      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
4 - SB Series - Control Pendant
SB - Series - Operator's / Service Manual
  • 3 - SB Series - Safety
  • 9 - SB Series - Part Setup
  • 11 - SB Series - Operation
  • 13 - SB Series - Macros
  • 15 - SB Series - Probing
  • 17 - SB Series - G-Codes
  • 19 - SB Series - Settings
  • 4.1 Control Pendant
  • 4.2 Pendant Front Panel
  • 4.3 Keyboard
  • 4.4 Function / Cursor Keys
  • 4.5 Display / Mode Keys
  • 4.6 Numeric / Alpha Keys
  • 4.7 Jog / Override Keys
4.1 SB Series - Control Pendant
Overview
The control pendant is the main interface to your Haas machine. This is where you program and run your CNC machining projects. This control pendant orientation section describes the different pendant sections:
  • Pendant front panel
  • Pendant right side, top, and bottom
  • Keyboard
  • Function/ Cursor Keys
  • Display / Mode Keys
  • Numberic / Alpha Keys
  • Jog / Override Keys
4.2 SB Series - Pendant Front Panel
Front Panel Controls
Name  Image Function
POWER ON Powers the machine on.
POWER OFF Powers the machine off.
EMERGENCY STOP Press to stop all axis motion, disable servos, stop the spindle and tool changer, and turn off the coolant pump.
HANDLE JOG This is used to jog axes (select in HANDLE JOG Mode). Also used to scroll through program code or menu items while editing.
CYCLE START Starts a program. This button is also used to start a program simulation in graphics mode.
FEED HOLD Stops all axis motion during a program. The spindle continues to run. Press CYCLE START to cancel.
Pendant Right Side, and Top Panels
Name Image Function
USB Plug compatible USB devices into this port. It has a removable dust cap.
Memory Lock In the locked position, this keyswitch prevents alterations to programs, settings, parameters, and offsets.
Setup Mode In the locked position, this keyswitch enables all machine safety features. Unlock allows setup (refer to “Setup Mode” in the Safety section of this manual for details).
Second Home Press to rapid all axes to the coordinates specified in settings 268 - 270. (Refer to “Settings 268 - 270” in the Settings section of this manual for details).
Auto Door Override Press this button to open or close the Auto Door (if equipped).
Worklight These buttons toggle the internal worklight and High Intensity Lighting (if equipped).
Pendant Top Panel
Beacon Light
Provides quick visual confirmation of the machine’s current status. There are five different beacon states:
Light Status Meaning
Off The machine is idle.
Solid Green The machine is running.
Flashing Green The machine is stopped but is in a ready state.  Operator input is required to continue.
Flashing Red A fault has occured, or the machine is in Emergency Stop
4.3 SB Series - Keyboard
Keyboard
Keyboard keys are grouped into these functional areas:
  1. Function
  2. Cursor
  3. Display
  4. Mode
  5. Numeric
  6. Alpha
  7. Jog
  8. Overrides
Special Symbol Input
Some special symbols are not on the keypad.
Symbol Name
_ underscore
^ caret
~ tilde
{ open curly brackets
} closed curly brackets
\ backslash
| pipe
< less than
> greater than
Do these steps to enter special symbols:
  1. Press LIST PROGRAMS and select a storage device.
  2. Press F3.
  3. Select Special Symbols and press ENTER.
  4. Enter a number to copy the associated symbol to the INPUT: bar.
For example, to change a directory’s name to MY_DIRECTORY:
  1. Highlight the directory with the name that you want to change.
  2. Type MY.
  3. Press F3.
  4. Select SPECIAL SYMBOLS and press ENTER.
  5. Press 1.
  6. Type DIRECTORY.
  7. Press F3.
  8. Select RENAME and press ENTER.
4.4 SB Series - Function / Cursor Keys
Function Keys
List of Function Keys and How They Operate
Name Key Function
Reset [RESET] Clears alarms. Clears input text. Sets overrides to default values if Setting 88 is ON.
Power up [POWER UP] Zero returns all axes and initializes the machine control.
