3 - Umbrella Tool Changer - Service Replacements
Mill Tool Changer - Service Manual
  • 0 - Mill Tool Changer - Table of Contents
  • 1 - Mill Tool Changer - Introduction
  • 2 - Mill Tool Changer - Overviews
  • 3 - Umbrella Tool Changer - Service Replacements
  • 4 - Umbrella Tool Changer - Alignment
  • 5 - Side Mount Tool Changer - Service Replacements
  • 6 - Side Mount Tool Changer - Alignment
  • 7 - Double Arm and Cambox - Service Replacements
  • 8 - Track Tool Changer - Service Replacements
  • 9 - Tool Changer - Troubleshooting Guides
  • 10 - Side-mount Tool Changer - Maintenance
  • 3.1 Shuttle Roller - Replacement
  • 3.2 Removable Geneva Drive Carousel Motor - Replacement
  • 3.3 Pocket - Replacement
  • 3.4 Carousel Plate - Replacement
  • 3.5 Guide Pin and Trap Door - Replacement
  • 3.6 Slip Clutch Arm and Shuttle Motor - Replacement
  • 3.7 20/32 - Pocket Carousel - Motor Replacement
  • 3.8 10-Pocket Carousel - Motor Replacement
3.1 Umbrella Tool Changer - Shuttle Roller - Replacement
Revision C - 4/2025
Shuttle Roller - Replacement - Introduction
This procedure tells you how to replace the top [1] and bottom [2] shuttle rollers on an umbrella tool changer.
Tools Required:
  • Mobil 460 Grease
  • Bottle Jack
  • Medium-strength thread-lock compound
Remove all tools from the tool changer.
Put wooden blocks on the table. Put a bottle jack on the wooden blocks.
Jog the table below the center of the carousel plate.
Support the carousel plate with the bottle jack.
Push [POWER OFF]. Set the main circuit breaker to the OFF position. Lock the main circuit breaker. Use an approved lock with an approved safety tag.
Top roller replacement:
Loosen the (2) 5/16-18 x 2 Socket Head Cap Screws (SHCS) [1]. Remove the wiper bracket [2].
Remove the SHCS [1], lock washer [3], flat washer [4], and roller [5].
Apply medium-strength thread-lock compound (for example, blue Loctite®) to the (2) SHCS [1]. Replace the roller [5] and bushing [6]. Install the components in the opposite sequence they were removed. Make sure the roller [5] is tight against the V-rail [7].
Torque the SHCS [1] to 20 ft-lb (27 N-m). Apply Mobil 460 grease to the top V-rail [7].
Bottom roller replacement:
Remove the 5/16-18 x 1 3/4 Hex Head Bolt (HHB) [1], lock washer [2], flat washer [3], and roller [4].
Apply medium-strength thread-lock compound (for example, blue Loctite®) to HHB. Replace the roller [4] and eccentric bushing [5]. Install the components in the opposite sequence they were removed. Make sure the roller [4] is tight against the V-rail [6].
Rotate the eccentric bushing [5] until the roller is tight on the rail.
Torque the HHB [1] to 20 ft-lb (27 N-m). Apply Mobil 460 grease to the bottom V-rail [6].
IMPORTANT: Hold the lower guide bushing in place with a wrench while torquing the HHB. Over-torquing will cause damage to HHB and eccentric bushing.
Verification
Test the umbrella tool changer for correct operation.
Visually inspect the roller to verify the carousel is not binding and is properly aligned as shown in the image.
Remove the cam follower assembly [1] and lower the slip clutch arm [2] to move the carousel assembly from the shuttle in position, to the shuttle out position in order to verify there are no binds.
If the carousel does not bind, re-install the cam follower assembly.
Refer to the VMC - Umbrella Tool Changer to Spindle - Alignment procedure.
3.2 Umbrella Tool Changer - Removable Geneva Drive Carousel Motor - Replacement
Revision A 08/2025
Removable Geneva Drive Carousel Motor - Introduction
P/N 32-1900A CAROUSEL MOTOR GENEVA
Remove the (4) 10-32 X 3/8 bolts [1] that attach the enclosure cover [2] and gasket [3] to the carousel motor enclosure.  Remove the enclosure cover [2] and gasket [3].
