14 - SB Series - Options Programming
SB - Series - Operator's / Service Manual
  • 0 - SB Series - Table of Contents
  • 3 - SB Series - Safety
  • 9 - SB Series - Part Setup
  • 11 - SB Series - Operation
  • 13 - SB Series - Macros
  • 15 - SB Series - Probing
  • 17 - SB Series - G-Codes
  • 18 - SB Series - M-Codes
  • 19 - SB Series - Settings
  • 21 - SB Series - Tow-along Tailstock
  • 22. SB-Series - Steady Rest
  • 23 - SB Series - Troubleshooting
  • 14.1 Automatic Tool Presetter (ATP)
  • 14.2 C-Axis
The Automatic Tool Presetter increases part accuracy and setup consistency, while reducing setup times by up to 50%. The system features easy-to-use automatic and manual modes of operation, with a user-friendly interface for quick, conversational-style programming.
  • Automatic, manual, and tool-breakage-detection operations.
  • Increases tool setting accuracy and consistency.
  • Conversational-style templates for easy tool-setting operations.
  • No macro programming required.
  • Outputs G-code to MDI, where it may be edited, or transferred into a program.
Follow the link or video below to Align, Test, and Calibrate the ATP.
Automatic Tool Presetter (ATP) - Alignment - Test - Calibration
Calibrate the Automatic Tool Probe (ATP) on Your Lathe
ATP - Manually Probe Tool Offsets
Warning: To manually probe a tool on the ATP, the tool must be fed into the probe stylus by holding the axis direction button and not the Hand Jog Wheel. The jog rate must be set to .001 or the tool offset measured may not be accurate.
Make sure that the ATP arm does not hit parts of the machine.
Push [CURRENT COMMANDS].
Select the Devices tab
Select the Mechanisms tab
Highlight Probe Arm
Push [F2] to lower the ATP arm.
Make sure a turning-stick tool is installed in the turret.
Make sure the pocket faces the spindle.
Jog the X and Z Axes to the center of the probe stylus to probe to X Geometry.
Make sure that you have distance of .125 inches between the tool tip and probe stylus.
Push [OFFSET] and navigate to the TOOL Offset tab .
Select the Tool Row that the tool offset will be measured.
Clear the tool offset value for both X Geometry and Z Geometry by pressing [0]. Push [F1]. This clears the Offset value.
If you get a warning message [1], Push [Y] to select YES.
Press [HANDLE JOG] and press [.001/1.].
Push and hold [-X] until the stick tool touches the probe.
 Note: You hear a beep sound when the stick tool touches the tool probe.
The tool offset will populate X Geometry.
Jog the X Axis away from the ATP arm.
Jog the X and Z Axes to the center of the probe stylus to probe the Z Geometry.
Push and hold [-Z] until the stick tool touches the probe.
The tool offset will populate Z Geometry.
Jog the Z Axis away from the ATP arm.
14.2 C-Axis
C-Axis
The C Axis provides high-precision, bi-directional spindle motion that is fully interpolated with X and/or Z motion. You can command spindle speeds from 0.01 to 60 RPM.
C-Axis operation is dependent on the mass, diameter and length of the workpiece and/or the workholding (chuck). Contact the Haas Applications Department if any unusually heavy, large diameter, or long configuration is used.
Cartesian to Polar Transformation (G112)
The G112 XY to XC coordinate interpolation feature lets you program subsequent blocks in Cartesian XY coordinates, which the control automatically converts to polar XC coordinates. While it is active, the control uses the G17 XY for G01 linear XY strokes and G02 and G03 for circular motion. G112 also converts X, Y position commands into rotary C-Axis and linear X-axis moves.
Cartesian to Polar coordinate programming greatly reduces the amount of code required to command complex moves. Normally a straight line would require many points to define the path, however, in Cartesian, only end points are necessary. This feature allows face machining programming in the Cartesian coordinate system.
C-Axis Programming Notes
Note: Programmed moves should always position the tool centerline.
Tool paths should never cross the spindle centerline. If necessary re-orient the program so the cut does not go over the center of the part. Cuts that must cross spindle center can be accomplished with two parallel passes on either side of spindle center.
Cartesian to Polar conversion is a modal command. Refer to Chapter 16 for more information on modal G-codes.
The G112 code is intended to be used with a Lathe using the C-axis and Live Tooling to program cutter anywhere along a non-rotating part.
The G112 code allows 3-D contouring using the X, Y, and Z axes. The tool centerline programing (G40) and cutter diameter compensation (G41/G42) are available with G112. They are also available for a tool in any of the three plane selection (G17, G18, G19).