Recover [RECOVER] Enters tool changer recovery mode.
F1- F4 [F1 - F4] These buttons have different functions depending on the tab that is active.
X Diameter Measure [X DIAMETER MEASURE] Records X-Axis tool shift offsets on the offset page during part setup.
X/Z [X/Z] Toggles between X-axis and Z-Axis jog modes during part setup.
Z Face Measure [Z FACE MEASURE] Used to record Z-Axis tool shift offsets on the offset page during part setup.
Cursor Keys
The cursor keys let you move between data fields, scroll through programs, and navigate through tabbed menus.
Name Key Function
Home [HOME] Moves the cursor to the top-most item on the screen; in editing, this is the top left block of the program.
Cursor Arrows [Up], [Down], [Left], [Right] Moves one item, block, or field in the associated direction. The keys depict arrows, but this manual refers to these keys by their spelled-out names.
Page Up, Page Down [PAGE UP] / [PAGE DOWN] Used to change displays or move up/down one page when viewing a program.
End [END] Moves the cursor to the bottom-most item on the screen. In editing, this is the last block of the program.
4.5 SB Series - Display / Mode Keys
Display Keys
You use the Display keys to see the machine displays, operational information, and help pages.
Name Key Function
Program [PROGRAM] Selects the active program pane in most modes.
Position [POSITION] Selects the positions display.
Offsets [OFFSET] Displays the Tool Offset and Work Offset tabbed menu.
Current Commands [CURRENT COMMANDS] Displays menus for Devices, Timers, Macros, Active Codes, Calculators, Advanced Tool Management (ATM), Tool Table, and Media.
Alarms [ALARMS] Displays the Alarm viewer and Message screens.
Diagnostics [DIAGNOSTIC] Displays tabs for Features, Compensation, Diagnostics, and Maintenance.
Settings [SETTING] Displays and allows changing of user settings.
Help [HELP] Displays help information.
Mode Keys
Mode keys change the operational state of the machine. Each mode key is arrow shaped and points to the row of keys that perform functions related to that mode key. The current mode is always displayed in the top left of the screen, in Mode:Key display form.
NOTE: EDIT and LIST PROGRAM can also act as display keys, where you can access program editors and the device manager without changing the machine mode. For example, while the machine runs a program, you can use the device manager (LIST PROGRAM) or background editor (EDIT) without stopping the program.
Name Key Function
EDIT MODE KEYS
Edit [EDIT] Lets you edit programs in the editor. You can access the Visual Programming System (VPS) from the EDIT tabbed menu.
Insert [INSERT] Enters text from the input line or the clipboard into the program at the cursor position.
Alter [ALTER] Replaces the highlighted command or text with text from the input line or the clipboard.
NOTE: ALTER does not work for offsets.
Delete [DELETE] Deletes the item that the cursor is on, or deletes a selected program block.
Undo [UNDO] Undoes up to the last 40 edit changes, and deselects a highlighted block.
NOTE: UNDO does not work for deleted highlighted blocks or to recover a deleted program.
MEMORY MODE KEYS
Memory [MEMORY] Selects memory mode. You run programs in this mode, and the other keys in the MEM row control the ways in which the program is run. Shows OPERATION:MEM in upper left display.
Single Block [SINGLE BLOCK] Toggles single block on or off. When single block is on, the control runs only one program block each time you press CYCLE START.
Graphics [GRAPHICS] Opens Graphics mode.
Optional Stop [OPTION STOP] Toggles optional stop on or off. When optional stop is on, the machine stops when it reaches M01 commands.
Block Delete [BLOCK DELETE] Toggles Block Delete On or Off. When Block Delete is On, the control ignores (does not execute) the code following a Forward Slash (/), on that same line.
MDI MODE KEYS
Manual Data Input [MDI] In MDI mode, you run unsaved programs or blocks of code entered from the control. Shows EDIT:MDI in upper left display.
Coolant [COOLANT] Turns the optional coolant on and off. Also, SHIFT + COOLANT turns on and off the optional Auto Air Gun / Minimum Quantity Lubrication functions.
