Extruded Spindle Liner - Adapter Kit Ø2.50 - Installation - Lathe - AD0267
Service Home How To Procedures Extruded Spindle Liner - Adapter Kit Ø2.50 - Installation - Lathe - AD0267
Recently Updated Last updated: 03/15/2022
AD0267
Applies to machines built from: November, 2015
- Jump to Section - 1. Introduction (1 step) 2. Installation Back to Top
Extruded spindle liners [4] adapt the lathe spindle bore to different sizes of bar stock. Extruded spindle liners are held in place with the LINER ADAPTER 2.50, an optional washer [3], and a “nesting” liner [5]. This procedure tells you how to install the LINER ADAPTER 2.50 kit for a Ø2.50" spindle bore.
A liner adapter 2.50 Spring-Lock Body) [6] fits onto the rear of the hydraulic closer. The extruded spindle liner [4] fits inside the Spring-Lock Body [6]. The Liner Adapter 2.50 ID Spring Lock Cap (Spring-Lock Cap) [1] and Spring [2] hold the extruded spindle liner [4] in position. For this kit, a Washer [3] is added to the Spring-Lock Cap [1] and Spring [2], when a “nesting” liner [5] is used.
 Note: All lathes with a spindle bore larger than Ø1.75" use a "nesting" liner [5] to support bars smaller than Ø1.75".`
The size of the bar stock determines the size of the extruded spindle liner. For correct liner configuration, contact your Haas Factory Outlet.
  1. Spring-Lock Cap
  2. Spring
  3. Washer (only required with optional "Nesting" Liner)
  4. Extruded Spindle Liner
  5. "Nesting" Liner (optional)
  6. Spring-Lock Body
  7. Nuts
  8. Button Head Cap Screws
Refer to Spindle Liner Kit Reference Table for more information.
If you have a Servo Bar 300, lower the transfer tray. If you have a Haas Bar Feeder, move the Bar Feeder to the setup position. Refer to the Operator's Manual for instructions on how to do this.
 Important: The illustrations do not show the coolant collector and Bar Feeder. This lets you see the steps. The removal of these parts is not necessary.
KIT PN: LINER ADAPTER 2.50, LINER GUIDE ADAPTER KIT, 2.50" (64 MM). QTY: 1
Remove the bolts on the bore cover [1]. Remove the bore cover [1] and the sensor ring [2] from the hydraulic closer.
 Note: Do not discard the bore cover [1] and sensor ring [2]. You can install them again if you remove the SPRING-LOCK BODY [A] from the lathe.
Make sure these parts are clean:
  • the threads on the hydraulic closer
  • the face of the hydraulic closer
  • the threads and inside shoulder of the SPRING-LOCK BODY [A].
Put the (3) BUTTON-HEAD CAP SCREWS (BHCS) [E] through the holes in the SPRING-LOCK BODY [A]. Attach the (3) NUTS [F]. Tighten the BHCS and NUTS with your hand.
Turn the SPRING-LOCK BODY [A] onto the hydraulic closer. Tighten the SPRING-LOCK BODY [A] with your hand.
Torque the (3) BHCS [E] to approximately 30 in-lb (339 N-cm).
 Caution: To prevent damage to the SPRING-LOCK BODY [A], do not torque the BHCS more than 30 in-lb (339 N-cm).
Install the correct spindle liner [4] for your size bar stock.
 Note: All lathes with spindle bore larger than Ø1.75" use a "nesting"liner [5] to support bars smaller than Ø1.75".
Put the SPRING [C] (and WASHER [B] if "nesting" liners) in the SPRING-LOCK CAP [D]. Align the SPRING-LOCK CAP [D] with the adapter guides. Press and turn the SPRING-LOCK CAP [D] until it locks.
 Note:
  • Remove the SPRING-LOCK CAP [D] to push full-bore size stock.
  • Clean debris from the SPRING-LOCK CAP [D], SPRING [C], and WASHER [B] when necessary.
To use this Adapter Kit Ø2.50 [3] on lathes built before November 1, 2015, install a COOLANT COLLECTOR EXTENSION [2] (P/N 25-2618) to help prevent coolant leaks during operation. Remove the coolant collector door [1] and insert the COOLANT COLLECTOR EXTENSION [2].
To install the coolant collector door [1] again on these lathes, you must remove the COOLANT COLLECTOR EXTENSION [2] and the Adapter Kit Ø2.50 [3].