A Lathe with Y-axis can use G112 and it can be useful to extend the range of travel of the live tool all the way across a part.
Circular motion (G02 and G03) in any of the three planes (G17, G18, G19) are also available with G112.
Since the spindle is not turning in G112, “feed per inch” (G98) must be selected.
Once G112 is active, all motions are programmed with XYZ and C cannot be used.
All X values are in radius when using G112.
Example Program:
o51120 (CARTESIAN TO POLAR INTERPOLATION) ;
(G54 X0 Y0 is at the center of rotation);
(Z0 is on face of the part) ;
(T1 is an end mill) ;
(BEGIN PREPARATION BLOCKS) ;
T101 (Select tool and offset 1) ;
G00 G20 G40 G80 G97 G99 (Safe startup) ;
G17 (Call XY plane) ;
G98 (Feed per min) ;
P1500 M133 (Live tool CW at 1500 RPM) ;
G00 G54 X2.35 C0. Z0.1 (Rapid to 1st position) ;
G112 (XY to XC interpretation);
M08 (Coolant on) ;
(BEGIN CUTTING BLOCKS) ;
G0 X-.75 Y.5 ;
G01 Z0 F10.;
G01 X0.45 (Point 1) ;
G02 X0.5 Y0.45 R0.05 (Point 2) ;
G01 Y-0.45 (Point 3) ;
G02 X0.45 Y-0.5 R0.05 (Point 4) ;
G01 X-0.45 (Point 5) ;
G02 X-0.5 Y-0.45 R0.05 (Point 6) ;
G01 Y0.45 (Point 7) ;
G02 X-0.45 Y0.5 R0.05 (Point 8) ;
G01 X0.45 Y.6 (Point 9) ;
G00 Z0.1 (Rapid retract);
(BEGIN COMPLETION BLOCKS) ;
G113 (Cancel G112) ;
M135 (Live tool off) ;
G18 (Return to XZ plane) ;
G00 G53 X0 M09 (X home, coolant off) ;
G53 Z0 (Z home) ;
M30 (End program) ;
C-Axis Cartesian Interpolation
Cartesian coordinate commands are interpreted into movements of the linear axis (turret movements) and spindle movements (rotation of the workpiece).
The lathe automatically engages/disengages the C-Axis when the axis is commanded or jogged.
When not using G112, Setting 102 - Diameter is used to calculate the feed rate.
C-Axis incremental moves are possible using the H address code as shown in this example:
G0 C90. (C-Axis moves to 90. deg.) ;
H-10. (C-Axis moves to 80. deg. from the previous 90 deg position) ;
Cartesian Interpolation Example 1. [1] Projected Cutting Path [A] The endmill feeds 1" into the workpiece on one side. [B] The C Axis turns 180 degrees to cut the arc shape. [C] The endmill feeds 1" out of the workpiece.
o51121 (CARTESIAN INTERPOLATION EX 1) ;
(G54 X0 Y0 is at the center of rotation) ;
G00 G18 G20 G40 G80 G99 (Safe startup) ;
G00 G54 X2. C90 Z0.1 (Rapid to 1st position) ;
M08 (Coolant on) ;
G01 Z-0.1 F6.0 (Feed to Z depth) ;
X1.0 (Feed to Position 2) ;
C180. F10.0 (Rotate to cut arc) ;
X2.0 (Feed back to Position 1 ) ;
G00 Z0.5 M09 (Rapid retract, coolant off) ;
G53 X0 Y0 (X & Y home) ;
G53 Z0 (Z home) ;
M30 (End program) ;
Example Program:
o51122 (CARTESIAN INTERPOLATION EX 2);
(T1 is a drill) ;
G19 (Call YZ plane) ; G98 (Feed per min) ;
G00 G54 X3.25 C0. Y0. Z0.25 ;
M08 (Coolant on) ;
G00 Z-0.75 (Rapid to Z depth) ;
G75 X1.5 I0.25 F6. (Begin G75 on 1st hole) ;
G00 C180. (Rotate C axis to new position) ;
G75 X1.5 I0.25 F6. (Begin G75 on 2nd hole) ;
G00 C270. (Rotate C axis to new position) ;
G75 X1.5 I0.25 F6. (Begin G75 on 3rd hole) ;
G00 Z0.25 M09 (Rapid retract, coolant off) ;
G53 X0 (X home) ;
G53 Z0 (Z home) ;
M30 (End program) ;
