DM-3
  1. Vertical Mills
  2. Drill/Tap/ Mill Series
  3. DM-3
DM-3
    CNY ONLY
For the best pricing in your area, contact your local Haas Factory Outlet.
CNC Drill/Mill Center with 36" x 16" x 15.5" travels
The DM-3 is identical in construction and specifications to the DM-2, but provides 8" (203 mm) more X-axis travel and a longer table, while maintaining the DM-2’s compact footprint. The longer X travel easily accommodates multiple fixtures, longer parts, and long extrusions, and the shop-proven 40-taper inline spindle provides 10,000 rpm, and allows high-speed rigid tapping. The machine’s 18+1 tool changer, high acceleration rates, fast rapids, and impressive short tool-change times make the DM-3 an attractive high-productivity machining center.
  • More X-axis travel and longer table than the DM-2
  • Powerful 40-taper inline direct-drive spindle
  • High-productivity machine with a compact footprint
See Available Stock
Current Lead Time
  • 40 Taper
  • 3 Axis
  • 10k RPM
  • 18+1 Tool Capacity
Compare Machines
EXPLORE ALL INVENTORY
Contact Distributor
DM-3
DOWNLOAD BROCHURE
HAAS JOURNAL
    Compare Machines
    BUILD & PRICE
    Contact Distributor
    • Build-&-Price
    • Specs
    • Automation
    • Machine Info
    • Rotary Fit chart
    Travels S.A.E METRIC
    X Axis 36.00 in 914 mm
    Y Axis 16.00 in 406 mm
    Z Axis 15.50 in 394 mm
    Spindle Nose to Table (~ max) 20.0 in 508 mm
    Spindle Nose to Table (~ min) 4.5 in 114 mm
    Spindle S.A.E METRIC
    Max Rating 15.0 hp 11.2 kW
    Max Speed 10000 rpm 10000 rpm
    Max Torque 46.0 ft-lbf @ 1700 rpm 62.0 Nm @ 1700 rpm
    Taper CT or BT 40 CT or BT 40
    Bearing Lubrication Air / Oil Injection Air / Oil Injection
    Cooling Air Cooled Air Cooled
    Table S.A.E METRIC
    Length 38.0 in 965 mm
    Width 15.0 in 381 mm
    T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
    T-Slot Center Distance 4.92 in 125 mm
    Number of Std T-Slots 3 3
    Max Weight on Table-100% Rapids (evenly dist.) 250 lb 113.4 kg
    Max Weight on Table-50% Rapids (evenly dist.) 400 lb 181.4 kg
    Feedrates S.A.E METRIC
    Max Cutting 1200 ipm 30.5 m/min
    Rapids on X 2400 ipm 61.0 m/min
    Rapids on Y 2400 ipm 61.0 m/min
    Rapids on Z 2400 ipm 61.0 m/min
    Axis Motors S.A.E METRIC
    Max Thrust X 2550 lbf 11343 N
    Max Thrust Y 2550 lbf 11343 N
    Max Thrust Z 4200 lbf 18683 N
    Tool Changer S.A.E METRIC
    Type SMTC SMTC
    Capacity 18+1 18+1
    Max Tool Diameter (full)** 2.5 in 64 mm
    Max Tool Length (from gage line) 7.00 in 178 mm
    Max Tool Weight 12.0 lb 5.4 kg
    Tool-to-Tool (avg) 1.75 s 1.75 s
    Chip-to-Chip (avg) 2.00 s 2.00 s
    Tapping S.A.E METRIC
    Max Tapping Speed 5000 rpm 5000 rpm
    General S.A.E METRIC
    Coolant Capacity 55 gal 208 L
    Inline Air Hose 3/8 in 3/8 in
    Coupler (Air) 3/8 in 3/8 in
    Spindle Speed 10000 rpm 10000 rpm
    Spindle Power 15.0 hp 11.2 kW
    Domestic Pallet 100.0 in x 91.5 in x 100.0 in 254 cm x 232 cm x 254 cm
    Export Pallet 100.0 in x 91.5 in x 100.0 in 254 cm x 232 cm x 254 cm
    Weight 5860 lb 5860 lb
    NOTE: All specifications listed are for the standard machine configuration. Optional equipment may change the machine’s specifications.
    *Haas machines are designed to operate on 220 VAC (200-240 VAC) power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Machines, CL-1, CM-1, and SR Series routers. This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
    Haas machines destined for Europe and the UK are configured with an internal high-voltage non-isolated transformer to operate on 400 VAC, except the Desktop Machines, CL-1, CM-1, and SR Series routers.
    **Optional tool changers may have a different max tool size than the standard tool changer. Extra-large tools may require two adjacent pockets empty between tools. Click here for toolholder specifications.
