5 - Side Mount Tool Changer - Service Replacements
Mill Tool Changer - Service Manual
  • 0 - Mill Tool Changer - Table of Contents
  • 1 - Mill Tool Changer - Introduction
  • 2 - Mill Tool Changer - Overviews
  • 3 - Umbrella Tool Changer - Service Replacements
  • 4 - Umbrella Tool Changer - Alignment
  • 5 - Side Mount Tool Changer - Service Replacements
  • 6 - Side Mount Tool Changer - Alignment
  • 7 - Double Arm and Cambox - Service Replacements
  • 8 - Track Tool Changer - Service Replacements
  • 9 - Tool Changer - Troubleshooting Guides
  • 10 - Side-mount Tool Changer - Maintenance
  • 5.1 SMTC - Carousel DC Motor - Replacement
  • 5.2 SMTC - 30/50 Pocket - Replacement
  • 5.3 SMTC - HSK Pocket and Plunger - Replacement
  • 5.4 SMTC - Pocket Check Valve - Replacement
  • 5.5 SMTC-30/50 - Air Cylinder - Replacement
  • 5.6 SMTC-50 - Installation - VMC
  • 5.7 SMTC - Pocket Slider - Set Screw - Adjustment - VMC
5.1 Side-Mount Tool Changer - Carousel DC Motor - Replacement
AD0362
Revision A 08/2025
Parts Required
This procedure applies to several kits. You need only (1) of the motors listed here:
  • 93-30-2111 Motor, SMTC Carousel 40T
  • 93-1642 Motor, SMTC Carousel 30/40T
  • 93-1664 Motor, SMTC Carousel 50T
Remove/Replace Motor
Remove the carousel cover assembly.
Disconnect the motor cable [1] from the electrical connector bracket.
Remove the (2) motor mount screws [2], the belt [3], and the used motor.
Install the new motor with the (2) motor mount screws [2].
Tighten the screws, but leave them loose enough to control the adjustment of the belt.
Put the new belt around the tool changer sprocket and the motor sprocket.
Tighten the belt until it has no more than 1/8 inch (3 mm) of deflection.
Torque the motor mount place screws [2] to 15 ft-lb (20.34 Nm).
Connect the motor cable [1] at the electrical connector bracket.
Replace the carousel cover assembly.
SMTC-30/50 Pocket - Replacement
Revision A 08/2025
This procedures tells you how to replace the tool pocket on the SMTC-30T/50T.
Replacement
Remove the number plate from the carousel.
Remove the (2) 5/16-18 bolts [1] from the carousel for the damaged pocket.
Slide the pocket assembly [2] out from under the carousel plate.
Install the replacement pocket. Torque the (2) 5/16-18 bolts [1] to 25 ft lbs. Install the number ring in the correct orientation.
AD0805
Revision A 08/2025
This procedure will go over how to replace the HSK pocket and plungers.
Pocket Replacement
Before installing the new pocket, make sure to lubricate the collet assembley by spreading tacky grease on it.
Slide the new pocket assembley under the carousel plate and attach using the (2) 5/16-18 bolts [1].
Contiue to next steps to further disassemble the HSK pocket.
Plunger Replacement
Remove the screw to allow the collet assembly to come out of the pocket.
With the collect assembly removed from the pocket, press the center cap [1] in to be able to remove the plungers [2].
NOTE: There is a spring behind the cap, be careful to make sure the cap does not shoot out after the plungers are removed.
Verify the spring is in good condition before reinstalling the plungers and collet assembly. Make sure to grease the plungers and cap before reassembling.
To reassemble, follow this procedure in reverse order.
AD0534
Revision B - 04/2026
This procedure will describe how to replace the check valve at the air cylinder side of the tool changer to a compression fitting and move the check valve to the solenoid side.
Machine Requirements:
  • Haas Classic Control M18.XX and below
The following kit pertains to this instruction:
  • 93-3278: 58-7243 PO CHECK VALVE REPLACEMENT KIT
SOLENOID CAUTION: Some of the solenoid configurations may not work as shown in the images due to space available around the solenoid . If that is the case some adjustments may have to be made to fit the check valve and compression fitting.
There are two solenoids you may encounter, a 4 port and a 5 port, they should follow the general configurations shown in the image.
  • For the 4 port solenoid the check valve [1] should go in the port across from the compression fitting in port B [3] and a fitting to connect the air line [2] should be assembled to the check valve [1]..
  • For the 5 port solenoid the check valve [4] goes in between the reducer [6] and air line fitting [5] in the port labeled IN. The compression fitting [7] goes in the port labeled A.
