320V Power Supply Replacement - AD0680
Service Home How To Procedures 320V Power Supply Replacement - AD0680
Recently Updated Last updated: 06/15/2026
320V Power Supply - Replacement
AD0680
Revision B - 06/2026
- Jump to Section - 1. Introduction 2. Electrical Safety 3. Replacement / Installation Back to Top
This procedure will show you how to replace 320V Power Supply on a Classic Haas Control.
This Document Applies to these Parts:
  • 93-6353: POWER SUPPLY, 5HP 320V
  • 93-69-2000F: POWER SUPPLY, 5HP 320V
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
1. [POWER OFF] the machine and wait until the High Volt light is completely turned off. Mark and remove all the cables from the 320V Power supply.
 Note:  The new 320V Power Supply does not need the +12VDC supply that was connected to J3 on the old power supply.
2. Install the new 320V Power Supply.
IMPORTANT: Pay attention to the wiring as older version have different wiring configurations.
3. Connect the PS Fault cable that connects to J4 [1].
4. Connect the voltage monitor (or VMON) cable to J2 [2].
 Note: Older machines did not have a VMON cable installed.  For these machines the VMON cable is not used.
5. Connect the Regen cable [3] to the terminal strip.
6. Connect the 320VDC cable [4] to the terminal strip.
7. Connect the 230VAC Input cable [5] to the terminal strip.
8. Connect the Ground cable and make sure all terminals are tight.  [POWER ON] and test the machine operation.
