120+1 Side-Mount, 50-Taper (SMTC-120-50T)
Product Image
GET QUOTE
120+1 Side-Mount Tool Changer, 50-Taper
    CNY ONLY
High-production tool changer for large HMCs
  • 120+1 Tools
  • 50 Taper
  • Side-Mount Type
50-Taper, 120+1 SMTC, 4+1 Pallet Pool
DOWNLOAD BROCHURE
HAAS JOURNAL
    Available for order, with estimated delivery Q3 2026.
    • Option Info
    • Specs
    OVERVIEW
    DOCUMENTS
    AVAILABLE ON THESE MACHINES
    This Haas-designed 120+1 side-mount tool changer holds 120 tools, plus one in the spindle, providing plenty of locations for back-up tooling, or setting up tools for multiple jobs. It is the perfect choice for high-volume production, or for unattended, lights-out operation with a pallet pool, cobot, or robot.
    The tool changer features a double-arm gripper that swaps tools quickly to minimize non-cutting time, and a bi-directional servo-drive system allows direct positioning to any tool in the carousel. Faster positioning reduces cycle times during short machining operations, or when the carousel is not pre-staged for the next tool. A remote load station with automatic lockout function allows tool inspection, loading, and unloading while the machine is cutting, simplifying tool maintenance, and eliminating the need to load tools through the spindle.
    With adjacent pockets empty, the tool changer will accept oversize tooling, and there’s a built-in automatic recovery process, should a tool change be interrupted for any reason.
    • Remote load station with automatic lockout
    • Bi-directional servo-driven positioning for fast tool staging
    • Mounts to the machine’s bridge and base for stability
    • Fast tool changes reduce non-cutting time
    • Tool Table allows complete control over the tool changer
    • Identify tools as LARGE to leave adjacent pockets empty
    • Identify tools as HEAVY to slow tool changer motion
    Currently available for these models: EC-1600ZT, EC-1600ZT-5AX.
    SERVICE DOCUMENTS
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 120+1 120+1
    Max Tool Diameter (full) 4.0 in 102 mm
    Max Tool Diameter, Large (adjacent empty) 8.0 in 203 mm
    Max Tool Length (from gage line) 20.00 in 508 mm
    Max Tool Weight 30.0 lb 13.6 kg
    Tool-to-Tool (avg) 8.00 s 8.00 s
    Chip-to-Chip (avg) 12.60 s 12.60 s
    Need More Information?
