Spindle - Lubrication Oil - Collection Test
Service Home How To Procedures Spindle - Lubrication Oil - Collection Test
Recently Updated Last updated: 02/18/2025
This test is required to get approval for any replacement spindle. This is also great monthly preventative maintenance to identify lubrication issues before a spindle is damaged.
- Jump to Section - 1. Introduction 2. Prerequisites 3. Tools Required 4. Spindle - Lubrication Oil - Bottle Collection Test (5 steps) Back to Top
This procedure shows you how to verify that a spindle is getting properly lubricated. Perform the procedure when you have these conditions:
  1. You are troubleshooting a spindle issue
  2. You are troubleshooting a lubrication issue
  3. You are replacing an oil pump
  4. You want to install a replacement spindle
  5. You want to perform preventative maintenance on the machine
Prerequisites
- If you have an old style oil pump that does not have sight glasses, then you must install the sight glass upgrade.
  • Bijur - Mechanical - Oil Pump - Single Drip Glass Installation
Tools Required
  • (1 or 2) Water Bottles, 16 ounce (473 ml)
  • Cable Ties
  • Drill
  • 1/4" drill bit
  • 1/16" drill bit
Note: This procedure is shown on a machine with a 50-Taper spindle. These require two collection bottles.  If the mill or lathe spindle only has 1 lubrication port, then you will only need one bottle.
Make collection bottles from empty (16-ounce, 473 ml) dry and damage free water bottles
Drill a 1/4" hole [1] and a 1/16" vent hole [2] in the cap of the water bottles
You will insert the spindle oil tube [3] through the 1/4" hole in the bottle caps [4]
 Note: The tube must fit tightly. The diameter of the vent hole must be 1/16". This creates the correct amount of back pressure in the collection bottles during the test
Loosely wrap a cable-tie [5] around the tubing approximately 3" (76 mm) from the end of the tube [3]. This makes sure the tube does not fall out
 Note: Do not make the cable-tie too tight. This can cause damage to the tubes
Disconnect the spindle oil tubes (lathe) [1] (mill) [2]
In MDI mode, command the spindle to run at 100 RPM
Make sure air flows out of the tubes
If air does not flow, make sure no kinks are in the tubes
Press [RESET] to stop the spindle
Insert the oil lube tubes into the bottle caps
Support the bottles on the side of the spindle head using cable ties
In MDI mode, command the spindle to run at 100 RPM for (4) hours.
 Note: Do not set the Spindle Speed Override to 0%. The spindle must run at a minimum of 100 RPM to cycle the lubrication system.
S100 M03;
G04 P60.L240;
M30;
 Note: For the Bijur mechanical-oil pump lubrication system, jog the axes. Check the axis lubrication system for leaks.
After 4 hours, observe the collected oil
For the Bijur mechanical-oil pump lubrication systems
  • (6-10) drops of oil are visible in the drip-sight glass for each pump cycle
For the minimum lubrication oil pump systems
  • (1-3) drops of oil are visible in the drip-sight glass for each pump cycle
Compare your results to the image shown here
Replace oil pump if you get poor results, otherwise your spindle does not have a lubrication issue
