Mill 45W/60W LED Work Light - Replacement Guide - AD0918
Service Home How To Procedures Mill 45W/60W LED Work Light - Replacement Guide - AD0918
- Jump to Section - 1. Introduction 2. Installation (7 steps) Back to Top
Recently Updated Last updated: 06/26/2026
Mill - 45W/60W LED Work Light - Replacement Guide
Revision 5
AD0918
Revision C - 06/2026
Updated
This procedure will tell you how to replace your mill worklights. The following steps show the UMC-500 series of mills, however can be helpful guidance for other Haas mills.
This document applies to the following service kits:
  • 93-5660 SERVICE KIT LAMP 24V 45W LED
  • 93-5661 SERVICE KIT LAMP 24V 60W LED
Note: Before replacing your work lights, make sure the power output of the replacement lights matches that of the previous lights. Replacement LED lights must not exceed the combined power that can be supplied by the LVPS.
Set the light switch to the LED work lights to the [OFF] position.
Push [POWER OFF].
Set the main circuit breaker to the [OFF] position.
Unplug LED Lamp from the wiring harness.
Note: Do NOT pull the cable to unplug it. Disconnect the light by pulling the connector.
Position the LED Mounting Bracket [1] on the inner left-side of the machine, inserting the studs [3] into the specified bracket holes.
Fasten the bracket with the provided nuts [2].
Repeat this step for the remaining left-side bracket.
Position the LED Mounting Bracket [1] on the inner right-side of the machine.
Fasten the bracket with the provided machine screws [2] through the highlighted bracket holes into the threads [3].
Repeat this step for the remaining right-side bracket.
Fasten the Pivot Bracket [3] to the Mounting Bracket [1] with the provided hardware [2][4] as shown in the diagram.
Fasten the 45W/60W LED Light [1] using the provided hardware as shown in the diagram.
Ensure the crush washer [4] is placed in between the flat washer [3] and the hex nut [5].
Adjust lamp to the desired position then tighten until fixed in place.
Plug in the 45W/60W LED Light to the work light extension cable.
Remove Lockout Tag, flip circuit breaker to [ON], and press [POWER ON].
Check function of LED lights with the light switch on the right side of the pendant.
