Oil Pump Modification - Minimum Lubrication - Mid-Point Oiling (MPO) Spindle - DT-1 - AD0112
Service Home How To Procedures Oil Pump Modification - Minimum Lubrication - Mid-Point Oiling (MPO) Spindle - DT-1 - AD0112
Recently Updated Last updated: 09/20/2018
AD0112
Applies to machines built from: January, 2014
- Jump to Section - 1. Introduction 2. Parts Required 3. Oil Pump Modification - Oil Reservoir With Drip Sight Glass - Minimum Lubrication (10 steps) Back to Top
This procedure tells you how change the air and oil lubrication system from a 2-port system to a 1-port system.
Perform this procedure when you have these conditions:
  1. The machine has a 2-port air and oil lubrication system.
  2. You must install a spindle that has MPO.
  3. The machine has a minimum lubrication oil pump with a drip sight glass.
Parts Required
  • P/N 93-2208; DT-1 MPO Conversion Kit
Remove the cover [1] for the spindle head.
Move the spindle down to get access to the mount assembly for the spindle motor.
Find the (2) adjacent fittings and (2) tubes that go into the assembly [3]. Remove the tube [1] and fitting [2] on the right.
Install the plug [1] into the opening where you removed the fitting.
Install the spindle head cover panel.
Open the air and lubrication panel door.
Support the oil reservoir while you remove the (4) screws that attach the reservoir to the lid.
Remove the oil reservoir from the lid.
Put the oil reservoir on a stable surface. Cover the oil reservoir to keep it clean.
Remove the air tube [1] and the fitting [2] from the low-pressure regulator.
Disconnect the spindle air and oil tube [1] from the assembly for the drip sight glass.
Carefully remove the air and oil tube from the machine.
Remove these parts from the assembly for the drip sight glass:
  • the air and oil fitting [1]
  • the oil fitting [2]
  • the air fitting [3]
Remove the screws [4] and the assembly [5].
Remove the oil hose [1] and the grommet [2] from the oil reservoir lid.
Remove the fitting [3] from the port of the pump body.
Install a blind grommet [1] in the hole on the oil reservoir lid.
Install a plug [2] into the open port of the low pressure regulator.
Install a plug [3] into the open port of the pump body.
Attach the reservoir to the lid. Use the (4) screws.
Make sure the air tube [1] is connected to the low pressure regulator and to the port [2] of the assembly.
Refer to the Mill - Spindle - Lubrication Oil - Collection - Test.
