Axis Lubrication System - Haas Liquid Grease - RD0006
Service Home Axis Lubrication System - Haas Liquid Grease - RD0006
Recently Updated Last updated: 10/16/2025
RD0006
- Jump to Section - 1. Introduction 2. Identification Back to Top
Note: The location of the grease reservoir is different on some machines.
The CALM - Haas Liquid Grease lubrication system is a restrictor grease flow system that pumps grease through flexible plastic tubing and copper tubes to the axes.
Identification
Use the illustration to identify the parts of the lubrication system.
Note: For recommended lubricant types, see Lubricant Table for Haas Machine Components.
  1. Grease Pressure Switch - Monitors the grease system pressure and sends a signal to the control to generate an alarm if the pressure drops below the minimum level too quickly.
  2. Grease Pressure Gauge - Shows the pressure (in psi and bar) of the grease system.
  3. Grease Filter Wrench - Removes the grease reservoir.
  4. Grease Reservoir Assembly - Stores the grease.
  5. Air-Lube Panel Decal - Shows the color-coded cables that connect each solenoid.
  6. Oil Reservoir - Stores the oil that lubricates the spindle.
  7. Air Manifold Assembly - Supplies air to the machine.
  8. Axis-Lube Air Solenoid - Pressurizes the grease reservoir.
  9. Air Pressure Gauge - Shows the pressure (in psi and bar) at which the air is supplied.
  10. Electronic Analog Air Pressure Sensor - Monitors the air system pressure and sends a signal to the control to generate an alarm if the pressure drops below the minimum level for a set period of time.
Axis Lubrication
The grease reservoir [1] lubricates the axes at a rate of (1) grease cycle for every 24 hours of axis travel.
Grease moves from the grease reservoir [1] through flexible plastic tubing [2] to the axis manifolds [3].
Note: The number of axis manifolds may be different on some machines.
Note: Each axis has (1) ballnut [4] and (4-6 ) linear guide trucks [5].
Grease moves from the axis manifolds [3] through copper tubes. The copper tubes lubricate the ballnuts [4] and the linear guide trucks [5].
Note: There is (1) copper tube that goes to the ballnut and (1) copper tube that goes to each linear guide truck.
Note: The Haas Liquid Grease canister lasts approximately 10 months to a year under normal machine operation, 8 hours a day and 5 days per week.
Axis Manifold Fitting Information
The Haas Liquid Grease lubrication system uses adapter fittings [1] in the axis manifolds. The linear guide trucks and ballnuts use restrictor fittings [2]. The restrictor fitting has a gap [4] between the threads and the set screw [3]. This forces the manifold-fed grease to pass through the gap [4] to lubricate the axes.
Note: The copper tubes on this system may or may not be equal length.
Caution: Do not change the length of the copper tubes or flexible plastic tubing. This changes the flow of grease.
