDrop
    • Dynamic Work Offsets and Tool Center Point Control
    • Rigid Tapping
    • ECO Mode
    • Convenience Package
    • Phone Charging Stand
    • 230 mm Platter
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    • Installation Guide
    • Layout Drawing
    • Torque Chart
    • Operator’s Manual
    UMC COMPARISON – Work Envelope ≠ Machine Travels
    In 5-axis machining, your part and workholding must be able to rotate and tilt within the workspace, allowing you to reach all areas of the part, without interference or collisions. This yields a cylindrical work envelope that is smaller than the machine travels.
    DOWNLOAD COMPARISON
    HAAS VISE OPTIONS AND CONFIGURATIONS CHART
    AIR VISES | HYDRAULIC VISES
    RELATED PRODUCTS
    LARGER WORK ENVELOPE
    Haas UMC-500
    UMC-500
    5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
    • 40 Taper
    • 5 Axis
    • 8.1k RPM
        CNY ONLY
    Learn More Build & Price
    DIFFERENT APPROACH
    Haas VF-2TR
    VF-2TR
    Trunnion CNC Vertical Mill with 30" x 16" x 20" travels
    • 40 Taper
    • 5 Axis
    • 8.1k RPM
        CNY ONLY
    HIGHER PRODUCTION
    Haas UMC-400SS
    UMC-400SS
    Super-Speed 5-Axis CNC Vertical Machining Center with 17" x 11" x 13" travels
    • 40 Taper
    • 5 Axis
    • 12k RPM
        CNY ONLY
    Build & Price
    Get Started
    Need More Information?
