APL - Troubleshooting Guide - NGC - TG0023
Service Home APL - Troubleshooting Guide - NGC - TG0023
- Jump to Cause - Back to Top
8.1 APL - troubleshooting
Recently Updated Last updated: 10/08/2025
Automatic Parts Loader - APL - Troubleshooting Guide - NGC
TG0023
Gripper alignment for pickup/dropoff is not repeatable. Error increases as gripper moves down the table that can cause the gripper to crash into parts. Flat style rail guides allow the table to drift and change the pickup/dropoff locations. Upgrade the table to the new linear guide rails. The Part Number is 93-3163. Follow the Installation Guide to upgrade your table.
Machine generates Alarm 9920 POSITION ERROR TOO LARGE or 9921 VELOCITY ERROR TOO LARGE during zero return or handle jog. The machine configuration files may be incorrect. Contact the service department for more information.
The rollers are misaligned. Loosen and realign the rollers on the specified axis.
There is a loud noise when the AV Axis is jogged or is in motion.  A faulty AV- axis motor can generate noise. Remove the AV axis motor from the module and run the motor by itself and see if the noise repeats.  If the noise repeats the problem is with the motor.
The module is not aligned. Loosen the screws from the module and jog the AV axis to its full travel a few times.  This will help self aling the module to the base, tighten the screws when done.
The APL skips the unload sequence of a finished part. There is a workholding state commanded in the part program. Remove the workholding command from the part program. Workholding states are commanded in the APL template.
There is a delay when the grippers are commanded to rotate or clamp/unclamp. There is a small delay when the digital SMC solenoid is commanded. Order service kits 93-3450 & 93-3452 and follow the Low Load Solenoid Valve Kit - Installation procedure.
The Light Curtain when broken does not trigger the machine to stop APL motion. There is no input from the light curtian to the machine. See the Light Curtain Troubleshooting Guide for more information.
When trying to run the machine a yellow warning message appears saying "Please activate Light Curtain or Cell Safe". The correct safety parameter kit has not been applied to the machine. Order the corresponding Front Automation Safety or Side Automation Safety kits (93-1000997 or 93-1000996) and re-upload the configuration files from HBC.
