C-Axis Rotary, 310SS (C-AXIS ROTARY 310SS)
Product Image
GET QUOTE
High-Speed C-Axis Rotary for the VP-5, 310 mm
    CNY ONLY
Machine prismatic features in a single operation
  • Option Info
  • Specs
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
Our High-Speed C-Axis Rotary option mounts an HRT310SS rotary table horizontally on the VP-5’s table as a C-axis platter, to provide access to 5 sides of a part for multi-side machining. The raised height of the rotary also allows the spindle to approach parts from below, for machining undercuts and prismatic features on long parts in a single operation.
  • 310 mm platter size
  • 240 °/sec max speed
  • 400 ft-lb max torque
SERVICE DOCUMENTS
Haas VMT-750
VP-5 Prismatic Machine
Vertical Prismatic Machining Center; 40" x 26" x 25"
  • 40 Taper
  • 4 Axis
  • 8.1k RPM
  • 50+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
Platter S.A.E METRIC
Platter Diameter 12.20 in 310 mm
Max Weight on Platter (w/support) 435 lb 197.3 kg
Max Weight on Platter (unsupported) 218 lb 98.7 kg
Number of Std T-Slots 6 @ 60° 6 @ 60°
Spindle S.A.E METRIC
Max Speed 240 °/sec 240 °/sec
Torque (Continuous) 400 ft-lbf 542 Nm
Runout Max 0.0010 in 0.025 mm
Pilot Bore Diameter 3.2500 in 82.550 mm
Through-Bore Diameter 2.3250 in 59.055 mm
Backlash 30 arc-sec 30 arc-sec
Brake Torque @ 100 psi/6.9 bar 940 ft-lbf 1270 Nm
Gear Ratio 36.75:1 36.75:1
Timing 2:1  2:1
Indexing S.A.E METRIC
Accuracy (±) ± 30.0 arc-sec ± 30.0 arc-sec
Repeatability 10 arc-sec 10 arc-sec
Resolution 0.001 ° 0.001 °
Need More Information?
