Ballscrew - Vertical Axis - Replacement - AD0860
Service Home How To Procedures Ballscrew - Vertical Axis - Replacement - AD0860
Recently Updated Last updated: 05/08/2026
AD0860
Revision B - 08/2025
- Jump to Section - 1. Introduction 2. Remove the Servo Motor (1 step) 3. Replace the ballscrew (2 steps) Back to Top
This procedure explains how to replace the Z axis ballscrew on the vertical mill. This procedure can be applied to the Y axis ballscrew on the horizontal mill.
The main components of the vertical axis ballscrew:
  1. Ballscrew.
  2. Ballnut.
  3. Ballnut Housing.
  4. Servo Motor Housing.
  5. Radial Bearing Support.
  6. Servo Motor.
This procedure applies to the following service kits:
  • 93-2384: BALLSCREW, 40-8-1031-22 W/ SPACER
  • 93-2386: BALLSCREW, 40-12-1031-22 W/ SPACER
  • 93-24-0006B: BALLSCREW, 40-6-1031
  • 93-24-0021: BALLSCREW, 32-6-809.4
  • 93-24-0040: BALLSCREW, 32-10-524
  • 93-2386A: BSCREW 40-12-1031-22
  • 93-2384A: BSCREW 40-8-1031-22
  • 93-24-0009A: BSCREW 32-10-793-.625"
  • 93-24-0011C: BSCREW 40-10-1031-22
  • 93-24-0016B: BSCREW 32-10-663-.625"
  • 93-24-0021A: BSCREW 32-6-803-.625"
  • 93-24-0023A: BSCREW 32-8-793-.625"
  • 93-24-0024A: BSCREW 32-8-1047-.625"
  • 93-24-0074B: BSCREW 40-10-994-22
  • 93-24-0075B: BSCREW 40-10-868-22
  • 93-24-3006A: BSCREW 32-6-663-.625"
  • 93-24-8548: BSCREW 32-6-492-.625"
  • 93-24-8765: BSCREW 32-6-575-.625"
  • 93-4592:  BSCREW 40-12-634-22
  • 93-4593: BSCREW 40-8-670-22
  • 93-4594:  BSCREW 40-8-960-22
Jog the Z axis down.
Remove the servo motor mount cover [1].
Jog the Z axis UP until you can access the ballscrew collar nut clamping bolt [2] and loosen it.
Jog the Z axis UP until you can access the lower coupler collar clamping bolt [3] and loosen it.
Block the spindle head with the wooden block at the MAX height that still allows the access to the radial bearing support, ballnut housing and the motor support.
Once the spindle head is blocked you can turn the machine OFF.
Remove the Servo Motor. Refer to the Vertical Axis Servo Motor Replacement.
Disconnect the lubrication line from the ballnut.
Loosen the five bolts [1] that secure the ballnut to the ballnut housing and back them off 2 turns. This will allow you to spin the ballscrew a small amount while spindle head is blocked.
Install the ballscrew locking tool [2] onto the bearing support end and break loose the collar nut on the motor housing end of the ballscrew with the appropriate tooling [3].
Remove the locking tool from the bearing support end.
Rotate the ballscrew by hand to gain access to the collar nut clamping bolt on the support end of the ballscrew and loosen it.
Tighten the collar nut clamping bolt on the motor support end of the ballscrew and install the ballscrew locking tool.
Break loose the collar nut on the bearing support end of the ballscrew.
Remove the collar nut along with the radial bearings and wave washers [4].
Break loose the bolts [5] that secure the radial bearing support to the casting and pull the dowel pins [6] out with the 10-32 bolts.
Remove the radial bearing support.
Loosen the collar nut clamping bolt on the motor end of the ballscrew and remove the collar nut with the spacer [7].
While holding the ballscrew up, remove the bolts that secure the ballnut to the ballnut housing.
Lower the ballscrew so the top end is no longer engaged the thrust bearing [8] and remove it from the machine.
 Note: Tilting the ballscrew to the side while it engaged the trust bearing can damage the bearings.
 Note: Before installing the new ballscrew clean and inspect all mating surfaces. Any burrs or debris will affect the ballscrew alignment and can cause premature failure.
Place the new and the old ballscrew side by side. Spin the ballnut of the new ballscrew by hand until the ballnut is slightly higher than the one on the old ballscrew. This will assure that there is clearance between the shoulder of the ballscrew and the thrust bearing while you installing the ballnut mounting bolts.
Slide the new ballscrew up behind the spindle head and install the five bolts that secure the ballnut to the ballnut housing. Leave these bolts loose at this time.
Turn the ballscrew by hand untill it fully engages the thrust bearing.
Install the required spacer and the collar nut on the motor end of the ballscrew. Leave it hand tight at this time.
Install the radial bearing support using the dowel pins to locate it.  Leave the mounting bolts hand tight.
Install the wave washer, radial bearings, spacer and the collar nut. Leave it hand tight at this time.
Tighten the collar nut clamping bolt on the support end of the ballscrew and install the locking tool.
Torque the collar nut on the motor end of the ballscrew. Refer to the Ballscrew - Installation Tools and Torque Specifications for the corrrect torque value.
Remove the locking tool from the support bearing side and loose the collar nut clamping screw.
Torque the collar nut clamping bolt on the motor end of the ballscrew and install the locking tool.
Torque the bolts that secure the radial bearing support to the casting.
Torque the collar nut on the support end of the ballscrew. Refer to the Ballscrew - Installation Tools and Torque Specifications for the corrrect torque value.
Remove the locking tool and torque the collar nut clamping bolt on the support end of the ballscrew.