Unplug the sensor and motor cables.
Remove the (4) 1/4-20 X 5/8 bolts [4] that attach the carousel motor assembly [5] to the carousel motor enclosure.  Lift the carousel motor assembly [5] up and out of the carousel motor enclosure.
Prevent the geneva driver [7] from rotating by placing a screwdriver between the cam followers.  Break loose and remove the (3) 1/4-20 X 3/4 bolts [6].
Screw the (3) 1/4-20 X 3/4 bolts [6] into the threaded holes on the geneva driver [7].
Evenly tighten the (3) 1/4-20 X 3/4 bolts [6] until the geneva driver [7] and collar [8] unclamp from the motor shaft.
Unscrew and discard the (4) 10-32 X 5/8 machine screws [9].  Discard the broken carousel motor [10].
Note: The (4) 10-32 X 5/8 machine screws [9] are secured with red loctite.  Use an impact driver to remove them.
 Note: If the carousel motor assembly has limit switch instead of a proximity sensor lubricate the limit switch roller axel with a drop of gear oil.
Install the new carousel motor onto the the mounting plate.
Place the (3) 1/4-20 X 3/4 bolts [6] into the counter bored holes in the geneva driver [7] and screw them into the collar [8] a few threads.
Set the 2-Pin Geneva Drive Spacer Tool (T-2662)  [11] on the motor mounting plate as shown.
Install the geneva drive assembly [12] onto the motor shaft and orient it so that one of the flat sections at the top of the ramps is directly above the TT Clamp sensor.  Press down on the geneva drive assembly [12] until the flat sections at the bottom on the ramps are flush with the 2-Pin Geneva Drive Spacer Tool (T-2662) [11].
Prevent the geneva driver [7] from rotating by placing a screwdriver between the cam followers.  Torque the (3) 1/4-20 X 3/4 bolts [6] to 12 ft*lbs.
Remove the 2-Pin Geneva Drive Spacer Tool (T-2662) [11] and spin the geneva drive assembly [12].  Make sure it does not interfere with the proximity sensors.
Reinstall the carousel motor assembly, gasket, and enclosure cover.
3.3 Umbrella Tool Changer - Pocket - Replacement
Applies to machines built from: January, 1989
Revision A 08/2025
Pocket - Replacement - Introduction
The illustrations in this procedure show a BT-style tool-changer. The instructions are the same for a CT-style tool-changer.
This procedure is applicable to more than one kit. Only one of the kits is necessary.
  • 93-2366 POCKET REPLACEMENT, BT UMBRELLA 32 STATION
  • 93-2371 POCKET REPLACEMENT, CT UMBRELLA 10 STATION (SMM & GR ONLY)
  • 93-2370 POCKET REPLACEMENT, BT UMBRELLA 10 STATION (SMM & GR ONLY)
  • 93-2373 POCKET REPLACEMENT, CT UMBRELLA 20 STATION (NOT GR)
  • 93-2372 POCKET REPLACEMENT, BT UMBRELLA 20 STATION (NOT GR)
  • 93-2369 POCKET REPLACEMENT, CT UMBRELLA 20 STATION (GR ONLY)
  • 93-2368 POCKET REPLACEMENT, BT UMBRELLA 20 STATION (GR ONLY)
  • 93-2374 POCKET REPLACEMENT, BT UMBRELLA 10 STATION (NOT SMM)
  • 93-2367 POCKET REPLACEMENT, CT UMBRELLA 32 STATION
  • 93-2375 POCKET REPLACEMENT, CT UMBRELLA 10 STATION (NOT SMM OR GR)
Remove all tools from the tool changer. Put wooden blocks on the table. Put a bottle jack on the wooden blocks.
Push [POWER OFF].
Remove the (6) SHCS from the carousel plate. With a second person remove the carousel plate.
Use your hand to push the station door [1] fully in to make sure it moves freely. If it does not move freely, clean the chips from the door and the door track.