Handle Scroll [HANDLE SCROLL] Toggles Handle Scroll mode. This lets you use the jog handle to move the cursor in menus while the control is in jog mode.
Automatic Tool Changer Forward [ATC FWD] Rotates the tool carousel to the next tool.
Automatic Tool Changer Reverse [ATC REV] Rotates the tool carousel to the previous tool.
HANDLE JOG MODE KEYS
Handle Jog [HANDLE JOG] Enters Jog mode.
.0001/.1 .001/1 .01/10 .1/100 [.0001] /[.1], [.001] / [1.], [.01] / [10.], [.1] / [100.] Selects the increment for each click of the jog handle. When the mill is in MM mode the first number is multiplied by ten when jogging the axis (e.g., .0001 becomes 0.001 mm). The bottom number sets speed after you press JOG LOCK and an axis jog key or you press and hold an axis jog key. Shows SETUP:JOG in the upper left of the display.
ZERO RETURN MODE KEYS
Zero Return [ZERO RETURN] Selects Zero Return mode, which displays axis location in four different categories: Operator, Work G54, Machine, and Dist (distance) To Go. Select the tab to switch between the categories. Shows SETUP:ZERO in the upper-left display.
All [ALL] Returns all axes to machine zero. This is similar to POWER UP, except a tool change does not occur.
Origin [ORIGIN] Sets selected values to zero.
Single [SINGLE] Returns one axis to machine zero. Press the desired axis letter on the Alpha keyboard and then press SINGLE
Home G28 [HOME G28] Returns all axes to zero in rapid motion. HOME G28 will also home a single axis in the same manner as SINGLE.
CAUTION: Make sure the axis motion paths are clear when you press this key. There is no warning or prompt before axis motion begins.
LIST PROGRAM MODE KEYS
List Programs [LIST PROGRAM] Accesses a tabbed menu to load and save programs.
Select Programs [SELECT PROGRAM] Makes the highlighted program the active program.
Back [BACK ARROW] Navigates to the screen you were on before the current one. This key operates like the BACK button on a web browser.
Forward [FORWARD ARROW] Navigates to the screen you went to after the current screen, if you have used the back arrow. This key operates like the FORWARD button on a web browser.
Erase Program [ERASE PROGRAM] Deletes the selected program in List Program mode. Deletes the entire program in MDI mode.
4.6 SB Series - Numeric / Alpha Keys
Numeric Keys
Use the numeric keys to type numbers, along with some special characters (printed in yellow on the main key). Press SHIFT to enter the special characters.
Name  Key Function
Numbers 0-9 Types numbers.
Minus sign - Adds a minus (-) sign to the input line.
Decimal point . Adds a decimal point to the input line.
Cancel [CANCEL] Deletes the last character typed.
Space [SPACE] Adds a space to input.
Enter [ENTER] Answers prompts and writes input.
Special Characters Press [SHIFT], then a numeric key Inserts the yellow character on the upper-left of the key. These characters are used for comments, macros, and certain special features.
+ [SHIFT], then - Inserts +
= [SHIFT], then 0 Inserts =
# [SHIFT], then . Inserts #
* [SHIFT], then 1 Inserts *
‘ [SHIFT], then 2 Inserts ‘
? [SHIFT], then 3 Inserts ?
% [SHIFT], then 4 Inserts %
$ [SHIFT], then 5 Inserts $
! [SHIFT], then 6 Inserts !
& [SHIFT], then 7 Inserts &
@ [SHIFT], then 8 Inserts @
: [SHIFT], then 9 Inserts :
Alpha Keys
Use the alpha keys to type the letters of the alphabet, along with some special characters (printed in yellow on the main key). Press SHIFT to enter the special characters.
Name Key Function
Alphabet [A-Z] Uppercase letters are the default. Press SHIFT and a letter key for lowercase.
End-of-block (EOB) ; This is the end-of-block character, which signifies the end of a program line.