Accessing the Air Cylinder
This picture shows the air cylinder on the 50-Pocket 50T tool changer [1] and the 30-Pocket 50T tool changer [2].
For the 50 & 30-Pocket tool changer, this procedure shows how to access the air cylinder through the front of the carousel.
As an alternative, you can remove the carousel to access the air cylinder.
All other tool changers air cylinders may be accessed the same way.
If you remove the carousel please use the appropriate lifting aids to safely lift the tool changer out of the machine.
WARNING: There is a locknut on the  30-Pocket 50T tool changer, use tool P/N T-1357 to remove and replace the bearing lock nut (P/N 51-2043). Torque the bearing lock nut to 80 ft-lb (108 Nm).
24 pocket, 30T, 40T
At the air cylinder replace the 58-7243 check valve [1a] & 58-7244 tee fitting [1b] with the 58-16708 FITG POLY1/4F NPT1/4M STR BRASS [2a] and 58-1349 FITG PC1/4F NPT1/4M STR BRASS [2b].
At the solenoid side replace 58-3070 [4] with 58-16706 compression fitting [6] at output B. Add 58-2019 check valve [5] at the input across from output B between the existing fittings and solenoid [3].
40 pocket, 40T
60 pocket, 40T
NOTE: No model was found to create the images, use the following as a guideline:
At the air cylinder replace the 58-7243 check valve & 58-7244 tee fitting with the 58-16708 FITG POLY1/4F NPT1/4M STR BRASS and 58-1349 FITG PC1/4F NPT1/4M STR BRASS.
NOTE: If a solenoid is present please refer to the solenoid caution in the introduction.
70 pocket, 40T
At the solenoid side replace 58-3070 [4] with 58-16706 compression fitting [6] at output B. Add 58-2019 check valve [5] at the input across from output B between 58-16700 FITG NPT1/8F NPT1/8M 90 BRASS and 58-1859 FITG PC3/8F NPT1/8M STR BRASS [3] built as shown.
30 pocket, 50T
At the air cylinder replace the 58-7243 check valve [1a]  & 58-7244 tee fitting  [1b] with the 58-0914 FITG POLY3/8F NPT1/4M 90 BRASS (90 degree compression) & 58-0562 FITG LBO1/4 NPT1/8M STR [2].
Updated
At the solenoid side insert 58-2019 check valve [7]  between the reducer and elbow fitting [5] in the port labeled in.
Replace the PTC fitting in port A [4] with 58-16755 FITG COMP 1/4 X 1/8 MNPT BR STR or 58-3075 FITG POLY1/4F NPT1/8M 90 BRASS [6].
50 pocket, 50T
At the air cylinder replace the 58-7243 check valve [1a]  & 58-7244 tee fitting [1b] with the 58-16708 FITG POLY1/4F NPT1/4M STR BRASS [2] and 58-0562 FITG LBO1/4 NPT1/8M STR, this assembly has the reducer at the cylinder and a plug [3] .
72 pocket, 50T
At the solenoid side replace 58-3070 [4] with 58-16706 compression fitting [6] at output B. Add 58-2019 check valve [5] at the input across from output B built with 58-16700 FITG NPT1/8F NPT1/8M 90 BRASS and 58-1859 FITG PC3/8F NPT1/8M STR BRASS.
VR 32 Pocket Umbrella Tool Changer
At the solenoid side insert 58-2019 check valve [7]  between the reducer and elbow fitting [5] in the port labeled in. Replace the PTC fitting in port A [3] with 58-16755 FITG COMP 1/4 X 1/8 MNPT BR STR or 58-3075 FITG POLY1/4F NPT1/8M 90 BRASS [6].
5.5 SMTC - 30/50 - Air Cylinder - Replacement
Revision A 08/2025
This procedures tells you how to replace the air cylinder on the SMTC-30/50.
Replacement
Remove the sheet metal covers.
Remove three adjacent pockets.
Rotate the carousel so the center removed pocket is in position.
Shut off the main air supply to the machine.
Unplug the top air cylinder hose [2] (green).
Use a 1/4" ball-end allen wrench to remove the (4) top cylinder mounting bolts [1].
Unplug the lower air cylinder hose [1] (red) and remove the pocket up/down proximity sensors [2].
Remove the (4) mounting bolts for the pocket slide assembly.
The pocket slide assembly is on (2) alignment pins. Pull the slide assembly off the pins and drop the slide and cylinder out of the tool changer.