Use a straightedge on the extractor fork [2] to see if it is bent.
Remove the screws [3] that attach the damaged fork assembly to the carousel plate. Remove the assembly as shown. Replace all damaged parts.
Apply a medium-strength thread-lock compound (for example, blue Loctite®) to the threads on the fork assembly screws [3]. Apply Mobil SHC grease to the thru-holes of the replacement assembly.
Install the replacement assembly. Make sure that the beveled side of the washer [4] is against the extractor key (BT, shown) or the fork bushing (CT). Torque the screws to 7 ft-lb (9.5 Nm).
Put a piece of tape [1] on the carousel at pocket 1. Remove the pocket number ring [2].
Remove the sliding panel cover [3], compression spring [4], rivet [5], and sliding panel [6]. Replace all damaged parts. Clean all debris from the pocket.
Apply Mobil SHC-460 grease to the new compression spring. Put the 3/32" rivet into the end of the compression spring. Install the new compression spring [4] and new sliding panel [6]. Install the new sliding panel cover [7] while you push the end of the spring [8] under the panel.
Torque the (2) 10-32 SHCS [9] to 20 in-lb (2.26 Nm).
Apply medium-strength thread-lock compound (for example, blue Loctite®) to the (2) 10-32 flat head cap screws (FHCS) [10]. Install the (2) FHCS [10] and torque to 20 in-lb (2.26 Nm). Make sure the sliding panel [6] moves freely.
Install the pocket number ring [2]. Make sure the number 1 on the number ring aligns with the tape [1] on pocket 1 of the umbrella tool changer.
3.4 Umbrella Tool Changer - Carousel Plate - Replacement
AD0284
Revision B - 06/2026
Updated
This procedure will show you how to replace the carousel plate on a umbrella style tool changer.
Note: The carousel plate is heavy. You must have the aid of one more person to help you lift it.
This document applies to the following service kits:
  • 30-0017A    CAROUSEL COMPLETE, 20 POCKET CT50
  • 93-1000374    BT TO CT CONV UMB 10 PCKT 40T
  • 93-1000375    CT TO BT CONV UMB 10 PCKT 40T
  • 93-1000376    BT TO CT CONV UMB 20 PCKT 40T
  • 93-1000377    CT TO BT CONV UMB 20 PCKT 40T
  • 93-1718    CAROUSEL COMPLETE, 10 POCKET BT40 W/COVERS
  • 93-30-0006    CAROUSEL COMPLETE, 32 POCKET CT40  (VR-6-11)
  • 93-30-7100A CAROUSEL COMPLETE, 16 POCKET CT40
  • 93-8001    CAROUSEL COMPLETE, 20 POCKET CT40
  • 93-8001BT    CAROUSEL COMPLETE, 20 POCKET BT40
Push [POWER OFF].
If necessary remove the old cover plate [1] and install it on the new carousel plate [2].
With the aid of a second person, put the new carousel plate [2] and the cover plate [1] onto the bottle jack. While the second person balances the new carousel plate [2] on the jack, do these steps:
  • Lift the new carousel plate [2] to the threaded holes. Align the dowel pin [3] to the hole in the bearing housing.
  • Install the (6) 5/16-18 x 1" Socket Head Cap Screws (SHCS) [4].
Torque the screws to 25 ft-lbs.
Push [POWER ON].
Check the tool changer alignment. Refer to Umbrella Tool Changer to Spindle Alignment.
Install the tools.
3.5 Umbrella Tool Changer - Guide Pin and Trap Door - Replacement
Revision A 08/2025
Guide Pin and Trap Door - Introduction
This procedure tells you how to replace the guide pin [1] and trap door [2] on a umbrella tool changer.
Tools Required
  • Mobil 460 Grease
  • Bottle Jack
Push [POWER OFF].
Raise the bottle jack up to support the weight of the bearing housing for the star assembly.
Remove the cover panel [1]. Remove the vertical axle nylon nut [2] and the flat washer [3]. Remove the guide pin assembly [4] from the trap door cover, behind the carriage assembly. Replace the guide pin assembly [4] if it is damaged.
