Lathe - 3rd Party Conveyor - Integration Aid - AD0686
Service Home How To Procedures Lathe - 3rd Party Conveyor - Integration Aid - AD0686
Recently Updated Last updated: 01/08/2026
AD0686
Revision A - 1/2026
- Jump to Section - 1. Introduction 2. Electrical Requirements 3. Conveyor Envelope Requirements 4. Installation (2 steps) 5. Lathe - 3rd Party Conveyor Activation 6. Motor Wiring Verification (1 step) Back to Top
This document is intended to aid in the integration of a 3rd party conveyor to a Haas Lathe Machine with the Next Generation Control (NGC). Haas Service personnel can help to make sure that the CNC machine operates correctly.
Danger: Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
WARNING: There are a number of elements that are needed to install 3rd Party options on a Haas Machine. It is the responsibility of the customer to choose a 3rd Party manufacturer and integrator to successfully install these options to the Haas Machine. The 3rd Party Option must meet the specification found in this document. The Haas Service and Applications staff will help to ensure the CNC machine is functioning properly, but is not responsible for setup or system integration of the 3rd Party option.
Machine Requirements:
  • This option applies to all NGC machines listed below.
Functionality Requirements:
  • 3rd party conveyor motor must be capable of being reversed electronically in order to ensure “FWD/REV” direction corresponds with our control
THIRD PARTY CHIP CONVEYOR FIELD INSTALL are applicable to the following machines:
Machines Kits
TL-1/2 93-1001044
TL-1-EDU
ST-10/15/Y 93-1001043
ST-10L/15L/Y 93-1001091
ST-20/25/28/Y 93-1001092
ST-20L/25L/28L/Y 93-1001093
ST-30/35/Y 93-1001094
DS-30Y
ST-30L/35L/Y 93-1001095
ST-40S/45S/Y 93-1001045
ST-40/45/Y  93-1001096
ST-40/45/Y Reboot
ST-40L/45L/50/Y 93-1001046
ST-40L/45L/50/Y Reboot
The conveyor motor must satisfy the following electrical requirements to integrate to the Haas machine.
WARNING: Motors outside of Haas specifications may not function as intended and Haas service are not responsible for such motors.
  • Single phase motor, 211-259 VAC, 50/60Hz
  • Power: 1/8 HP nominal.
  • Full load current: 0.75 – 0.8 Arms
  • In-rush/locked rotor current: 1.7 Arms maximum.
  • Motor must be capable of being reversed electronically.
  • Thermal or impedance protection.
  • Power cable connector type: L15-20P (black, white, red, green).
Haas recommends the power cable to be a L15-20P (Black – Z, White – X, Red – Y, Green – G) type to be compatible with our receptacle (L15-20R) on the coolant connector bracket.
Customers have the option to change power cables as needed so long as the power cable satisfies our electrical requirements and meets electrical safety standards.
The Chip Conveyor Extension Cable will be connected to P24 on the NGC I/O Board.
Machine Model A B C D E F (Adjustable) G (Adjustable) H Belt Width
ST-10/15/Y 93.0 " Tol: +/- 3.0"  50.0" Tol: +/- 3.0" 43.0" Tol: +/- 3.0" 29.0" Tol: +/- 3.0" 49.0" Tol: +/- 3.0" 11.0" Tol: +/- 1.0" 5.0" Tol: +/-0.5" 12.0" MAX 8"
ST-10L/15L/Y, ST-30/35/Y, DS-30Y 125.0" Tol: + / -3.0" 82.0" Tol: + / -3.0" 80.0" Tol: + / -3.0" 29.0" Tol: +/- 3.0" 52.0" Tol: +/- 3.0" 11.0" Tol: +/- 1.0" 5.0" Tol: +/-0.5" 12.0" MAX 8"
ST-20/25/28/Y 114.0" Tol: +/- 3.0" 70.0" Tol: +/- 3.0" 69.0" Tol: +/- 3.0" 29.0" Tol: +/- 3.0" 52.0" Tol: +/- 3.0" 11.0" Tol: +/- 1.0" 5.0" Tol: +/-0.5" 12" MAX 8"
ST-20L/25L/28L/Y 136.0" Tol: +/- 3.0" 92.0" Tol: +/- 3.0" 91.0" Tol: +/- 3.0" 29.0" Tol: +/- 3.0" 52.0" Tol: +/- 3.0" 11.0" Tol: +/- 1.0" 5.0" Tol: +/-0.5" 12" MAX 8"
ST-30L/35L/Y 157.0" Tol: +/- 3.0" 113.0" Tol: +/- 3.0" 112.0" Tol: +/- 3.0" 29.0" Tol: +/- 3.0" 52.0" Tol: +/- 3.0" 11.0" Tol: +/- 1.0" 5.0" Tol: +/-0.5"
12" MAX 8"
ST-40/45/Y 152.0 " Tol: +/- 3.0"  107.0" Tol: +/- 3.0" N/A 28.0" Tol: +/- 3.0" 52.0" Tol: +/- 3.0" 21.0" Tol: +/- 1.0" 5.5" Tol: +/-0.5" 22.0" MAX 18"
ST-40L/45L 189.0 " Tol: +/- 3.0"  145.0 " Tol: +/- 3.0"  127.0" Tol: +/- 3.0" 28.0 " Tol: +/- 3.0"  57.0" Tol: +/- 3.0" 21.0" Tol: +/- 1.0" 5.5" Tol: +/-0.5" 22.0" MAX 18"
TL-1, TL-1 EDU 100.0 " Tol: +/- 3.0"  56.0 " Tol: +/- 3.0"  N/A 27.0 " Tol: +/- 3.0"  50.0" Tol: +/- 3.0" 17.0" Tol: +/- 1.0" 6.0" Tol: +/-0.5" 12.0" MAX 8"
TL-2 118.0 " Tol: +/- 3.0"  74.0 " Tol: +/- 3.0"  N/A 27.0 " Tol: +/- 3.0"  49.0" Tol: +/- 3.0" 17.0" Tol: +/- 1.0" 6.0" Tol: +/-0.5" 12.0" MAX 8"
ST-10/15:
Remove the shipping chip tray from the machine.
Place the conveyor into the machine by sliding the conveyor into the casting funnel.
NOTE: The conveyor in the image will most likely does not reflect the conveyor you purchase from a 3rd party vendor. This image is for reference only, please verify with your 3rd party vendor lifting points, weights, and other important details for installation.
Turn on the machine
Log in to the HBC PORTAL.
Dowload the applicable configuration patch files.
Note: The option files will appear on the configuration download page after the 3rd Party Conveyor Integration Aid has been ordered. If the option does not appear, contact the service department.
Load the option configuration patch file to the control. Refer to the NEXT GENERATION CONTROL - CONFIGURATION FILE - DOWNLOAD/LOAD procedure.
Wire the motor, Haas recommends to follow the motor wiring shown in this image.
NOTE: Motor wire colors can vary from vendor to vendor.
Please verify the following Conveyor Motion after wiring the motor:
When power is applied to black and red cable leads (“CHIP FWD” button on Haas control), conveyor moves in the forward direction, i.e., pushes chips out.
When power is applied to black and white cable leads (“CHIP REV” button on Haas control), conveyor moves in the reverse direction, i.e., pulls chips in.
NOTE: The wiring of white and red leads can be swapped to change the direction of the motor.
