Vector Drive - 60 HP - Replacement - AD0294
Service Home How To Procedures Vector Drive - 60 HP - Replacement - AD0294
Recently Updated Last updated: 01/31/2022
AD0294
Applies to machines built from: June, 2003
13.2 Vector Drive - 60 HP - Replacement
AD0294
Revision A - 05/2025
This procedure tells you how to replace a 60 hp vector drive.
Haas machines have one of these 60 hp vector drives:
  1. Type 1: Classic vector drive
  2. Type 2: Smart vector drive (current style)
All of the replacement vector drives look like Type 2.
KIT PN: 93-32-5560, VECTOR DRIVE, 60HP SMART.
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Replacement
Push [POWER OFF].
Set the main circuit breaker to the [OFF] position. Lock the main circuit breaker.
Danger: After turning off the machine, wait at least 5 minutes before working in the control cabinet, to allow power to dissipate. Wait for the voltage indicator LED on the vector drive to go off completely.
Put a label on each cable connected to the vector drive. Disconnect all of the cables from the vector drive.
Loosen the (2) bottom screws [1].
Remove or loosen the top (2) screws [1].
Remove the vector drive [2].
Install the replacement VECTOR DRIVE [A].
Tighten the (4) screws.
Connect all of the cables.
After you replace a Type 1 vector drive with a Type 2 vector drive, you must do the Control - Cabinet Door - Vent Hole Modification procedure.