Lower the bearing housing for the star assembly [5] and remove it from the machine.
Remove the trap door, the (2) nylon washers [1] from the top and bottom of the trap door, and the (3) plastic riders [2] from the bottom of the trap door. Replace the washers [1] and the riders [2] if they are damaged.
Apply Mobil 460 grease to the nylon washers [1], plastic riders [2], and the trap door guide slot [3]. Install the washers [1], riders [2], and the new trap door.
Install the bearing housing for the star assembly [4]. Install the vertical axle nylon nut and flat washer [5] in the carriage assembly. Install the cover panel [6]. Apply Mobil 460 grease the tool slots [7] on the star assembly.
Install the guide pin assembly [8].
With the aid of a second person, put the carousel plate [2] and the cover plate [1] onto the bottle jack. While the second person balances the carousel plate [2] on the jack:
  • Lift the carousel plate [2] to the threaded holes. Align the dowel pin [3] to the hole in the bearing housing.
Perform the VMC - Umbrella Tool Changer to Spindle - Alignment procedure.
3.6 Umbrella Tool Changer - Slip Clutch Arm and Shuttle Motor - Replacement
AD0586
Revision A 08/2025
This procedure is applicable to 10- and 20-pocket umbrella tool changers. This procedure tells you how to replace the slip clutch arm [1] and the shuttle motor [2]. The illustrations show a 20-pocket umbrella tool changer.
Document applies to these parts:
  • 93-2597
  • 32-0011
  • 93-30-30061
  • 93-1790
  • 93-30-1937
  • 30-0019B
Tools Rquired:
  • Two-Jaw puller
  • Mobil SHC 460 Grease
  • Medium Strength thread-lock Compound
Replacement
Remove the cover for the carousel motor. Put labels on the cables for the carousel motor assembly. Remove the carousel motor assembly [1]. Remove the cam follower assembly [2]. On 10-pocket umbrella tool changers, the cam follower assembly also has a flag and a nut [3] behind the carriage.
Push the shuttle assembly in the direction of the spindle. Remove the set screw [4] from the slip clutch arm collar. Use a small two-jaw puller [5] to remove the slip clutch arm from the motor shaft.
Remove the shuttle motor assembly [6] and (4) screws [7] from the rail plate. Apply a thread-lock compound (for example: blue Loctite®) to the (4) screws [7]. Install the replacement motor [6] to the rail plate. Use the (4) screws [7].
Install the motor key [8] onto the motor shaft. Install the slip clutch arm [9] onto the motor shaft, over the key [8]. Adjust the position of the slip clutch arm on the motor shaft to make sure the adjacent screw heads have sufficient clearance. Apply a thread-lock compound (for example: blue Loctite®) to the set screw [4]. Install the set screw into the slip clutch arm [9].
Apply Mobil SHC 460 grease to the carriage slot [10] and cam follower [2 and 3]. Install the remaining parts in the opposite sequence that they were removed. Make sure the umbrella tool changer operates correctly. Install the carriage assembly cover.
3.7 Umbrella Tool Changer - 20/32 - Pocket Carousel - Motor Replacement
AD0295
Revision A 08/2025
20/32 - Pocket Carousel - Motor - Replacement - Introduction
This procedure tells you how to replace the carousel motor on a 20- or 32-pocket umbrella tool changer, and a GR machine with a 10-pocket umbrella tool changer.
  1. carousel motor power cable
  2. tool-in-position limit switch
  3. tool-1-in-position limit switch
  4. carousel motor
Machine Compatibility
All VMCs
Requirements:
  • VMCs with a 20/32-pocket umbrella tool changer
  • GR machines with a 10-pocket umbrella tool changer, use [KIT] 30-2416
This procedure applies to (6) different kits. You only need (1) motor assembly to complete the procedure.
