10 - Side-mount Tool Changer - Maintenance
Mill Tool Changer - Service Manual
  • 0 - Mill Tool Changer - Table of Contents
  • 1 - Mill Tool Changer - Introduction
  • 2 - Mill Tool Changer - Overviews
  • 3 - Umbrella Tool Changer - Service Replacements
  • 4 - Umbrella Tool Changer - Alignment
  • 5 - Side Mount Tool Changer - Service Replacements
  • 6 - Side Mount Tool Changer - Alignment
  • 7 - Double Arm and Cambox - Service Replacements
  • 8 - Track Tool Changer - Service Replacements
  • 9 - Tool Changer - Troubleshooting Guides
  • 10 - Side-mount Tool Changer - Maintenance
  • 10.1 VMC - SMTC Cambox - Oil Level Inspection
AD0615
Revision A - 10/2025
This procedure covers how to measure the oil level and fill the square body or compact cambox of a side-mount tool changer (SMTC) on a vertical mill.
A square body cambox's oil level is checked using a dipstick. The recommended oil level has been raised to 4 inch (101 mm) from the top surface of the square body cambox. This is currently recommended for all vertical square body camboxes no matter when it was manufactured. This is higher than the sight glass and the oil level plug, so these are no longer recommended to use for checking oil level.
The compact cambox 's oil level is checked using the fill plug on the side of the compact cambox. The oil level is checked by undoing the fill plug to see if oil will leak out of the fill plug.
Important: If a cambox's oil level is not at the correct height that may not indicate that the cambox is leaking. Over time the cambox will slowly lose oil or the cambox may have been filled to lower oil level previously. Before replacing the cambox do more investigation to see if the cambox has been damaged and is leaking.
    Required parts
  • T-0144 CAMBOX OIL LEVEL DIPSTICK
Identification
Compact Cambox:
The compact cambox can be distinguished by its housing design. Unlike the square-bodied cambox, the compact version features a more rounded shape and is equipped with a single proximity sensor.
Square Body Cambox:
The square body cambox can be identified from the cambox housing. The cambox body is more square. The cambox also has 3 prox sensors on the cover plate to determine position of the cambox.
Check the Oil Level - Square Body Cambox
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Lock the main circuit breaker. Use an approved lock and an approved safety tag.
Remove any sheet metal necessary to access the top of the SMTC cambox and remove the muffler [1] from the top of the cambox. This can be done with a 9/16-inch wrench.
Make a mark at the point labeled [3] 4 inch (101 mm) from the reference surface [1].
The part labeled [1] will be flush with the top of the cambox. The horizontal labeled [2] should not be used as a reference.
Put the dipstick [1] into the whole at the top of the cambox till it is all the way down as shown in the picture to the left.
Pull the dipstick out and check if the oil is above or below the 4 inch (101 mm) mark made in step 2.
If the oil level is correct, no further action is required.
If the oil level is low, go to the next section.
If the cambox is overfull, do not drain the extra oil.
Check the Oil Level - Compact Cambox
Push [POWER OFF].
Remove any sheet metal necessary to access the SMTC cambox. Remove the fill plug on the cover plate of the compact cambox.
The correct oil level is when the oil is at the height of the fill plug.
Refill the Cambox - Square Body Cambox
Use a funnel [1] to add oil to the cambox until it is 4 inch (101 mm) from the top. Check the level again with a dipstick to verify the level is correct.
Note: Refer to Lubricant Table for Haas Machine Components for the correct oil type.
Refill the Cambox - Compact Cambox
Use a funnel [1] to add oil to the cambox until it has reached the fill port.
Once filled, reinstall the fill plug.