    ATTENTION! Optional high-performance spindles may have a higher power requirement than the standard spindle. However, if the spindle horsepower (kW) does not change, the power requirement remains the same. Verify the power requirement before running power for your machine.
    † Air consumption on 40-taper DC Series machines may be higher, when Through-Tool Air Blast (TAB) is activated.
    Standard Features
    • 10,000-rpm Spindle
    • 18+1 Side-Mount Tool Changer
    • 55-Gallon Coolant Tank
    • Multi-Stage Coolant Pump
    • Chip Washdown Feature
    • Control Widescreen Monitor
    • Ethernet Interface
    • Power Surge Protection
    • Advanced Tool Management
    • Media Display M-Code; M130
    • Safe Run
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    • Convenience Package
    • Stainless Steel Way Covers
    • Phone Charging Stand
    Warranty
    • 1-Year Standard Warranty
    Available Options
    Automation Options
    ANSWERS TO YOUR CONCERNS ABOUT ADDING A HAAS ROBOT: It won’t take up much space, cost a ton of money, or take weeks to integrate.
    SPACE EFFICIENT
    COST EFFECTIVE
    EASY TO INTEGRATE
    EASY TO LEARN
    AVAILABLE OPTIONS
    RELATED PRODUCTS
    Standard Features
    • Safe Run
    • HaasDrop
    • Rigid Tapping
    • ECO Mode
    Warranty
    Available Options
    Automation Options
    • Installation Guide
    • Layout Drawing
    • TORQUE CHARTS
    • Operator’s Manual
    • Automation Options And Configurations chart
    • Automatic Workholding and Configuration Chart
    HAAS VISE OPTIONS AND CONFIGURATIONS CHART
    AIR VISES | HYDRAULIC VISES
    RELATED PRODUCTS
    TURRET-STYLE MACHINE
    Haas DC-2
    DC-2/40 Drill Center
    High-Speed Drill Center with 39.4" x 19.7" x 19.7" travels, 40 taper
    • 40 Taper
    • 3 Axis
    • 10k RPM
    • 20 Tool Capacity
        CNY ONLY
    Learn More Build & Price
    SMALLER SPINDLE TAPER
    Haas DT-3
    DT-3
    CNC Drill/Tap Center with 36" x 16" x 15.5" travels
    • 30 Taper
    • 3 Axis
    • 10k RPM
    • 20+1 Tool Capacity
        CNY ONLY
    TOOLROOM ALTERNATIVE
    Haas TM-2P
    TM-2P
    CNC Toolroom Mill with 40" x 16" x 16" travels and ATC
    • 40 Taper
    • 3 Axis
    • 6k RPM
    • 10 Tool Capacity
        CNY ONLY
    HA2TS DM-3 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    HA5C DM-3 POSITIVE FIT
    HA5C2 DM-3 POSITIVE FIT
    HA5C3 DM-3 POSITIVE FIT
    HA5C4 DM-3 POSITIVE FIT
    HA5CS DM-3 POSITIVE FIT
    HRC160 DM-3 POSITIVE FIT
    HRC210 DM-3 POSITIVE FIT
    HRT160 DM-3 POSITIVE FIT
    HRT160-2 DM-3 POSITIVE FIT
    HRT160SP DM-3 POSITIVE FIT
    HRT160SS DM-3 POSITIVE FIT
    HRT210 DM-3 POSITIVE FIT
    HRT210-2 DM-3 POSITIVE FIT
    HRT210SP DM-3 POSITIVE FIT
    HRTA5 DM-3 POSITIVE FIT
    HRTA6 DM-3 POSITIVE FIT
    T5C DM-3 POSITIVE FIT
    TRT100 DM-3 POSITIVE FIT
    TRT70 DM-3 POSITIVE FIT
    HRT210HT DM-3 POSITIVE FIT
    HRT100 DM-3 POSITIVE FIT
    TH240 DM-3 POSITIVE FIT
    HRT210SS DM-3 POSITIVE FIT
    HA5C2-T DM-3 POSITIVE FIT
    HA5C-T DM-3 POSITIVE FIT
    HA5C3-T DM-3 POSITIVE FIT
    HA5C4-T DM-3 POSITIVE FIT
    LT260 DM-3 POSITIVE FIT
    HRT200HS DM-3 POSITIVE FIT
    HQDA5 DM-3 POSITIVE FIT
    HQDA6 DM-3 POSITIVE FIT
    HRT210S DM-3 POSITIVE FIT
    HDD255 DM-3 ALTERNATIVE FIT: CAUTION ALTERNATIVE FIT: CAUTION This rotary fits this particular machine, but may require alternative fixturing for proper positioning, such as a sub-plate or alternate T-slot.
    Build & Price
    Get Started
    Need More Information?
