20k Spindle, HSK-A63 (20K-HSK-A63)
Product Image
GET QUOTE
20,000-rpm Spindle, HSK-A63
    CNY ONLY
Standard HSK spindle for the VR Series
  • 20k Speed
  • HSK-A63 Taper
  • 24 hp Power
  • Integral Motor Drive
  • Option Info
  • Specs
  • TORQUE CHART
OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This 20,000-rpm spindle features an integral motor design that provides high speed capability in a compact package. The HSK-A63 taper provides high rigidity and high stability for high-speed, extended-reach machining applications. The HSK (Hohl Shaft Kegel, or hollow-shank taper) tooling provides dual contact between the taper and the spindle face, providing a very rigid connection that offers excellent axial and radial accuracy, especially at high spindle speeds.
NOTE: Speeds higher than 10,000 rpm require toolholders balanced to a G2.5 rating at a speed greater than or equal to the operational rpm.
  • Dual-axis spindle head provides ±245 degrees of C-axis rotation and ±120 degrees of B-axis tilt
  • Powerful brakes on the B and C axes for rigid 3+2 machining
  • Dual-contact taper for high rigidity and high accuracy
  • More rigid toolholders for long-reach tools
  • Increased performance for 3D profiling
  • Increased performance when using small cutting tools
Service Documents
SPINDLE S.A.E METRIC
Max Rating 24.0 hp 18.0 kW
Max Speed 20000 rpm 20000 rpm
Max Torque 10.5 ft-lbf @ 12000 rpm 14.3 Nm @ 12000 rpm
Drive System Integral Spindle/Motor Integral Spindle/Motor
Taper HSK-A63 HSK-A63
Bearing Lubrication Grease Packed Grease Packed
Cooling Liquid Cooled Liquid Cooled
B AXIS - TILT S.A.E METRIC
Travel 120 ° to 120- ° 120 ° to 120- °
Max Speed 112 °/sec 112 °/sec
Max Torque 250 ft-lbf 339 Nm
Brake Torque 403 ft-lbf 547 Nm
C AXIS - ROTATION S.A.E METRIC
Travel ± 245 ° to 245- ° 245 ° to 245- °
Max Speed 208 °/sec 208 °/sec
Max Torque 254 ft-lbf 344 Nm
Brake Torque 442 ft-lbf 600 Nm
Note:
  • The following charts are for reference only.
  • These power numbers are based on 240V service, supplied at the required amperage.
  • Actual results may vary depending on the supplied power and the operating conditions.
  • Haas spindles will provide these peak power numbers (which equate to 200% spindle load) for 3 minutes,
    150% spindle load (75% of the peak number) for 10 minutes, 100% spindle load (50% of the peak number) continuously.
Need More Information?