[KIT]
30-2416
QTY: 1
MOTOR, UMBRELLA CAROUSEL 10 POCKET W/ MECH SENSOR (GR & SMM)
[KIT]
93-7000
QTY: 1
MOTOR, UMBRELLA CAROUSEL 16 / 20 POCKET W/ MECH SENSORS (SINGLE PIN DRIVE)
[KIT]
30-0005
QTY: 1
MOTOR, UMBRELLA CAROUSEL 20 POCKET W/ MECH SENSORS(DUAL PIN DRIVE)
[KIT]
93-30-0005A
QTY: 1
MOTOR, UMBRELLA CAROUSEL 20 POCKET W/ PROX SENSORS(DUAL PIN DRIVE)
[KIT]
93-1685
QTY: 1
MOTOR, UMBRELLA CAROUSEL 32 POCKET W/ MECH SENSORS (DUAL PIN DRIVE)
[KIT]
30-0016
QTY: 1
MOTOR, 50T UMBRELLA CAROUSEL 20 POCKET W/ MECH SENSORS
Umbrella Tool Changer - Pocket Carousel - Motor - Replacement
Remove the (4) screws [1] that attach the cover panel [2] to the tool changer carriage. Remove the cover panel [2].
 Note: 10-pocket carousel motor covers have the screws on the back of the tool changer carriage.
Disconnect the carousel motor cable, the tool-in-position cable, and the tool-1-in-position cable [3] from the electrical bracket.
Remove the (4) screws [4] and (4) washers [5] that attach the carousel motor assembly [6] to the bottom of the tool changer carriage. Remove the carousel motor [6].
Attach the new carousel motor assembly [1] to the bottom of the tool changer carriage. Use the (4) screws [2] and (4) washers [3].
Connect the carousel motor cable, the tool-in-position cable, and the tool-1-in-position cable [4] to the electrical bracket [5].
Install the cover panel [6] to the tool changer carriage.
Unlock the main circuit breaker. Set the main circuit breaker to the ON position.
Push [POWER ON]. Push [POWER UP/RESTART].
Make sure the umbrella tool changer rotates.
3.8 Umbrella Tool Changer - 10-Pocket Carousel - Motor Replacement
AD0301
Revision A 08/2025
This procedure tells you how to replace the carousel motor on a 10-pocket umbrella tool changer.
  1. carousel motor
  2. carousel motor power cable
  3. tool changer proximity sensor
  • VMCs with a 10-pocket umbrella tool changer
 Note: SMM and GR machines with a 10-pocket umbrella tool changer use the same kit ([KIT] 30-2416). To replace a 10-pocket carousel motor on a GR machine, refer to Umbrella Tool Changer - 20/32-Pocket Carousel - Motor - Replacement.
This procedure applies to (4) different kits. You only need (1) motor assembly to complete the procedure.
[KIT]
30-2416
QTY: 1
[KIT]
93-1696
QTY: 1
MOTOR, UMBRELLA CAROUSEL 10 POCKET W/ PROX SENSOR (SMM)
[KIT]
93-30-1679A
QTY: 1
MOTOR, UMBRELLA CAROUSEL 10 POCKET W/ PROX SENSOR (MM)
[KIT]
93-1681
QTY: 1
MOTOR, UMBRELLA CAROUSEL 10 POCKET W/ MECH SENSOR (MM)
Umbrella Tool Changer - 10-Pocket Carousel - Motor - Replacement
Remove the (8) screws [1] that attach the cover panel [2] to the tool changer carriage. Remove the cover panel [2].
 Note: Covers for the 10-pocket carousel motor have (2) screws on the back of the tool changer carriage.
Disconnect the carousel motor power cable [3]. Disconnect the tool changer proximity sensor [4].
Remove the (4) screws [5] and (4) washers [6] that attach the carousel motor assembly to the bottom of the tool changer carriage. Remove the carousel motor.
Install the new carousel motor assembly to the bottom of the tool changer carriage. Use the (4) screws [1] and (4) washers [2].
Connect the power cable [3] for the carousel motor and the tool changer proximity sensor [4] to their correct locations [5] on the electrical bracket.
Install the cover panel [6] to the tool changer carriage. Use the (8) screws [7].
