8 - Track Tool Changer - Service Replacements
Mill Tool Changer - Service Manual
  • 0 - Mill Tool Changer - Table of Contents
  • 1 - Mill Tool Changer - Introduction
  • 2 - Mill Tool Changer - Overviews
  • 3 - Umbrella Tool Changer - Service Replacements
  • 4 - Umbrella Tool Changer - Alignment
  • 5 - Side Mount Tool Changer - Service Replacements
  • 6 - Side Mount Tool Changer - Alignment
  • 7 - Double Arm and Cambox - Service Replacements
  • 8 - Track Tool Changer - Service Replacements
  • 9 - Tool Changer - Troubleshooting Guides
  • 10 - Side-mount Tool Changer - Maintenance
  • 8.1 120 Pocket Trolley - Replacement
  • 8.2 120 Pocket Tipping Assembly - Replacement
Track Tool Changer - 120 Pocket Trolley - Replacement
AD0880
Revision B - 01/2026
Updated
This procedure will show how to replace the pocket trolley on your 120 pocket track side mount tool changer.
This procedure applies to these service kits:
  • UMC-500/SS:
    • 93-5162 SMTC 120 0DEG 40T BT/CT TROLLEY ASSY
    • 93-5163 SMTC 120 0DEG HSK63A TROLLEY ASSY
    • 93-5164 SMTC 120 0DEG 40T BT/CT MSTR TROLLEY (See Note)
    • 93-5165 SMTC 120 0DEG HSK63A MSTR TROLLEY (See Note)
  • UMC-750/SS:
    • 93-5734 SMTC 120PKT 14.5DEG HSK63A TROLLEY ASSY
    • 93-5735 SMTC 120 14.5DEG 40T BT/CT MASTR TROLLEY (See Note)
    • 93-5736 SMTC 120PKT 14.5DEG HSK63A MASTR TROLLEY (See Note)
    • 93-5737 SMTC 120 14.5DEG 40T BT/CT TROLLEY ASSY
  • SMTC 120 POCKET NUMBERS:
    • 93-5933 SMTC120 POCKET NUMBER DECAL SVC KIT
Note: One pocket number sticker sheet will need to be ordered as well for the replacement pockets.
Note: The master pocket 93-kits are for replacing pocket number 1 only.
Note: If a catastrophic failure occurs, the trolleys on both sides of the damaged trolley may need to be replaced as well.
Removing Trolley
Locate the trolley/trolleys that you want to replace.
Using the back door switch panel, jog the tool changer till the pin [1] of the trolley you are trying to remove is visible at the service hole.
Remove the retaining rings [1] on the trolley connecting pins.
Remove the trolley connecting pin [1] from the assembly.
Repeat steps 1-3 of this section to remove the pin from the other end of the trolley.
Note: If removing more than one trolley, remove the pin that will remove the chain of trolleys instead of removing all the pins on that chain of trolleys.
Using the back door switch panel, rotate the carousel till the trolleys go from the service hole location [1] to the back vertical section of track [2].
Remove the track retaining plates D/E and Q/R [1].
Remove the trolley/trolleys [2] from the track.
Install Replacement Trolley
Place the new pocket number stickers onto the pocket before continuing.
Insert the trolley [1] from the service kit into the track and align the trolley pin holes with the surrounding trolleys.
Reattach the track retaining plates [2] to hold the trolleys in the track.
Using the back door switch panel, rotate the carousel till the trolleys go from the back vertical section of track [1] to the service hole location [2].
Install the connecting pin [1] through the service hole of the tool changer. Insert the pin with one retaining ring on the pin. Make sure to push the connecting pin as far as you can till the retaining ring groove is sticks out on the other side of the trolley.
Press on the retaining rings [1] until they are sitting in the groove of the trolley connecting pin.
Note: Make sure the retaining ring is fully seated in the groove all the way around, otherwise the pin could eventually vibrate out.
Test the tool changer and run a tool change for that pocket to make sure there are no issues after the replacement.
Track Tool Changer - 120 Pocket Tipping Assembly - Replacement
UNDER CONSTRUCTION
This procedure will show how to replace the tipping link assembly on your 120 pocket track side mount tool changer.
This procdure applies to these serivce kits:
  • 93-5166 SMTC 120 PCKT 40T TIPPING LINK ASSY