Remove the roller [1] from the cylinder side of the pocket slide assembly.
Remove the cylinder from the pocket slide.
Remove the bushing [2] and air fittings [4] and install them on the replacement cylinder. Thread the bushing [2] all the way on the cylinder shaft, then back it off approximately two turns so there is a 1/8" gap [3] between the flange on the shaft and the jam nut.
Loosen the cylinder jam nuts [5] and back off the set screws until they stop then tighten the jam nuts.
Re-assemble the pocket slide and install the cylinder in the reverse order they were removed.
Turn on the main air supply and test the pocket up/down cylinder. Re-install the sheet metal covers.
AD0416
Revision A 08/2025
Use the lifting hoist ring [1] as shown to support the tool changer (aprox. 775 lbs/351 kg).
Clean the mating surface for the tool changer [2].
Place a piece of cardboard between the spindle head and the tool changer to prevent scratching the spindle head covers.
Unbolt the tool changer from the shipping mounts and lift it into position on the column [2] and tighten the (6) bolts to 80 ft-lb (108 N-m).
Remove the shipping mounts [3] but leave the lifting ring [1] on for alignment.
The tool changer is wired as shown:
  • Carousel Motor (TT) [1]
  • Cambox Motor (TA) [2]
  • Tool Changer Status Harness [3]
  • Carousel Lube Line [4]
  • Pocket Up Air Hose [5]
  • Pocket Down Air Hose [6]
The cable clamps are removed to reach the shipping position but the cables are still connected. Reinstall the cable clamps.
Power up and Activate the control. Remove the shipping brackets and complete the machine leveling procedure before aligning the tool changer in the next step.
Using a split tool [1] in RECOVERY mode, verify the alignment to the pocket and check the alignment to the spindle.
With the (4) TC bolts loose support the weight of the tool changer with the lifting ring, rotate the SMTC adjuster [2] to align the front-to-back of the arm to the spindle. The tool changer will not move unless you support the weight.
If the spindle alignment is out side-to-side, insert a shim [3] between the tool changer and the mount. Do not leave the shim exposed.
  Important:  You must set the Z-axis Tool Change Offset and Spindle Orientation after installing the 50 Pocket Tool Changer. Refer to Side Mount Tool Changer - Z-Axis Tool Change offset- NGC,  Side-Mount Tool Changer - Spindle Orientation Offset - NGC
The sheet metal will be installed in this order.
  • [1] Back Enclosure Panel
  • [2] Cover Bottom Front
  • [3] Cover Bottom Back
  • [4] Cover Bottom Middle
  • [5] Brushes
  • [6] Cover Seal Bracket
  • [7] Cover Seal Top
  • [8] 5/16 Plastic Rivet
  • [9] Cover Tool Back
  • [10] Cover Tool Front
  • [11] Cover Tool Brace
  • [12] Cover Carousel
  • [13] Cover Cambox
  • [14] Cover Top Access
Install
Install
  • [5] Brushes
Install [6] [7] [8], cover seal assembly.
Install
Install
  • [13] Cover Cambox
5.7 Side-Mount Tool Changer - Pocket Slider - Set Screw - Adjustment - VMC
Revision A 08/2025
If the pocket slider set screw [1] is not correctly adjusted, the cam follower [2] may hit the pocket when the carousel turns.
This procedure tells you how to adjust the set screw for the pocket slider.
VMC - Side-Mount Tool Changer - Pocket Slider - Set Screw - Adjustment
Go into DEBUG mode.
Press [RECOVER] to go into TOOL CHANGER RECOVERY mode.
For software 17.XX and later, press [M].
For software 16.XX and earlier, press [Y] (3) times.
The screen shows Manual Tool Changer Operation.
Press the [RIGHT] cursor arrow to move the carousel forward.
While the carousel turns, monitor the cam follower alignment with the pocket slot.
In this example, the slider is too low.
The cam follower hits the pocket when the carousel turns [1].
Adjust the set screw for the pocket slide, as follows.
Under the pocket stop, find the lock nut [1] for the set screw. Loosen the lock nut.
Turn the set screw [1] clockwise or counterclockwise.
This moves the pocket slider up or down.
For this example, turn the set screw clockwise. This moves the pocket slider up.
Press the [RIGHT] cursor arrow.
This moves the carousel to the next position.
If the adjustment is correct, the cam follower is in the center of the slot.
The cam follower does not hit the pocket when the carousel turns.
If the adjustment is correct, tighten the lock nut [1] for the set screw.