Parentheses (, ) Separate CNC program commands from user comments. They must always be entered as a pair.
Shift [SHIFT] Accesses additional characters on the keyboard, or shifts to lower case alpha characters. The additional characters are seen in the upper left of some of the alpha and number keys.
Special Characters Press [SHIFT], then an alpha key Inserts the yellow character on the upper-left of the key. These characters are used for comments, macros, and certain special features.
Forward Slash [SHIFT], then ; Inserts /
Left Bracket [SHIFT], then ( Inserts [
Right Bracket [SHIFT], then ) Inserts ]
4.7 SB Series - Jog / Override Keys
Lathe Jog Keys
Name Key Function
Tailstock towards spindle [TS <—] Press and hold this key to move the tailstock towards the spindle.
Tailstock rapid [TS RAPID] Increases the speed of the tailstock when pressed simultaneously with one of the other tailstock keys.
Tailstock away from spindle [TS —>] Starts the chip removal system in the "reverse" direction.
Axis Jog Keys +X/-X, +Y/-Y, +Z/-Z, +A/C/-A/C and +B/-B ([SHIFT] +A/C/-A/C) Jog axes manually. Press and hold the axis button, or press and release to select an axis and then use the jog handle.
Jog Lock [JOG LOCK] Works with the axis jog keys. Press JOG LOCK, then an axis button, and the axis moves until you press JOG LOCK again.
Coolant Up [CLNT UP] Moves the optional Programmable Coolant (P-Cool) nozzle up.
Coolant Down [CLNT DOWN] Moves the optional P-Cool nozzle down.
Auxiliary Coolant [AUX CLNT] Press this key in MDI mode to toggle the Through-Spindle Coolant (TSC) system operation, if equipped. Press SHIFT + AUX CLNT to toggle the Through Tool Air Blast (TAB) function, if equipped. Both functions also work in Run-Stop-Jog-Continue mode.
Override Keys
Overrides let you temporarily adjust the speeds and feeds in your program. For example, you can slow down rapids while you prove out a program, or adjust the feedrate to experiment with its effect on part finish, etc.
You can use Settings 19, 20, and 21 to disable the feedrate, spindle, and rapid overrides, respectively.
FEED HOLD acts as an override that stops rapid and feed moves when you press it. FEED HOLD also stops tool changes and part timers, but not tapping cycles or dwell timers.
Press CYCLE START to continue after a FEED HOLD. When the Setup Mode key is unlocked, the door switch on the enclosure also has a similar result but displays Door Hold when the door is opened. When the door is closed, the control is in Feed Hold and CYCLE START must be pressed to continue. Door Hold and FEED HOLD do not stop any auxiliary axes.
You can override the standard coolant setting by pressing COOLANT. The coolant pump remains either on or off until the next M-code or operator action (see Setting 32).
Use Settings 83, 87, and 88 to have M30 and M06 commands, or RESET, respectively, change overridden values back to their defaults.
Name Key Function
-10% Feedrate [-10% FEEDRATE] Decreases the current feedrate by 10%.
100% Feedrate [100% FEEDRATE] Sets an overridden feedrate back to the programmed feed rate.
+10% Feedrate [+10% FEEDRATE] Increases the current feedrate by 10%.
Handle Control Feed Rate [HANDLE FEED] Lets you use the jog handle to adjust the feedrate in 1% increments.
-10% Spindle [-10% SPINDLE] Decreases the current spindle speed by 10%
100% Spindle [100% SPINDLE] Sets the overridden spindle speed back to the programmed speed.
+10% Spindle [+10% SPINDLE] Increases the current spindle speed by 10%.
Handle Spindle [HANDLE SPINDLE] Lets you use the jog handle to adjust the spindle speed in 1% increments.
Forward [FWD] Starts the spindle in the clockwise direction.
Stop [STOP] Stops the spindle.
Reverse [REV] Starts the spindle in the counterclockwise direction.
Rapids [5% RAPID]/ [25% RAPID]/ [50% RAPID] / [100% RAPID] Limits machine rapids to the value on the key.
